Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-07-2012, 11:12 AM   #1
mayday0017
Senior Member
Default Fixing "Lumpy" yard
I know this isn't a garage discussion but it is general....
My back yard is what I would call "Lumpy and Bumpy" when I mow it the lawnmower bounces up and down and the yard doesn't look nice and smooth. Ideally I would order 2-3 loads of dirt have them dumped in the back yard and rent a bobcat and spread it all out. But I am to cheap to rent the bobcat & to lazy to spread that much dirt by hand.
Is there an more easy way to fix my problem? I was thinking over the winter while grass is dead/dormant anyways to just cut it super short so I could really see the ground. Then I could fill in the areas as needed and spread out some of the small "mounds" of dirt that are around as well.... I plan on installing a sprinkler system over the winter too so seems like maybe I do all of this at once and call it a day (week).
Another Problem I have is mixed grass types in my back yard, I have 1/2 St. Augustine and 1/2 Bermuda grass. I only mention this because if someone has a solution for getting rid of the Bermuda that would be great too!
Any input would be great!
mayday0017 is offline   Reply With Quote
Old 09-07-2012, 11:23 AM   #2
Joe B.
Senior Member
Joe B.'s Avatar
Default Re: Fixing "Lumpy" yard
http://www.sears.com/agri-fab-univer...-07124250000P?
If you don't have a tractor, just hitch up your wife.
Joe B. is offline   Reply With Quote
Old 09-07-2012, 11:31 AM   #3
malibu101
Senior Member
malibu101's Avatar
I am watching this thread to learn the answers too.
I have more or less "holes" in my yard versus "bumpy". I don't know what kind of grass I have but it grows well. I use a walk behind pushmower and the holes cause the mower to come close to scalping the grass in a few areas.
I've never done anything because I've wondered.......
Should the existing grass be removed before filling in with good soil and seed?
Should the ground (the yard) be loosened up a bit before filling?
Would doing small (2' diameter) sections play well with the existing?
I am not trying to hijack your thread but I think we both have similar questions.
malibu101 is offline   Reply With Quote
Old 09-07-2012, 11:32 AM   #4
Dale B
Senior Member
Dale B's Avatar
It's a bit of work , but rototill it to 2-3 inches , and rake it smooth with an aluminum landscape rake. They are about 3 ft wide, it goes fast. Reseed as needed..... If you have St. Agustine like me , it will come back on it own , just water !
Dale B is offline   Reply With Quote
Old 09-07-2012, 11:38 AM   #5
digdug18
Senior Member
digdug18's Avatar
Location: Williamsport, Pa(school), Ottsville, PA(Home)
Depends where your at, but there are a couple different ways to deal with your problem.
Easiest but not really the best is to fill the holes to 3" to the top then put on a layer of turf.
Honestly though Its not the best way. If you want to do it right, it is a 1 year fix really. I worked for many landscapers, and this is how we did it each time. In the end we'd go to the persons house an 2-3 times for 1 year.
First, you need to kill all the grass in the yard. Roundup or similar works good for this purpose, though you need to reapply about 2 weeks after to kill anything that reamerges.
After everything it dead we'd use one of these:
It would spin towards the front of the tractor, pulling off grass, rocks, etc. It would move all the dirt to the low spots from the high spots. 2 guys walk behind the machine with large rakes to smooth out the ground, pull any additional rocks out, etc.
Then after the yard is smooth, you do 1 of three things:
1. Seed and straw
2. Hydro seed
3. Lay down turf
Each of the 3 have different price tags, I listed them in cheapest to most expensive, which also happens to be listed in worst method to best. And less likely to most likely for the grass to take hold.
Keep in mind if you turf you need to keep it wet for the first 2 weeks, so if your on a well pump it isn't advised, you could burn out your pump if your not careful.
We would almost always hydroseed, especially if seeding on a hill.
digdug18 is offline   Reply With Quote
Old 09-07-2012, 11:47 AM   #6
kartracer23
Senior Member
kartracer23's Avatar
Not sure where you are, but roll it. Here in Indiana, we normally do it in the spring when the ground is super wet. Then, take sand and fill in any depressions left. The sand will work it's way down into the dirt and push it up. While that's happening, the grass will go through it so your yard doesn't look like a sand trap.
There's a landscape company here that has a ride-on roller and I'm going to have them do mine in the spring-too many narrow areas for a pull behind.
kartracer23 is offline   Reply With Quote
Old 09-07-2012, 11:49 AM   #7
steel 35
Senior Member
steel 35's Avatar
My wife has been filling the low spots for years and now when I walk on it I need tall tight boots so I don't twist my ankles.
This would be my next test because with two labs reseeding is out.
steel 35 is online now   Reply With Quote
Old 09-07-2012, 12:01 PM   #8
MoonRise
Senior Member
MoonRise's Avatar
band-aid fix?
Try to find the low spots and spot-fill them with some (good) dirt. May or may not work, may or may not involve having to spot reseed (depending on just how low the spots were and just how much dirt you had to put in).
Really want it all flat and smooth?
Kill all the existing vegetation, wait till all is dead, rototill it all (remove rocks and sticks and 'chunks' at that time) and also add and till-in soil amendments (organic matter such as compost, peat moss, etc), rake smooth with (several) landscape rakes, then reseed or apply sod.
Like usual, Good, cheap, fast. Pick any two. Good and cheap = not fast. Good and fast = not cheap. Cheap and fast = not good.
MoonRise is offline   Reply With Quote
Old 09-07-2012, 01:14 PM   #9
Spudland_Dave
Senior Member
Spudland_Dave's Avatar
Power Rake...Only way.
Not cheap...but most certianly the ONLY way to make golf course quality yards. I know because I've got one I built myself...works AWESOME.
Spudland_Dave is offline   Reply With Quote
Old 09-07-2012, 01:18 PM   #10
mayday0017
Senior Member
Hm... think I might do a "mix" of things....
1. Cut grass on shortest possible setting during winter, this will allow me to identify low spots and high spots and just make less grass to mess with during sprinkler install and moving soil.
2. Identify how bad the yard really is, if it is only slight lumps and hole (fairly low qty) then shovel the high spots and fill the low. If it is worse then that rent a tiller and till the whole yard prior to sprinkler install, rake smooth, install sprinkler system, rake smooth again.
3. Rent/Borrow/Buy a roller and roll the yard once or twice during the winter months using new sprinkler system to get ground soft before rolling and avoid damaging sprinkler heads with roller.
4. Use arrator attachment on the entire yard around first part of spring and checker sod the yard with St Augustine and water well.
Oh and I forgot the 1st thing dream about steps 1 through 4 because after typing all of that I realized I will most likely install the sprinkler system and toss some dirt in the holes and hope for the best!
Old 09-07-2012, 01:46 PM   #11
Joe B.
Senior Member
Joe B.'s Avatar
I had this problem and I just filled in the holes with the cheapest dirt from a big box store. I put a little fertilizer and grass seed on top and it was good. I had to water this year on account of the drought but any other year I would have been done. My holes were a result of trees that have been gone for decades and the stumps had long ago rotted away.
Old 09-07-2012, 03:40 PM   #12
Senior Member
theoldwizard1's Avatar
If you want it done fast, strip the sod, rototill, rake, roll and lay sod. You will have to re-roll every second or third spring
Quote:
Simple and it works !! Unless you have large depressions you should not need any fill of any kind. Throw some seed down when you are done to help fill in where you have killed the grass.
WOW I wonder if you could rent something like that !
theoldwizard1 is offline   Reply With Quote
Old 09-07-2012, 03:57 PM   #13
ctb
Senior Member
I had the same problem. I attacked the grass with a hoe taking it all off. Then borrowed a roto tiller and went over it a few times. Raked it level and re-seeded. Was a lot better for a few years then it started getting lumpy again. Time to send the wife out this time.
ctb is offline   Reply With Quote
Old 09-07-2012, 05:17 PM   #14
KEH
Senior Member
Good luck o getting rid of the Bermuda grass. It come back from the roots ans from seed. I don't know how long the seed remains viable in the soil.
Spray Roundup now and again in 2-3 weeks to get the spots you missed. Roto till the yard, or at least the rough spots(probably whole yard from what you say) Rake smooth, filling in low spots. Keep traffic off the yard, this includes big dogs that might mire down when it is wet and muddy. To keep dogs off, put up a low electric fence, if possible.
Not familar with St Augustine grass. If it is established by seeding in the spring, seed next spring. During the growing season spot spray Bermuda grass. Maybe all the seedling Bermuda will be killed but I wouldn't bet on it. Good luck.
KEH
KEH is offline   Reply With Quote
Old 09-07-2012, 06:00 PM   #15
Toomanytools?
Senior Member
We get lumpy yard from worms mounding up dirt then it gets packed down by mowing. One thing is to aireate or core the yard, then roll with a big water drum like above post. Bermuda grass needs to be killed and kept that way for a year, you can spot kill but it's hard. There are some products out there that claim to work but takes 3 to 4 applications throughout the year. I bought some "eraser" but have yet to try it cost was $50 for a 16oz, not sure what coverage is. 16 oz makes 25 gallons at 1% solution, the fricken instructions are so small i need cheaters for my cheaters to read it.
Toomanytools? is offline   Reply With Quote
Old 09-07-2012, 06:22 PM   #16
Senior Member
Outlawmws's Avatar
Bermuda is a tough job to eliminate, and spraying it once or even twice won't get it.
Spray the round up now and do the follow up as suggested, and yes, keep watering the dead lawn, and spray again. Next spring wait for the Bermuda to reappear, (it will) and spray it again. Once you are sure none of it is left, you can rototill and plant or re-sod. anything less and you can count on the Bermuda coming back again next spring everywhere is was. (And if you have lazy neighbors that don't keep theirs mowed so the seed heads are gone it will get blown in tracked in and re-establish itself again, and again, and again...)
I'm on my 4th attempt to get it gone from a section of my yard in 25 years; when we moved in it was ALL Bermuda, and I mean nearly every square inch of dirt on my 1/4" acre lot, PLUS the Parkways for my corner lot, near 200 ft long hell it was growing the in cracks between my front door walk and the foundation...
__________________
Outlaw's Camp Gear Thread
Outlaw's Shed Thread
Outlaw's Garage Sale
- For sale or trade... Last Update w/new items 8/21/2012 - P9, (More auto books)
Outlaw's Garage sale - Feedback
"It might be for sale or trade, it never hurts to ask..."
Outlawmws is offline   Reply With Quote
Old 09-07-2012, 06:55 PM   #17
digdug18
Senior Member
digdug18's Avatar
You'll do all that and end up with a product that you'll be unhappy with. Trust me, I've seen people that have tried to do short cuts in this area. You'll end up doing it over again in the next 5 years, do it once and do it right, you'll be happier afterwards.
Old 09-07-2012, 07:42 PM   #18
malibu101
Senior Member
malibu101's Avatar
Bermuda grass is some interesting stuff. http://en.wikipedia.org/wiki/Cynodon_dactylon
I've heard that "fall" is a good time to plant grass because there are less weed seeds blowing around in the air than in the spring. True?
Like my location says, I live in PA.
What do you think would happen if I were to scratch the grass out of my holes, dig up the ground (yard) a few inches, fill level with good ground, and plant grass seed this weekend?
Well, maybe a little less than even to allow for the thickness of the grass.
On that note- What about filling up the holes with ground and buying sod? I saw a local construction project where they just laid sod a week ago. Instant lawn but I see they have sprinklers running every time I go by.
The following question I'm sure is a whole 'nother discussion, but,---
Since Bermuda Grass is so "bad".
What type of grass would you recommend for my climate?
I am not looking for a golf course. I just don't want holes/depressions anymore.
EDIT- toomanytools?- You metioned aireating. I've seen aireating and overseeding help very well but that won't help my holes. Great advice!
Old 09-07-2012, 08:06 PM   #19
jal395
Senior Member
jal395's Avatar
I love my bermuda. I mow it short - one inch, spray for weeds and fertilize twice a year. Spot spray anything that the storms blow in. The heat cant kill it, the kids cant trample it. I say its perfect for me.
jal395 is offline   Reply With Quote
Old 09-07-2012, 09:00 PM   #20
fflintstone
Senior Member
fflintstone's Avatar
My yard is a mix of former cow pasture and forest. Every other year for the past 8 years I have been tilling the grass 3 or 4 times over the summer rather than mowing. My lawn has steadily but very slowly improved. The tilling has helped even it out but if I was really serious I would run a York rake over it.
I have access to a 3 point tiller so that is why I do it.
You can have a good lawn from seed if you have good soil. Unless you do sod your lawn will only be as good as your soil.
In your case I would vote for renting the bobcat. Machinery is fun to play with. I still enjoy most of the time I spend on my tractor.
fflintstone is offline   Reply With Quote
Old 09-07-2012, 09:52 PM   #21
Senior Member
Quote:
Okay Tom Sawyer, how much would you charge for a day of "mowing" your yard !
Us "suburbanites" never get a chance to handle anything more than a walk behind mower !!
Old 09-07-2012, 11:14 PM   #22
fflintstone
Senior Member
The tiller is not mine so I stick my neck out for $2000 everytime I till the church garden.
my C3500 GMC gets about 7-8 MPG towing the tractor and trailer. just to bring my tractor down to you would be $150-$200 in gas for the truck
Old 09-07-2012, 11:27 PM   #23
FleaDog
Senior Member
What square footage are we talking about?
A roller is good for frost heave but i think thats about it. it can cause compaction which isnt good for grass/soil (opposite of aeration).
i would rent a small skid steer or tractor for a day with a box rake or harley rake +/- having some topsoil delivered. I have a box rake for my graden tractor.
look at aroundtheyard.com
FleaDog is offline   Reply With Quote
Old 09-08-2012, 03:04 AM   #24
buzz4041
Senior Member
buzz4041's Avatar
I built a skid out of landscape timbers and put some cinder blocks on it for weight distribution on the rear. It had a edge out of 2x2x1/4" angle iron on the rear. I pulled it with my JD lawn tractor over my acre and did a good job. It was cheap to build. We got a few loads of fill dirt to add to the low spots. I didn't have any grass or anything at the time it was to get it ready for sod.
buzz4041 is offline   Reply With Quote
Old 09-08-2012, 10:03 AM   #25
Senior Member
2 or 3 passes and my lawn would be done !
I meant me coming up to your spread !
Got any other "construction equipment" to play with ?
Old 09-08-2012, 10:09 AM   #26
Senior Member
Where I live, most Humps/lumps/bumps and shallow areas are caused by frost heaves or roots !
Roll (compact) early in spring, after last frost. Aerate in early summer, once most of the moisture is out of the topsoil.
Anyone who lives in an area that gets heavy freeze and a lot of freeze/thaw cycles will have issues if they want a really flat, level lawn. Rolling and aeration every couple of years is your only solution.
Old 09-08-2012, 12:30 PM   #27
fflintstone
Senior Member
a very cheap and effective drag can be made out of an old box spring. Easiest is to burn the foam off and then throw some cement blocks on it for weigh and drag it around. If you canít get away with burning it just cut the foam and leave the wood. A twin size is good to tow behind a riding lawn tractor.
a box spring can be had for free in the dumpsters behind goodwill or in large apartment complexes.
Old 09-08-2012, 02:32 PM   #28
Kevin54
Senior Member
Kevin54's Avatar
I didn't read through everything, but a lot of the lumpiness is coming from worms. I don't know how the heck they can dig through that hard dirt but they can. This Fall when we get into more normal of weather, then roll it. Next Spring when the weather gets decent, roll it. Other than that, tear it out, rockhound it, and start from brand new.
Me....I have a roller ready to go.
Kevin54 is offline   Reply With Quote
Old 09-13-2012, 11:18 PM   #29
Shrimp92
Sand. It will work its way into the ground just smooth it out and wait.
Shrimp92 is offline   Reply With Quote
Old 09-15-2012, 02:59 PM   #30
BigSteve63
Senior Member
BigSteve63's Avatar
What is the HP of the tractor you are using? Any plans for the power rake you wouldn't mind sharing or letting me know where you got them?
BigSteve63 is offline   Reply With Quote
Old 04-22-2016, 10:41 PM   #31
Qryptix
Junior Member
From the perspective of just flattening your yard, all the suggestions above would work.
However, there is a major problem with using rollers to flatten your yard; compaction is really tough on plants. If you look where people walk a lot on lawns, you can see the effect that soil compaction has on grass; it just doesn't grow well. If you use rollers to compact the soil, you may have a difficult time keeping your lawn healthy afterwards.
From the perspective of a horticulturalist, the best move is to aerate with a hollow core aerator, power rake, then top dress low patches with about a 1/2 inch or 1 inch of compost. This keeps your soil healthy and should knock down your bumps over the course of a year or two.
Qryptix is offline   Reply With Quote
Old 04-22-2016, 11:18 PM   #32
James-W
Senior Member
A friend of mine had a rather "nasty" looking lawn, wasn't very flat in spots and the grass wasn't growing real well either. He tried several things, none of which worked to any great extent. Finally his wife got on his case and he hired a landscaper to come in and take care of it. The landscaper did quite a bit of work on the lawn, not just with the grass, he also planted some shrubs and made a little area for flowers to be planted. Not sure what my friend paid for it, I am certain it wasn't cheap, but it sure made a HUGE improvement on his yard.
I said all that to say this, sometimes it pays to just bite the bullet and let someone do the job that knows what needs to be done and how to do it.
James-W is offline   Reply With Quote
Old 04-23-2016, 06:26 AM   #33
TractorJeff
Senior Member
Roll it, worms will take care of soil compaction.
Adding dirt will change the elevation and slopes around your house. You want water to run away from your foundation.
TractorJeff is offline   Reply With Quote
Old 04-23-2016, 09:43 PM   #34
ishiboo
Senior Member
Nah, a ride-on roller + aerator is the way to go without ruining your lawn for a whole growing season or two, coupled with augmentation of the soil if applicable.
I just bought a 8' Harley Rake for my tractor... absolutely LOVE it for seedbed prep and it's amazing how fast/efficient it works, but if I can fix the lawn without tearing it down to dirt I'll take that option every time!
We get a lot of frost heave which causes lumpy yards up north, lawn rolling is just part of the fun.
I know this thread is 4 years old, still replying though.
__________________
2017 Denali 3500HD Duramax
2006 Pontiac GTO 6-speed
ishiboo is offline   Reply With Quote
Old 04-24-2016, 01:08 AM   #35
Cato
Senior Member
Cato's Avatar
My back yard was pretty "lumpy" when I bought the place. For years I've been adding soil here and there. The grass seems to have leveled it somewhat.
If I could do it again, I would dig out the sod, grade it properly, and put in St. Augustine.
Cato is offline   Reply With Quote
Old 04-24-2016, 08:27 AM   #36
Techie1961
Senior Member
Techie1961's Avatar
I have been following this thread and have the same problems but probably on a larger scale. I've had the place for 5 years and am still trying to figure it out. It's 3.25 acres.
I do the rolling thing every spring and don't worry to much about compaction since we have a high water table and the stuff grows too fast anyway. If I could slow it down a bit, that'd be great.
I built this rear blade for my tractor and since some had mentioned a drag, I figured I'd share my little design. I was thinking about the box spring as well and then saw these shelf pieces that I had extra of. They could be used independently of if you have a rear blade, use it like I did. I connected it to the blade where the skids are. Who knows, maybe it would work on the front also.
Techie1961 is offline   Reply With Quote
Old 04-24-2016, 08:39 AM   #37
toplessHO
Senior Member
a cheap drag can be made from a chain link fence gate
look for one on craigs list and add concrete blocks for ballast.
a roller will do no good if its not leveled out first.
Grass will grow thru 1 inch of topping but most likely not 3 inches.
If you dont want to reseed then do it in stages,which would take a couple seasons
toplessHO is offline   Reply With Quote
Old 04-24-2016, 01:32 PM   #38
D1005
D1005's Avatar
Depends on what you want. To me, a yard is something around the outside of the house. Not a carpet. Nor do I want a toxic superfund area from spraying all manner of chemicals on it.
Between frost, moles, and various other factors, no matter what I did to the earth, I'd be redoing it in a couple of years.
So I went a different way. I put bigger, fatter, softer tires on the tractor, which smoothed out the ride considerably. I've done this with a couple of different tractors at a couple of different houses. Works great!
__________________
Dale
Preserve the peace,
Do not disturb the peace.
D1005 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
