Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 09-02-2012, 02:28 PM   #1
gahrajmahal
Senior Member
gahrajmahal's Avatar
Default Central Air Conditioning, Hide The Ugly Compressor
My wife wanted to camoflage the ugly compressor next to the house and found something online. Needless to say it was less than desired and made of plastic. (sorry no photo of that), but we did find out a tall cover would draw your eye to the compressor instead of minimize the appearance. After checking online I found few examples or pictures of how others covered their air conditioning compressor.
After checking the home centers without any inspiration I realized I should be immitating our privacy fence that borders two sides of our property.
I purchased two decorative 4 x 4 ballisters that matched the fence posts. I also bought 20 4" X 4" cedar pickets.Additionally I purchased 8, 2 x 2 fence posts.
The Finished cover.
You can see I had quite a bit of other stuff to avoid like the dryer vent, furnace vent and 220v fusebox.
The assembly was pretty straight forward. I used some Kreg pocket screws to attach the 2 x 2's to the upright posts. The cedar 4 x 4's were spaced using the 2 x 2 as a guide.
I didn't want the wood to be in contact with the ground, so to deter the termites I used these plastic feet they had.
The only fasteners holding the little enclosure near the compressor are 4 screws through the vertical 2 x 2's to the facia of the house. Those 2 x 2's do not come in contact with the ground.
The curve was cut using two screws driven partway into the cedar. I put a thin piece of wood trim between them and bent it in the middle to a pleasing curve. Then I traced it with my pencil and cut the curve with the jig saw.
I measured between the back uprights and cut the front cross braces to the same length. I put a couple of pocket holes in the cross pieces with my Kreg jig making it pretty easy to connect them between the 4 x 4 decorative posts.
I appreciate all the folks who post their projects as I often borrow all or part of the idea around my house. Maybe you can get an idea from mine.
__________________
Can't never did anything...
What mom always told me when I wanted to give up.
gahrajmahal is offline   Reply With Quote
Old 09-02-2012, 03:42 PM   #2
geezer48
Senior Member
geezer48's Avatar
Default Re: Central Air Conditioning, Hide The Ugly Compressor
that looks nice,build your own if you cant find what you want,it better anyway.
geezer48 is offline   Reply With Quote
Old 09-02-2012, 04:31 PM   #3
pipsters
Senior Member
Neat idea but too close to the condenser IMO. For proper airflow you're suppose to leave something like 3' on the sides.
Reading thru I can't tell, can it be easily removed for servicing?
pipsters is offline   Reply With Quote
Old 09-02-2012, 05:48 PM   #4
7th Kahuna
Senior Member
7th Kahuna's Avatar
Nice job. Not only serves to hide the compressor but adds a bit of visual interest to the house.
7th Kahuna is offline   Reply With Quote
Old 09-02-2012, 05:50 PM   #5
KCarGuy
Senior Member
KCarGuy's Avatar
That turned out very cool. Nice Job!
KCarGuy is offline   Reply With Quote
Old 09-02-2012, 06:32 PM   #6
furnacewhisperer
Junior Member
I hate that this is my first post, but why are you embarassed of the machine that keeps you comfortable inside? I hope that you took the same consideration when hiding your trash cans. Honestly, I'm not trying to sound derogatory. Rich
furnacewhisperer is offline   Reply With Quote
Old 09-02-2012, 07:07 PM   #7
premierplayer
Senior Member
premierplayer's Avatar
That looks great. I've got swimming pool equipment and A/C on the back of my place I'd like to hide. You've got me thinking...
__________________
Quote:
Re: Missing SnapOn man
Don't worry. It takes a while to drive over to China and pick up a new load. Give him time.
"Show us your PVC air lines"
premierplayer is offline   Reply With Quote
Old 09-02-2012, 07:23 PM   #8
Ron Lombardo
Senior Member
Ron Lombardo's Avatar
... looks very nice ...BUT did you read the Manufactuers recommendations .... need a minimum of 30" on the 3 sides for air flow ... those solid boards are going to burn out the compressor and condenser fan ... also how are you going to pressure wash and clean the coil every year ?
R
Ron Lombardo is offline   Reply With Quote
Old 09-02-2012, 08:26 PM   #9
er3456df
Senior Member
Quote:
R
With the gaps in between the boards, 30" may be overkill- but yeah, space em out a lil. 1 foot on each side wouldn't look too bad.
er3456df is offline   Reply With Quote
Old 09-02-2012, 08:40 PM   #10
green.bubbly
Senior Member
green.bubbly's Avatar
Neat idea and it turned out nice. As mentioned, you might have a problem with airflow but with the gaps in the boards, you might be ok. You could also leave off the section furthest from the house if need be. The unit would still be hidden from the front and back. Do you plan on painting it the same color as the house? I kinda of like it the way it is. Good contrast.
On a side note, I would do what I could to deflect the dryer vent away for the unit as some lint will get sucked into the coils causing them to eventually clog.
How do you like that Kreg setup? I just ordered a set after eyeing them for several months. First project will be some cabinets.
__________________
_______________________________________
My garage and steel home build thread...
http://garagejournal.com/forum/showthread.php?t=91518
green.bubbly is offline   Reply With Quote
Old 09-02-2012, 08:58 PM   #11
gahrajmahal
Senior Member
Quote:
Obviously you have not checked out my " what is the best trash can" posting I did last year. I do care how those cans look. Still looking for those new cans by the way.
In the fall I vacuum the leaves, spiderwebs and mouse nests out from the inside. I then lubricate the motor shaft and other sprayable surfaces with WD 40 or similar. Then it gets a heavy vinyl cover. It's about 15 years old now.
Green Bubbly, you are going to LOVE your Kreg setup. I only have the basic set. I bought it for a custom cabinet project and it really made the job easier and better. It is super strong when combined with normal glue up. Be sure and post up your project. I will keep an eye out for it.
Quote:
Yes I know looking at it it does seem a bit close. But I have to tell you it is more open than the one we purchased initially. I may add a spacer to the house thereby bringing the front out a bit. It will make it intrude into the path a bit more.
__________________
Old 09-02-2012, 10:05 PM   #12
MoparTrucks
Senior Member
MoparTrucks's Avatar
Nice job, the Mrs has been after me to do something similar and you gave me some ideas.
MoparTrucks is offline   Reply With Quote
Old 09-03-2012, 07:04 AM   #13
ChristopherLutz
Senior Member
Looks nice and thanks for taking the time to post.
ChristopherLutz is offline   Reply With Quote
Old 09-03-2012, 07:26 AM   #14
Moose02
Senior Member
Moose02's Avatar
great looking I hope my wife doesn't see it
__________________
moose aka Glenn
Moose02 is offline   Reply With Quote
Old 09-03-2012, 08:23 AM   #15
Bull
Bull's Avatar
It looks like a very neat job, for sure. Nice choice of materials and careful attention to aesthetics.
I am also concerned about the airflow; the spaces between the boards aren't going to make up for the lack of openness.
Please also consider how the unit will be serviced, as mentioned above. If a tech has to come to your house and fit his own body, plus his manifold set, plus some tools, and find room to bend/kneel/work, even a 30" space begins to feel very constrictive.
The companies that sell the covers don't need to fix the problems that they create, so I wouldn't use their design as a model for what should be done in terms of not harming the unit.
__________________
EUDAIMONIA
"It Pays to Stay in the USA!"
Bull is offline   Reply With Quote
Old 09-03-2012, 09:31 AM   #16
JimL
Senior Member
R
Don't use a pressure washer
Too close. Don't care if you don't think it is restrictive, it is being that close.
JimL is offline   Reply With Quote
Old 09-03-2012, 09:45 AM   #17
Lugnut64052
Senior Member
Yeah, it's too close and too solid. I'd make it bigger, move the sides about a foot away from the unit, and make it removable. It's a real drag trying to wind yourself into some hole to work on a unit that's in a tight spot.
__________________
The road to hell is paved with OSB.
Lugnut64052 is offline   Reply With Quote
Old 09-03-2012, 10:14 AM   #18
mitusa
Senior Member
Quote:
This....and put something down to keep the weeds and grass from growing up around the enclosure. Those units don't take well to deviations from normal. They also work better in shade.
mitusa is offline   Reply With Quote
Old 09-03-2012, 12:56 PM   #19
digdug18
Senior Member
digdug18's Avatar
Location: Williamsport, Pa(school), Ottsville, PA(Home)
This isn't cheap, but hammacher schlemmer sells a fake bush that covers the whole A/C compressor. Price is very steep at $549.95, looks to be the same material as a fake X-mas tree though.
http://www.hammacher.com/Product/Default.aspx?sku=82556
digdug18 is offline   Reply With Quote
Old 09-03-2012, 03:24 PM   #20
brownbagg
Senior Member
just paint it the same color as house and forget about it, some people got too much time on their hands
brownbagg is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
