Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 07-22-2012, 11:40 PM   #1
dozerbuilder01
Senior Member
dozerbuilder01's Avatar
Default Homemade Ring Roller and Porch Swing Built From It
A few weeks ago, I added a porch on to my house. Wife's request. If I ever want that bigger garage in the future, this was necessary.
So now the wife wanted a porch swing. And I've always wanted a reason to build a ring roller. Perfect.
I basically built it out of scrap I had around (except the bearings). And I overbuilt it. It happens. I just kind of designed it as I went.
Cut out side plates with a torch and cleaned them up on the mill. This would have been a good time to build that CNC plasma cutter but need more $$$. Would have saved a lot of time on the plates.
The rollers are 2.5" OD and 3" wide with a 3/4" shaft. The shaft will be the weak point. It happens. And I'm using needle bearings. Why 3" wide? It's what I had. And should be enough for what I'll need.
As I said, I didn't have much of a plan. It was built around a 12 ton bottle jack. Overkill but I had it.
As with all of my projects, it lets me practice welding without wasting.
Here it is.
And first up was a handle. You'll see the finished wheel later on. (should have made it a bigger diameter but it was the first thing I made on it).
It worked well. It rolled the 1/2" tubing very easily. Only problem is that it tracked all over the place which I expected. I tried doing some bumpers which you may see in some other pictures, but I don't like it. And I don't feel like milling out grooves. And locking collars are too expensive. So I dug deep into the pile of scrap and found a 2.5" ID 3.75" OD piece of tube (seen in a picture above). So I'll make my own later. For what I needed to do at this time, it worked fine.
__________________
Built a mini dozer for my son that is loosely modeled after a Caterpillar Twenty-Two. Check it out.
http://www.garagejournal.com/forum/s...d.php?t=132812
View more at www.minidozerbuild.com
dozerbuilder01 is offline   Reply With Quote
Old 07-22-2012, 11:47 PM   #2
dozerbuilder01
Senior Member
Default Re: Homemade Ring Roller and Porch Swing Built From It
I also needed a bender. I made something similar for another project I'm working on. Yes, it's made out of aluminum but I had some scrap pieces that worked great. My lathe isn't that good to turn down a lot of metal quickly so any short cuts help. It is a 3" diameter die and the top half can be flipped to bend 1/2" tubing.
I had a rough idea what I wanted so I started building.
Using the new roller.....
Second bend....
Third bend....
Figured I'd give the top bar a little arch.
And this is where I'm at tonight.
__________________
Old 07-23-2012, 12:38 AM   #3
HOTFR8
HOTFR8's Avatar
Location: Castlemaine, Victoria. The Hot Rod Centre of Australia.
As per your Dozer build, neatly done.
__________________
1966 (Aussie) XP Falcon Sedan, 1923 T Roadster, 1948 F4 Truck, Home Built Teardrop Camper, 1969 International 4 X 4 truck (Classic),
84 x 30 Colorbond Shed with Showroom, Workshop, Car storage and Office.
www.streetrod.com.au
The Beast Runs>http://www.garagejournal.com/forum/s...0871&showall=1
Sheddwellers>http://www.garagejournal.com/forum/s...0063&showall=1
The International> http://www.garagejournal.com/forum/showthread.php?t=32307&showall=1
"V8's are Great, But Six inlines Just Fine" - CUMMINS Advertising.
HOTFR8 is offline   Reply With Quote
Old 07-23-2012, 12:46 AM   #4
rvr6000
Senior Member
rvr6000's Avatar
Are you kidding me.....that's cool as hell. Keep the pictures comin'.
rvr6000 is offline   Reply With Quote
Old 07-23-2012, 12:58 AM   #5
fomocoforrester
Senior Member
I would have loved to read about your project and seen the pictures - but I just can't keep scrolling back and forth like that....:SAD:
Maybe I can reduce the picture size at my end somehow?....
__________________
- John
Tiger Avon
CBR 1100 XX
20X30x14
fomocoforrester is offline   Reply With Quote
Old 07-23-2012, 12:59 AM   #6
kngkong
Senior Member
kngkong's Avatar
That's really awesome. Thanks for posting the making of the tools. I would really like to put something together like that sometime.
__________________
The Vault is open!
"I'm limited by my stupidity not my capability. "
kngkong is offline   Reply With Quote
Old 07-23-2012, 01:07 AM   #7
e-tek
Senior Member
e-tek's Avatar
Maybe you just need a BIGGER computer!!!
e-tek is offline   Reply With Quote
Old 07-23-2012, 01:21 AM   #8
fomocoforrester
Senior Member
Quote:
Ah ha! - maybe I should give that a try - thanks....
__________________
- John
Tiger Avon
CBR 1100 XX
20X30x14
Old 07-23-2012, 01:27 AM   #9
A_Pmech
A_Pmech's Avatar
Great work on all of the above. Despite the tracking problem it looks like the ring roller is making some very respectable bends.
I'm looking forward to seeing the completed swing. Are you copying a commercial design or is this all from scratch out of the notebook?
__________________
Your Finest Hammer
Building The Paulding Racer - My Blog
My Garage Machine Shop
Quote:
Originally Posted by Sir Stanley Hooker
One stroke to produce power and three strokes to wear it out.
A_Pmech is offline   Reply With Quote
Old 07-23-2012, 02:04 AM   #10
Trucky
Senior Member
Trucky's Avatar
Is that a mill table I see holding down that tube bender??
Trucky is offline   Reply With Quote
Old 07-23-2012, 02:12 AM   #11
HOTFR8
HOTFR8's Avatar
Hold ctrl and then scroll the page smaller with your mouse and see if that helps you with the pictures etc. you should be able to make the page smaller and bigger that way.
__________________
Old 07-23-2012, 02:12 AM   #12
nine4gmc
Senior Member
nine4gmc's Avatar
Quote:
thats the only thing that made me nervous, slick side rails though!! nice work!
nine4gmc is offline   Reply With Quote
Old 07-23-2012, 03:05 AM   #13
fomocoforrester
Senior Member
Quote:
Thanks HOTFR, that helps, but it makes the normal size pages smaller and there are issues with centering as well.
Oh well - time to get the manual out I guess - thanks again....
__________________
- John
Tiger Avon
CBR 1100 XX
20X30x14
Old 07-23-2012, 08:40 AM   #14
PCO6
Senior Member
PCO6's Avatar
Nice work ... AS ALWAYS!
__________________
PCO6 is offline   Reply With Quote
Old 07-23-2012, 09:45 AM   #15
NASTYZEN
Senior Member
NASTYZEN's Avatar
I love the ingenuity of your benders. Makes a great looking bend.
Square tubing is the worst to bend, specially a tight bend like that.
__________________
"Engineering is the art of modelling materials we do not wholly understand, into shapes we cannot precisely analyse so as to withstand forces we cannot properly assess, in such a way that the public has no reason to suspect the extent of our ignorance."
- Dr AR Dykes
You can get your Dimple Dies here: http://www.r-fabriplus.com/
NASTYZEN is offline   Reply With Quote
Old 07-23-2012, 11:07 AM   #16
Jim Stabe
Senior Member
Jim Stabe's Avatar
You will find so many uses for that ring roller. I made mine just to make the cockpit surround edge on my car but have used it for dozens of other projects since, handwheels probably being the most common. Nice job on the roller and bender. On the bender, do you have anything that produces the depression on the inside of the bend or does it form naturally?
__________________
If you want me to agree with you I can, but then we would both be wrong.
Building an MGB roadster that is widened 11" with C4 Corvette F&R suspension and blown LT1 V8 with 6 speed. Lots of pictures here:
Part 1
http://forum.britishv8.org/read.php?13,7581
Part 2
http://forum.britishv8.org/read.php?13,22422
Part 3
http://forum.britishv8.org/read.php?13,33108
Jim Stabe is offline   Reply With Quote
Old 07-23-2012, 11:25 AM   #17
superspec
Senior Member
holy crap that is nice. i wish i could walk outside and just throw together a bender on the spot.
superspec is offline   Reply With Quote
Old 07-23-2012, 07:55 PM   #18
HOTFR8
HOTFR8's Avatar
Thanks HOTFR8, that helps, but it makes the normal size pages smaller and there are issues with centering as well.
Well it works for me as I can see all the pictures then size it back to how I like to view the pages to read them.
__________________
Old 07-23-2012, 09:15 PM   #19
willy3486
Senior Member
Its post like this is why I am here! I love this, you wanted to make something and you made a really nice tool to make it. I really envy the folks here who have such tallent. Good work. My wife and I took a vacation in Chattanooga TN on a old docked paddlewheel boat. They had one of the nicest porch swings I have ever sat on. I cheated by drawing out the side and took pictures. That way I could use it to make a pattern. But to start off like you did and first make a tool is talent. There is no shortage of talent on this site. I can't wait to see more pics, keep up the good work.
__________________
My shop rebuild.
http://www.garagejournal.com/forum/s...ad.php?t=97315
willy3486 is offline   Reply With Quote
Old 07-23-2012, 09:38 PM   #20
machine_punk
Senior Member
machine_punk's Avatar
great job...
"Hmmm...I need a tube bender and ring roller...I'll just go out and build one."
you can rule the world with skills like that.
M_P
__________________
Rivets are the New Duct Tape.
"Kev's out of control. Don't put your keys down--he will rivet them to the table." (ozi jim from the Metal Meet Forum)
Just returned from the Santa Cruz Metal Meet, where I taught riveting and showed off recent projects from The Aerodrome Studio,
where I build functional art with solid rivets.
- my thread: http://www.garagejournal.com/forum/s...d.php?t=122188
- Blog:
http://TheAerodromeStudio.com/wordpress
machine_punk is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
