Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 07-19-2012, 05:56 PM   #1
Rascal
Junior Member
Default Screw Type Adjustable Jack Stands?
Looking for help locating a good quality screw type height adjustable jack stand.
I have seen the Camco aluminum versions for sale, and that is the function I need, just in a more durable version. Something that will safely hold a car.
Has anyone seen something like this?
Thanks
__________________
Beer.
The cause and solution to all of life's problems.
Rascal is offline   Reply With Quote
Old 07-19-2012, 07:13 PM   #2
franzdom
Senior Member
franzdom's Avatar
Default Re: Screw Type Adjustable Jack Stands?
http://www.garagejournal.com/forum/s...d.php?t=148245
franzdom is offline   Reply With Quote
Old 07-25-2012, 03:48 PM   #3
Rascal
Junior Member
Thanks. I some extensive searching on this site and have found some close matches to what I need. This may work, just need to lob off the angled top and weld in a flat perch.
Thanks
__________________
Beer.
Old 07-25-2012, 07:04 PM   #4
jrlp
Senior Member
I bought some adjustable / foldable welding stands I use for jackstands. Well, they serve double-duty, of course. Even the small 2' tall ones are rated for 2,500lb each, and you can lift with them as well. If you can get them cheap, they're great. You can always chop off the V shaped head and weld on a platform if you'd chose. Personally, the V head works well even as a jackstand!
jrlp is offline   Reply With Quote
Old 08-26-2012, 09:31 PM   #5
GSMotorrad
Senior Member
GSMotorrad's Avatar
Quote:
Originally Posted by franzdom View Post
That is the most gorgeous work of art (for a jackstand) I've ever seen. I searched and searched, but can't find them for sale anywhere. Pelican site has AC Hydraulic jacks, but not their stands. They recommend Esco, which uses pins, instead of that incredible threaded bad-assery.
GSMotorrad is offline   Reply With Quote
Old 01-15-2013, 08:19 PM   #6
alan camby
Senior Member
alan camby's Avatar
Sorry, could not let the thread die.
Has anyone tried Zinko http://www.asedeals.com/zinko_jack_stands.html
Very expensive. Wonder what the quality is like.
The threaded rod looks a little on the small size, hard to tell though.
alan camby is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
