Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 10-23-2012, 08:50 PM   #1
pmilin
Senior Member
Default Epoxy floor using Sherwin Williams Tile-Clad
Hi all,
I am getting ready to coat my garage floor with Sherwin Williams Tile-Clad HS product. I thought I would chronicle my experience in case someone else is thinking about using this product. They have lots of color choices. I chose Rhombus.
pmilin is offline   Reply With Quote
Old 10-23-2012, 08:55 PM   #2
pmilin
Senior Member
Default Re: Epoxy floor using Sherwin Williams Tile-Clad
I choose to acid etch the floor. I have done this before with good results. I mixed 1 1/2 pt muriatic acid with 1 gallon of water and applied it to the floor with a flower sprinkler can. Wet the floor first.
I let the solution fizz for a few minutes then I scrubbed it with a stiff brush. I rinsed the floor several times afterward and squeegeed it dry. I tried using a mop to dry it but fibers from the mop were sticking to the roughened concrete.
I will have to wait a few days for it to dry.
Old 10-23-2012, 10:06 PM   #3
pmilin
Senior Member
Old 12-27-2012, 09:22 PM   #4
pmilin
Senior Member
I finally got the floor epoxied. I did it a while back but was having trouble posting pictures at the time so I am posting the pics now.
I used a lint free roller from Sherwin Williams.
I mixed the two part solution in a bucket and let it sweat in from 45 minutes or so. Sweat in time is important as it helps reduce bubbles. I then spread it out with the 18" roller cutting in with a brush as I went along.
I had to give it two coats as some areas etched more than others. The areas that etched more didn't cover as well.
I went with a solid color and color no chips. Tile Clad doesn't require a clear coat so the process was pretty easy.
I am now getting ready to paint the walls and ceiling.
Old 12-27-2012, 11:22 PM   #5
HotrodHR
Senior Member
HotrodHR's Avatar
Looks nice in pics... how about a close up. I guess it's too early to n]know how the finish will perform...
Costs and coverage info?
HotrodHR is offline   Reply With Quote
Old 12-29-2012, 10:32 AM   #6
SNOW JW
Did the same exact system in a 3bay car garage. Works well after 3 years it looks good.
Wished we would have done the chips though.
SNOW JW is offline   Reply With Quote
Old 12-30-2012, 11:58 PM   #7
bernialisha
Junior Member
bernialisha's Avatar
Wow, it is looking very nice and great, i heard that epoxy and concrete flooring are working good and it lives more number of years. Thanks for sharing such an useful information with us.
__________________
concrete coating
bernialisha is offline   Reply With Quote
Old 01-02-2013, 06:55 PM   #8
pmilin
Senior Member
As requested, here are a couple of close up pictures of the floor. It looks more orange peel than it really is. I chose to go with a smooth finish instead of the chips because I wanted a super smooth finish and because I thought the chips would make it hard to find dropped screws, etc. on the floor. Of course not having the chips doesn't hide the imperfections in the floor as well.
Some of the small imperfections and paint roller hairs will wear off.
Old 01-02-2013, 06:59 PM   #9
240zs30
Junior Member
Looks really nice. Can't wait to do something like this.
240zs30 is offline   Reply With Quote
Old 01-02-2013, 07:07 PM   #10
pmilin
Senior Member
So far the floor is holding up well. I have used this product before and it will dull down a bit with use, sunlight, and repeated cleaning, etc.
Coverage of this product is about 1 gallon of epoxy plus 1 gallon of hardener (2 gallons total) to cover approximately 500 sqft. It depends on how thick you want it.
When I did it I mixed more than needed so about a quart of the mix went to waste. To do the second coat I had to buy more product. I figured the second coat would cover more square footage so I adjusted the mix accordingly.
Old 01-02-2013, 10:50 PM   #11
4everRS
4everRS's Avatar
Thanks for documenting your story. I am casually shipping for an epoxy product and this one is on my list.
I will likely do chips and would like a clear coat. Will the SW product work well with a clear coat? And what is the general consensus on the best top coats?
4everRS is offline   Reply With Quote
Old 01-02-2013, 11:14 PM   #12
pmilin
Senior Member
I think you can use a top coat. Someone on here did that using this product. Do a search for tile clad or sherwin williams.
Here is a link about clear coating this product.
http://www.garagejournal.com/forum/s...ight=tile+clad
Here is another guy who top coated his:
http://www.garagejournal.com/forum/s...ad.php?t=73603
Old 01-04-2013, 06:11 PM   #13
munkey
Senior Member
http://www.garagejournal.com/forum/s...ad.php?t=73603[/QUOTE]
That's mine. I have done 3 floors this way with no issues; Tile Clad base coats with a topcoat of ArmorSeal Rexthane (a moisture cure urethane). It is stinky stuff and takes some skill to apply, but is extremely durable. I definitely recommend this system after seeing it in action for several years now.
munkey is offline   Reply With Quote
Old 09-24-2015, 03:50 PM   #14
jargirl561
Junior Member
What color did you paint the walls? I really like the color combo!
jargirl561 is offline   Reply With Quote
Old 09-24-2015, 03:51 PM   #15
jargirl561
Junior Member
I assume you went with the darker gray on the walls?
Old 09-24-2015, 05:17 PM   #16
GarageFlooringLLC
Alliance Member
GarageFlooringLLC's Avatar
as requested, here are a couple of close up pictures of the floor. It looks more orange peel than it really is. I chose to go with a smooth finish instead of the chips because i wanted a super smooth finish and because i thought the chips would make it hard to find dropped screws, etc. On the floor. Of course not having the chips doesn't hide the imperfections in the floor as well.
nice job!
GarageFlooringLLC is offline   Reply With Quote
Old 09-24-2015, 05:18 PM   #17
benwah
Senior Member
May I ask why you decided not to roll a coat of gray polyurethane over it?
benwah is offline   Reply With Quote
Old 09-24-2015, 06:38 PM   #18
12ozd
Senior Member
12ozd's Avatar
You guys know this is from Jan. 2013..right?
__________________
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
12ozd is offline   Reply With Quote
Old 09-24-2015, 07:19 PM   #19
benwah
Senior Member
Quote:
Well I do now!
Sent from my XT1254 using Tapatalk
Old 09-24-2015, 08:53 PM   #20
GarageFlooringLLC
Alliance Member
Lol somebody bumped it and I did not notice
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
