Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 07-25-2012, 06:33 PM   #1
Shrimp92
Default Split face block
I am getting ready to build a 40x40 and really like the look of split face block. Does anyone have experience with it? Any leaks in the block? Any responses will be greatly appreciated.
Shrimp92 is offline   Reply With Quote
Old 07-25-2012, 07:03 PM   #2
kartracer23
Senior Member
kartracer23's Avatar
Default Re: Split face block
Not only is the block more expensive, you'll also pay more to have it laid. That's becasue the block layer has to lift it over the string vs. sliding it to it.
They HATE split faced block.
When I did my garage, the first 3 courses were done with regular block and the top full and half were split face. Could have gotten by with just the top half course split, but there are a couple places the second course shows a bit.
But it looks nicer...
kartracer23 is offline   Reply With Quote
Old 07-25-2012, 08:12 PM   #3
ms fowler
Senior Member
Location: Littlestown, PA _ 6 miles south of Gettysburg
i was inspecting a job where they had split face block. The masons were UNION men, and proud of it. They argued over how to lay the SF--True to the inside ( smooth) face, true to the outside, split face side, or split the difference.
ms fowler is offline   Reply With Quote
Old 07-25-2012, 08:39 PM   #4
Big-Foot
Senior Member
Big-Foot's Avatar
Quote:
LOL
Good thing they aren't laying sod!!!
__________________
Regards - Randy
http://www.GT-Forty.com
Big-Foot is offline   Reply With Quote
Old 07-25-2012, 09:16 PM   #5
carhunter
Senior Member
What did they decide?
__________________
Life looks better in Kodachrome
carhunter is offline   Reply With Quote
Old 07-25-2012, 09:20 PM   #6
kbs2244
Senior Member
Almost all your current "big box" stores are built with SFB.
kbs2244 is offline   Reply With Quote
Old 07-25-2012, 09:49 PM   #7
RivennHewn
Senior Member
RivennHewn's Avatar
I laid my own split face block. No harder, or easier than flat faced.
don't buy it from Home depot or other box stores. They don't carry corner or half blocks, and you will probably get a mix of different batches.
The same block, from the same supplier can look very different between batches.
As far as whining about laying split faced block, I'd chock it up to just being union.
RivennHewn is offline   Reply With Quote
Old 07-25-2012, 10:04 PM   #8
Kentuckian
My 36 x 42 garage was built using split face block. Yes it cost me more, both to buy and to have laid. The increased labor cost did not come from being split face but from being heavy block vs lightweight block. There is more charge for laying heavy block.
The main reason I chose split face block is because a plain block wall is not real pretty. I have a corner lot and mine is the first house located in the subdivision. In fact everyone sees my garage before they see my house. My garage with the split face walls looks much nicer to everyone who comes into our subdivision.
Kentuckian is offline   Reply With Quote
Old 07-25-2012, 11:39 PM   #9
MadMechMaster
Senior Member
No experience with it personally, but being in the Chicago area, I have heard of issues like this:
http://blogs.wttw.com/moreonthestory.../leaky-condos/
Like with anything, the installation needs to be done right.
MadMechMaster is offline   Reply With Quote
Old 07-26-2012, 02:54 PM   #10
joes169
Senior Member
Quote:
If you don't plan on painting the block you'll want to use "Dry-Block" additive in the mortar, as well as find block that where built with "Dry-Block." To give you an idea, here it's getting increasingly harder to find split-face block that DON'T have "Dry-Block" in them. If you're painting the exterior, it's less of a concern.
And as for having to lay splitface block over the line, it's not necessary in most cases, you just lay your block from the other side of the wall in most cases........
joes169 is offline   Reply With Quote
Old 07-26-2012, 06:41 PM   #11
aar0s
Senior Member
aar0s's Avatar
My brother didnt have any trouble laying the SFB on my retaining wall. We made caps out of some old 8 inch block that I scored and whacked with a hammer
__________________
Our lives are determined by opportunities, even the ones we miss.
Quote:
Originally Posted by 432bullet View Post
I have never seen a Brinks truck following a hearse yet. Just a thought.:)
aar0s is offline   Reply With Quote
Old 07-27-2012, 07:55 AM   #12
AndysMBgarage
Senior Member
AndysMBgarage's Avatar
I sold split face block for 4 years dealing with builders, block layers and architects.
The two big things to remember that are critical to the end result are, design everything to suit the unit gauge, [in length and height] and lay it clean with a good damp proof course. It cannot be cleaned with hydrochloric acid as that will etch the block face and it needs to be protected from the elements until the mortar has cured.
I have attached a link to the construction specification guides and brochures we give to builders to ensure they get it laid right.
Use a waterproofing additive in the mortar and if your structure has no eaves, coat it with a penetrative sealer to reduce water access through the wall. Efflorescence can be a real problem due to the way water can easily saturate the block to the core.
It is also laid to a string line along the back of the block.
Cheers
__________________
Andrew
"Whether you think you can, or you think you can't, you're right."— Henry Ford
My Garage Build
AndysMBgarage is offline   Reply With Quote
Old 07-31-2012, 08:17 PM   #13
Shrimp92
Y'all are scaring me...you guys think I should go for split face or Hardie plank
Old 07-31-2012, 08:24 PM   #14
lt1driver
Senior Member
what is split face block?????
lt1driver is offline   Reply With Quote
Old 07-31-2012, 08:26 PM   #15
lt1driver
Senior Member
what is split face block for those of us who have never used blocks???????
Old 08-01-2012, 10:22 AM   #16
jaysberman
I have done a couple of split face buildings and they much more street appeal than regular painted block. I have found that it is wise to have them sprayed with water proofing to keep the rain water from penetrating the block.
jaysberman is offline   Reply With Quote
Old 08-01-2012, 10:36 AM   #17
Zeke
Senior Member
Zeke's Avatar
Location: Senior Member—in more ways than one in Long Beach CA
What?
Quote:
Quote:
Double wide blocks "split" to produce 2 irregular faces before they enter the kiln.
Zeke is offline   Reply With Quote
Old 08-01-2012, 10:50 AM   #18
openg111
They are split after they leave the kiln.
openg111 is offline   Reply With Quote
Old 08-01-2012, 12:07 PM   #19
NUTTSGT
NUTTSGT's Avatar
Tradesmen taught different ways to do things, you can find that any place that crews that normally don't work together and are on the same job site. You'll get the same between different trades too, carpenters, masons, plumbers or electricians, it has nothing to do with being a union member.
The same thing goes for inspectors too, some work with the construction guys and other create nothing but problems for them and the homeowners. Keep reading GJ and you'll find quite a few hate stories for the inspectors.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 08-01-2012, 12:17 PM   #20
NUTTSGT
NUTTSGT's Avatar
Ever seen a building like these in the link ? That's spilt face block.
http://superiorblock.com/Split_Face.html
__________________
ERIC
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
