Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 11-10-2012, 09:06 PM   #1
ex-x-fire
Senior Member
ex-x-fire's Avatar
Default Rebuildable casters on a floor jack?
New member here, nice place to talk about tools.
I picked up a Walker J-122 the other day, I started taking it apart to clean & paint it, I found one of the caster bearings stuck. I looks flattened, like it was dropped off of a truck or something.
The casters are the stem style & looks like they are pressed together & one end is mushroomed over to hold it together. My question is, has any one cut the head off & rebuild the bearings? I'm thinking if I could get the stem off I could drill & tap a hole for a bolt. The trick is removing only the mushroomed part of the stem.
ex-x-fire is offline   Reply With Quote
Old 11-10-2012, 09:12 PM   #2
Hiball
Senior Member
Hiball's Avatar
Default Re: Rebuildable casters on a floor jack?
It's just a matter of separating the upper and bottom race. If your caster was the stem type (threaded) that was secured with a nut, I'd say replace it. I'm sure yours is secured with a snap ring (top) and they are pricey, so yes you will need to grind off some of that staked portion.
There was another member who was trying to do the same thing, but a quick search l
Didn't show anything.
Can you simply use a chisel/hammer to allow free movement of the race/frame? Or is it missing balls?
__________________
Im Currently not taking any orders or shipping Kits/parts. It's always best to patronize local business's when possible, if not available there are numerous online suppliers. Below, you will find a phone number to HPS, Steve and His Wife are very knowledgable and very economically priced. .
Have a Hydraulic Jack Question? Check Here First..
Need a Seal Kit? Contact Hydraulic Parts Supply at 620-594-2247
BRC 6/9/22 - 3/5/12 My Best Friend and the Greatest Man i ever Knew RIP...
Hiball is offline   Reply With Quote
Old 11-10-2012, 11:22 PM   #3
ex-x-fire
Senior Member
ex-x-fire's Avatar
The stem on the casters has the groove style, I'm wondering if I could just put bolt on casters on it.
Old 11-11-2012, 05:50 AM   #4
Hiball
Senior Member
Hiball's Avatar
The bolt on ones won't work on that frame style, here is what they look like.
Maybe a picture of the damage?
__________________
Old 11-11-2012, 08:50 AM   #5
ex-x-fire
Senior Member
ex-x-fire's Avatar
The shells are really flat, I can't even see any bearings.
Old 11-20-2012, 07:28 PM   #6
ex-x-fire
Senior Member
ex-x-fire's Avatar
Well, I cut the staked part of the stem, I had to use a press to get everything serperated. The shells looked in good shape & no missing bearings. Half of the bearings ride in the top (in a C shaped bearing retainer of the caster body) & the lower holds an equal no. of bearings. Thats probably why the bearing looks alittle tilted.
I cleaned & blasted all the parts, lubed the bearings & tapped it back together, it seems to be alot better. I weld alittle bead to keep it together.
The real test will be after I put a load on it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
