Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 10-24-2012, 02:57 PM   #1
glt29824
Junior Member
glt29824's Avatar
Default New Pole Barn - inside grade vs. outside grade + rat guard question
Hi all. New guy here. Proud new owner of my "hobby place".... 30x40x10 - yes only 10. We have a farm 15 miles away that we keep big stuff at that are 12' and 14' heights.
Getting right to it, I have a question in regards to the inside grade vs. the outside with the rat-guard that was used. As you can see by the pictures below, the inside will be considerably higher than the out. The outside piece TOP is under the rat guard trim. I would like to try and not cover any of the metal, but am wondering what options I have at the moment. Thanks in advance for any suggestions or input. All is welcome at this point.
Take care................Greg
glt29824 is offline   Reply With Quote
Old 10-24-2012, 08:46 PM   #2
trbomax
Senior Member
trbomax's Avatar
Default Re: New Pole Barn - inside grade vs. outside grade + rat guard question
There should have been 2 - 2 x 6 t&g treated skirt boards around the bottom . This would be a minimum IMO. I have 4 on mine,one below grade and 3 above grade. The outside sideing should be at least 6" above final grade ,again IMO. It looks like I can see right thru and under the skirt boards on the back and side. You cant pour concrete up against the exterior sideing (well,its your building,so I guess you can, but you shouldnt). I think what you have here is a giant CF due to improper planning. Nothing personal.
__________________
"If I live the life I'm given,I wont be scared to die." Seth & Scott Avett.
trbomax is offline   Reply With Quote
Old 10-25-2012, 01:27 PM   #3
glt29824
Junior Member
glt29824's Avatar
Thanks - figured those things but too late - was just excited I was getting it so quick...
Biggest problem with a CF however is that nobody ultimately wants to stand behind it and regardless if it was planned or not, that's where this ended today.
So the minimum fix is going to be to add the extra 2X6 under and on the outside just as the originial with a 2X4 1" over the seam to screed from inside. Excavate the exterior pads and there will be only a 1" height difference from interior to exterior that will blend well and reside under the rat-guard. That creates the problem of the overhead doors height so I've got a couple of good full sheets and will un-sheet the front, take out the corner reliefs, lower the top height accordingly, add to the sides with PT accordingly and then salvage what I can of the metal on it now, cutting new pieces to close it back in once done.
Final grade on the exterior was going to be taken down on the west end so that takes care of that.
Plan is 4000 psi with fiber, 2 inches of gravel compacted, termite treatment, 6ml vapor barrier and wire mesh on 2" chairs, metal key ways, wet cured for 7 days and then sealed with no traffic for a few weeks. That's it for now with Christmas coming on fast.
Take care.....Greg
Old 10-25-2012, 01:46 PM   #4
trbomax
Senior Member
trbomax's Avatar
That sounds like a good plan. No one will ever notice the difference in the front and if they do just tell themthey are looking too hard. Good luck with all that. I didnt mean to sound harsh,I just usually tell it like I see it! Post up your progress.
__________________
Old 10-25-2012, 02:05 PM   #5
glt29824
Junior Member
glt29824's Avatar
No worries brother. I'm ex-law enforcement and as blunt as they come... Will post as I work.
__________________
Take care............Greg
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
