Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-27-2012, 04:21 PM   #1
ESwartz
Default OSB Ceiling installation
I'm going to be installing 7/16" OSB in my shop for my ceiling. My trusses are on 4' centers.
1. Do I need to install what I call sleepers between the trusses every 2' or will the OSB not sag on 4' centers? I will be adding blown in insulation later, that is the only weight that will be on the OSB.
2. Do I need a vapor barrier before I install the OSB?
Thanks
ESwartz is offline   Reply With Quote
Old 08-27-2012, 05:14 PM   #2
Falcon67
Senior Member
Falcon67's Avatar
Default Re: OSB Ceiling installation
It'll sag on 48" OC, I'd about guarantee. 24" OC is the max rating for 7/16". It's stamped right on the material.
Can't answer the other - vapor barriers are climate dependent. We don't use them down here in a shop/garage.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 08-27-2012, 05:32 PM   #3
Stinger
Senior Member
Stinger's Avatar
I agree, I've been in a pole barn that had OSB sagging for this very reason.
Stinger is offline   Reply With Quote
Old 08-27-2012, 05:54 PM   #4
willymakeit
Senior Member
Yes and the sleepers need to be able to take the span and added weight. As mentioned previously the vapor barrier could be area dependent. Ask your insulation installer.
willymakeit is offline   Reply With Quote
Old 08-27-2012, 06:53 PM   #5
cyamaha2007
Senior Member
cyamaha2007's Avatar
on barns weve done i install the sleepers vertically between the trusses. Its much stronger but takes longer. We used 2x4s
__________________
Male pussification is the downfall of America.
Check out my 36wx56Lx14h pole barn build done the hard way http://www.garagejournal.com/forum/s...d.php?t=118655
cyamaha2007 is offline   Reply With Quote
Old 08-27-2012, 07:44 PM   #6
ddawg16
Senior Member
ddawg16's Avatar
Why OSB instead of drywall? Price is about the same....but drywall will not burn....and reflects light better.
Either way, you will need the support (sleepers)
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
