Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 08-19-2012, 07:14 PM   #1
itwnexus
Senior Member
Default What is the best adjustable oil filter cap wrench?
What is the best adjustable oil filter cap wrench? I need it for hondas, nissans, hyundais.
Lisle 63600 Oil Filter Tool:
http://www.amazon.com/Lisle-63600-Oi...xgy_auto_img_b
Craftsman Universal Oil Filter Wrench, Auto-Adjustable
http://www.sears.com/craftsman-unive...p-02820523000P
harborfreight Universal 3 Jaw Adjustable Oil Filter Wrench:
http://www.harborfreight.com/univers...nch-69021.html
World's Best Universal Oil Filter Wrench - 3 Jaws:
http://www.amazon.com/Worlds-Best-Un...=pd_sbs_auto_3
itwnexus is offline   Reply With Quote
Old 08-19-2012, 07:23 PM   #2
scott0
Senior Member
scott0's Avatar
Default Re: What is the best adjustable oil filter cap wrench?
Other than the ones that we get directly from Honda made specifically for Honda filters. I use the top one you have pictured. It works great. The 3 finger ones don't seem to have the same "bite"
scott0 is offline   Reply With Quote
Old 08-19-2012, 07:27 PM   #3
dragonballz
Senior Member
Default
I have used the craftsman on hondas, nissan, and hyundai. It works very good.
It wont work on toyota's small filters... They are too small.
If i were to buy again, i'd get a spring loaded one. Is #1 spring loaded?
dragonballz is offline   Reply With Quote
Old 08-19-2012, 07:28 PM   #4
OEXL16B
The one in your first picture is the best. The others shown are junk.
OEXL16B is offline   Reply With Quote
Old 08-19-2012, 07:29 PM   #5
itwnexus
Senior Member
Lisle makes 2 sizes. Should I get the Lisle 63250 or 63600 Oil Filter Tool? The Honda oil filters are really small but Hyundai and Nissan oil filters are larger.
Lisle 63250 = oil filters from 3 1/8" to 3 7/8" in diameter
Lisle 63600 oil filters from 2-1/2" to 3-1/8" in diameter
Old 08-19-2012, 07:31 PM   #6
OEXL16B
I've only used the bigger size on old Toyota Land Cruisers.
Old 08-19-2012, 07:33 PM   #7
osborn.ozzy
Your going to need one of these for cartridge filters on the Hyundai/KIA
http://www.amazon.com/OTC-6904-Filte.../dp/B0014DGSGM
osborn.ozzy is offline   Reply With Quote
Old 08-19-2012, 07:35 PM   #8
skang
Senior Member
skang's Avatar
First one, however there are time you will need 3 jaw one like Craftsman. If you apply too much pressure on those thin jaws, it will bent out.
skang is offline   Reply With Quote
Old 08-19-2012, 07:38 PM   #9
osborn.ozzy
Also, the HF one sucks, the fingers are not really long enough to get a good grip since oil filters have a convex bottom.
Old 08-19-2012, 07:39 PM   #10
itwnexus
Senior Member
Current Hyundai Sonatas (2.4 L and 2.0 L turbo) do not use cartridge filters.
Old 08-19-2012, 07:44 PM   #11
fr0mastaj
Senior Member
fr0mastaj's Avatar
The Lisle (first) one by far. I have and despise the 3 prong ones.
fr0mastaj is offline   Reply With Quote
Old 08-19-2012, 07:44 PM   #12
skang
Senior Member
skang's Avatar
btw, Honda still use metal oil filters, but some of Nissan, Hyundai use canister oil filter. So you are going to need oil filter caps too.
Old 08-19-2012, 07:52 PM   #13
Skin
Senior Member
Hazet 2172 is the best. I actually got it specifically due to overtightened filters on Honda B20 engines. Thats probably one of the most inconvenient filter placements on any passanger vehicle. Dont waste your time with any other adjustables. Its expensive (around $80 i think) but compare that to having 3 or 4 different styles that barely work. Plus the hazet has a much wider range of adjustment. Also worth having is a strap model, and a set of the caps.
Skin is offline   Reply With Quote
Old 08-19-2012, 07:57 PM   #14
cide1
Senior Member
Default
I have the Lisle, and a bunch of others that don't get used anymore. The design of it is very good, and it removed a filter from my wife's Honda that no other wrench would
cide1 is offline   Reply With Quote
Old 08-19-2012, 07:57 PM   #15
osborn.ozzy
Quote:
If that's the only Hyundai's you work on then you are right.
Old 08-19-2012, 08:02 PM   #16
skang
Senior Member
skang's Avatar
Quote:
why is the oil filter so tight to begin with?
I do use filter tool to remove the oil filter, but with very minimum effort.
Old 08-19-2012, 08:14 PM   #17
Sam B
Junior Member
Here's a vote for the Craftsman, would be lost at work without it. Gets borrowed daily for those filters that cups and pliers won't move.
The HF version has the right idea, but the little red socks are worthless and doesn't have enough reach.
The Lisle wrenches are great except for the little springs that tension the jaws; seen the springs fly out and make the wrench a paperweight.
Sam B is offline   Reply With Quote
Old 08-19-2012, 08:22 PM   #18
itwnexus
Senior Member
Will the Lisle 63250 (oil filters from 3 1/8" to 3 7/8" in diameter) fit on the larger Honda S2000 oil filters or on Toyota Tacoma oil filters?
Old 08-19-2012, 08:32 PM   #19
cide1
Senior Member
Default
From the factory it was very tight. Not sure why, and I doubt the dealer touched it.
Old 08-19-2012, 08:47 PM   #20
RCStocker
Senior Member
I use a lot of the swivel head band filters but on the new cars with engines in the front it can be a toss up. I have 6 different ones. Only because my family buys different cars. I am a Ford man. If it doesn't have a V8 I don't own it and never will.
I had a neighbor 33 years ago that had a filter on his new car that was so tight that I had to use a chain pipe wrench to get it off. I crushed it to death but I got it off for him. They are not all the expensive and You will find you will need different types. I wish they would make everthing standard. It would be nice if they put an allen socket in the end of the bloody things. That would make it simple.
RCStocker is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
