Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 08-30-2012, 10:43 AM   #1
xbanone
Default 100 amps to shop. What wire size?
I just had an electrician install a 200a service upgrade to my house. I would like to run a 100 amp feed to the new shop. I have a 100a panel in the shop and will have to go about 100-120 feet distance underground. What cable do I need to ask for at the electrical supply house? I will have 3 conductors and a ground. #3 THHN? What should I expect to pay for copper?
xbanone is offline   Reply With Quote
Old 08-30-2012, 10:48 AM   #2
930dreamer
930dreamer's Avatar
Default Re: 100 amps to shop. What wire size?
Here's some good info. Post # 7 & 9.
http://www.garagejournal.com/forum/s...d.php?t=162740
__________________
I can take it apart.
http://stores.ebay.com/930dreamer?_rdc=1
930dreamer is offline   Reply With Quote
Old 08-30-2012, 11:03 AM   #3
xbanone
Thanks,
according to the chart, #4 copper or 2AL for 100 amps. Is voltage drop something I should consider at this distance?
Old 08-30-2012, 11:19 AM   #4
930dreamer
930dreamer's Avatar
Distance is a factor.
__________________
Old 08-30-2012, 11:22 AM   #5
pattenp
Senior Member
pattenp's Avatar
For a feeder the #2 Al is good to 90A not 100A. #2 Al used as service entrance carrying the whole load to a dwelling can be used at 100A. That chart is for 3 wire service entrance. You are doing a 4 wire branch/feeder circuit, which is a different chart/table. It's a NEC thing. If you can be happy with 90A use Mobile Home Feeder 2-2-2-4 or 2-2-4-6.
http://www.southwire.com/products/MobileHmFeeder.htm
The #2 is fine for the 120', it will be less than 3% at 90A @ 75C.
pattenp is offline   Reply With Quote
Old 08-30-2012, 03:44 PM   #6
sberry
Senior Member
sberry's Avatar
And 95 and a half plus of the time it will never see much load, I like the 90A with alum also.
sberry is offline   Reply With Quote
Old 08-30-2012, 05:17 PM   #7
CoyoteLL
CoyoteLL's Avatar
Just ran 50' to a 100A subpanel in my garage. Used #4 Copper. Pulled 4 legs through 1 1/2" PVC conduit.
__________________
My Shop Build (2012)
http://www.garagejournal.com/forum/s...d.php?t=143973
CoyoteLL is offline   Reply With Quote
Old 08-30-2012, 05:44 PM   #8
pattenp
Senior Member
pattenp's Avatar
Hope you are feeding it from a max of 90A breaker, because #4 Cu is rated at 85A.
Old 08-30-2012, 10:24 PM   #9
Gary S
Senior Member
I ran #2 copper to my garage. Menards didn't have #3 in stock and the other vendors in town wanted more for #3 than I paid for #2 at Menards. It handles the 100a breaker with room to spare.
Gary S is offline   Reply With Quote
Old 08-31-2012, 03:42 PM   #10
mrjaw14
Senior Member
I did a similar project earlier this year and was wanting #4 Cu thhn/thwn, but the cost of #2 Al XHHN was literally about half of what it was going to cost for Cu. I did the entire project for the cost of what #4 Cu would have been.
90A breaker > 4 cond AL to a subpanel in detached garage (on 100A "main disconnect")
I had a single 15A circuit prior to this but anything with a motor would heat up really quickly, voltage would drop to around 100 VAC, it was horrible. Things are much happier now that I have an actual sub panel setup. V-drop is next to nothing under the same loads I was putting on it before.
mrjaw14 is offline   Reply With Quote
Old 08-31-2012, 09:29 PM   #11
Dave Maxwell
Senior Member
Just got a price from local electric supply. #2 copper is 1.37 per foot. Menards is 1.89.
Dave Maxwell is offline   Reply With Quote
Old 08-31-2012, 10:10 PM   #12
fnsane
Most economical is 1/0 al SER.
fnsane is offline   Reply With Quote
Old 08-31-2012, 10:17 PM   #13
'04 Cummins
Senior Member
'04 Cummins's Avatar
Quote:
Wire other than romex is where the supply houses have the box stores beat by a mile. Panels and breakers usually seem to be cheaper at HD, Lowes, etc. YMMV
'04 Cummins is offline   Reply With Quote
Old 08-31-2012, 10:34 PM   #14
Falcon67
Senior Member
Falcon67's Avatar
#2 AL mobile feeder is running about 1.80/ft. That's a 4 wire cable - not a single wire. It's what I used for mine - it was 1.47/ft when I bought it. I fused my 100A panel at 75A in the panel at the meter.
Error - 70A is what's in the can.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 09-01-2012, 12:25 AM   #15
Norcal
Senior Member
Quote:
Where are you finding 75A fuses or circuit breakers? 75 is not a standard size, 70A is.
Norcal is offline   Reply With Quote
Old 09-01-2012, 09:55 AM   #16
pattenp
Senior Member
pattenp's Avatar
That would be okay, except for the fact that SER can't be run under ground.
Old 09-01-2012, 09:55 PM   #17
fnsane
Pipe it.
Old 09-01-2012, 10:15 PM   #18
Steevo
Senior Member
Steevo's Avatar
Mine is about 90 ft overall from main panel to sub in shop.
We used #2 copper to feed the 100A sub panel.
Steevo is offline   Reply With Quote
Old 09-01-2012, 11:48 PM   #19
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Quote:
Pipe it.
338.12 Uses Not Permitted.
(A) Service-Entrance Cable. Service-entrance cable (SE)
shall not be used under the following conditions or in the
following locations:
(1) Where subject to physical damage unless protected in
accordance with 230.50(B)
(2) Underground with or without a raceway
(3) For exterior branch circuits and feeder wiring unless
the installation complies with the provisions of Part I of
Article 225 and is supported in accordance with 334.30
or is used as messenger-supported wiring as permitted
in Part II of Article 396
Charles (in GA) is offline   Reply With Quote
Old 09-02-2012, 10:23 AM   #20
Falcon67
Senior Member
Falcon67's Avatar
Error - its a 70. 220,221 - whatever it takes
It was in stock and plenty big enough IMHO. I worked out here all day yesterday, cut some stuff on the lathe, built a mobile stand for the handsaw- bet I didn't pull 10~15A peak all day.
__________________
Chris - Merkel, TX
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
