Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 07-17-2012, 04:08 PM   #1
EmptyWallet
Senior Member
Default Master bedroom warmer than the rest of the house....
I know I probably need to get some model numbers and what not of the unit I have, and maybe some measurements to help people out with answering my question....but the master bedroom in my house (built within the past year) is several degrees warmer than everywhere else in the house. I'm talking even the master bathroom.
It's odd. There is one single output vent, maybe that's the problem. There is also an intake vent (small) in the master bedroom.
What could cause this? Any ideas on what to check?
EmptyWallet is offline   Reply With Quote
Old 07-17-2012, 08:11 PM   #2
justsam
Senior Member
Default Re: Master bedroom warmer than the rest of the house....
I am not going to be the one to have the knowledge to answer your question, but I do know more information is needed.
Where are you located?
Is the whole home built in the last year or a master bedroom remodel?
When I lived in Dallas, I had one unit that served only the master bedroom. How many physical units do you have?
How many square feet iin the house?
Single or two story?
Where is thermostat located?
Is it a zoned system? Both heating and AC?
justsam is offline   Reply With Quote
Old 07-17-2012, 09:44 PM   #3
mitusa
Senior Member
Friction?
mitusa is offline   Reply With Quote
Old 07-17-2012, 10:51 PM   #4
Falcon67
Senior Member
Falcon67's Avatar
Damaged feed, not enough flow, unbalanced outlets, not enough flow back to the return - guesses that.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 07-17-2012, 11:00 PM   #5
mrobins297aaa
Senior Member
mrobins297aaa's Avatar
is the bedroom on the second floor?
mrobins297aaa is offline   Reply With Quote
Old 07-18-2012, 12:45 AM   #6
cowboyjosh
Senior Member
Common problem. In my house in order for the master bedroom to stay the same temp as the rest of the house, I need to keep the door open so that there is enough air flow, otherwise you freeze to death in the winter or swelter in the summer. Its rare in any house for there not to be areas that are hotter or cooler then others. To help with your problem more details are needed like how many windows and doors are in the room, second floor master or main floor? Valuted ceiling? How many returns?
If your inside a year of the house being built you should still be in some sort of warranty. Most builders guarantee each area will not be more then 4 degrees different (thats what my HVAC guy guarantees at least).
cowboyjosh is offline   Reply With Quote
Old 07-18-2012, 03:44 PM   #7
EmptyWallet
Senior Member
I'm currently out of town and will be back to the house on Friday.
House is 1 story, 1 unit, 1900 square feet. Master has two windows, on one wall spread apart about 8 feet. Wall with windows faces north, so not into the sun at any point.
I'm going to get measurements of the room on Friday.
Old 07-18-2012, 03:56 PM   #8
mayday0017
Senior Member
Look at Duct work, there should be non on the end of the plenium unless it has a coil in the plenium. If this is done then you will have hot/cold rooms. Also look at how many times a single feed has a Y. Also look and see which way vents are facing they should ALWAYS blow on windows never away. I have seen this before, painters pull them down and then toss them back up and don't realize direction does make a difference.
Air condition systems are designed with flow in mind. When you restrict any flow you cause issues. As mentioned above do you have problems when door is open and closed both?
mayday0017 is offline   Reply With Quote
Old 07-18-2012, 04:36 PM   #9
EmptyWallet
Senior Member
I haven't really noticed with the door being shut or closed, but I can check when I get back home. I'll measure the room and take some pictures.
There is a large television at one end of the room, but even with it being off all night long and having it off for several days the room is still warmer significantly than the rest of the house. I thought that might be the problem initially but since I figured out it still occurs when it's off, something else might be going on.
Old 07-18-2012, 08:34 PM   #10
coolreed
Senior Member
coolreed's Avatar
Your AC unit may be far from the Master Bedroom, therefore you may need to adjust/restrict your outlet vents in other rooms to allow more airflow in your MB.
Is this during a certain time of day, say late afternoon, meaning you may be getting alot of radiant heat from late afternoon sun.
I am sure you will find the answer if you just analyze your system carefully.
Good Luck
coolreed is offline   Reply With Quote
Old 07-18-2012, 11:27 PM   #11
EmptyWallet
Senior Member
The unit is directly outside the master bedroom window. So scratch that off. LOL.
Old 07-19-2012, 03:50 AM   #12
6t7gto
Senior Member
6t7gto's Avatar
http://hvac-talk.com/vbb/index.php
6t7gto is offline   Reply With Quote
Old 07-19-2012, 06:48 PM   #13
pseudorealityx
Senior Member
Quote:
That's the outdoor condensing unit. It's doesn't have anything to do with the air in your bedroom.
The air handler is the inside piece, and is typically located in a mechanical closet, attic, basement, etc. That's where all the air comes from/returns to, and that's where all the ductwork will be.
pseudorealityx is offline   Reply With Quote
Old 07-20-2012, 11:07 AM   #14
tpwalsh
Senior Member
Good Luck
This is the problem with my master bedroom. Southern exposure in NC means the heat load in that room is probably double the other rooms in the house(ranch style, narrow end pointing directly south)
__________________
Tim
73 911 (restoration project)
Shifter Kart(autocrosser)
tpwalsh is offline   Reply With Quote
Old 07-20-2012, 12:12 PM   #15
pseudorealityx
Senior Member
Quote:
Decent windows? Any ability to put up some trees to shade said windows?
Old 07-20-2012, 12:43 PM   #16
Jagmandave
Senior Member
Jagmandave's Avatar
Wait a minute, you said the A/C condensor is right outside the MB window - so all the heat being thrown off by the condensor is being blown AT the master bedroom? Seems we may have at least one answer here.....
We have a small window unit in our MB, when the main A/C kicks off at night the house gets stuffy, so running the little window unit keeps the bedroom nice and cool and comfy without having to run the whole house A/C. I don't know if it saves us any money but it makes sleeping better.....
__________________
'04 Audi Allroad TT
'09 MINI Clubman S
'69 Jag XK-E
'80 Mini Clubman Estate
Jagmandave is offline   Reply With Quote
Old 07-20-2012, 01:15 PM   #17
pop pop
Senior Member
Your answer can only be found by a qualified A/C technician that will run a survey of air flow from your ductwork. If it can be balanced, he can do that or tell you why it can't. At that point you'll either have to rework ductwork or add an additional unit to the room.
pop pop is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
