Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Search this Thread Display Modes
Old 11-28-2012, 10:47 AM   #1
cowboy73
Senior Member
cowboy73's Avatar
Default Repointing mortar joints concrete block?
The wife seen a mouse in the kitchen last night So after setting traps, I started looking around the outside of the house for possible entry points. I have a few spots in the concrete block foundation where the mortar is gone or loose. The house was built in the early 1920s. Would you guys just use regular mortar mix? I know I should dampen the blocks to keep the mortar from drying out too fast. Would you use a concrete binding agent to improve the mortar sticking? Would hydraulic cement be a better option since it expands slightly? Any advice would be appreciated.
Tom
cowboy73 is offline   Reply With Quote
Old 11-28-2012, 10:49 AM   #2
rlitman
Senior Member
Default Re: Repointing mortar joints concrete block?
You want the mortar to be softer than the brick, or it can cause the brick to crack.
So, NO to concrete, and NO to hydraulic cement.
rlitman is offline   Reply With Quote
Old 11-28-2012, 10:53 AM   #3
cowboy73
Senior Member
cowboy73's Avatar
Thanks. I was wondering about that. Is the premix stuff in a bag okay for the patch job?
Old 11-28-2012, 11:02 AM   #4
geologist
Senior Member
geologist's Avatar
Quote:
I've used it without any troubles on my grandmother's house a couple of years ago. Seems to have held up pretty well. Just be careful when you mix it so that you get it wet enough.
__________________
Speak the truth, even if your voice shakes.
Plumbers and Pipefitters Local 577 - Portsmouth, Ohio
geologist is offline   Reply With Quote
Old 11-28-2012, 11:33 AM   #5
rlitman
Senior Member
The premix mortar in the bag will have a letter code.
The code designates the strength of the mortar, with N being in the middle of the range, and that is probably what you want (unless you have really old and soft bricks).
Usually N is the regular stuff, so yeah, that's what you probably want.
Old 11-28-2012, 12:01 PM   #6
geologist
Senior Member
geologist's Avatar
I think the old timers used more of a lime base for their mortar. I looked at a house from the 1820s that had been partly repointed with modern mortar, and it's basically ruined about 1/3rd of the bricks. If your house was built after 1900, you should be fine.
__________________
Old 11-28-2012, 12:06 PM   #7
STINEY
Senior Member
STINEY's Avatar
Quote:
Originally Posted by geologist View Post
. I looked at a house from the 1820s that had been partly repointed with modern mortar, and it's basically ruined about 1/3rd of the bricks. .
I will be repointing my 1850's house brick foundation in the near future...... what sort of damage did you observe? My bricks are definitely the softer variety.
STINEY is offline   Reply With Quote
Old 11-28-2012, 12:20 PM   #8
bczygan
Senior Member
bczygan's Avatar
The mortar gets it's waterproof qualities, not by it's hardness, but rather, by compression of the mortar surface by striking off the joints with a jointing tool. Start by removing loose mortar by mechanical means including sawing as necessary. Choose a local sand to try to match the existing mortar color and recipe.
bczygan is offline   Reply With Quote
Old 11-28-2012, 01:16 PM   #9
JF5000
Senior Member
JF5000's Avatar
Quote:
Yeah STINEY, I would do some serious research before making a move. Dang 1/3 of the bricks destroyed! That sucks.
__________________
James
"Why, Johnny Ringo! You look like somebody just walked over your grave."
All American
JF5000 is offline   Reply With Quote
Old 11-28-2012, 01:23 PM   #10
TAMPAGT07
Senior Member
TAMPAGT07's Avatar
Did you catch the mouse?
__________________
This posting is copyrighted by TAMPAGT07 for the private use of our audience. Any other use of this posting or any pictures, descriptions, or accounts of the posting without TAMPAGT07's consent is prohibited. (This mesage was bought to you by TAMPAGT07''s legal team, the three Robinowitz's)
TAMPAGT07 is offline   Reply With Quote
Old 11-28-2012, 01:34 PM   #11
geologist
Senior Member
geologist's Avatar
Between the end of the Civil War and roughly 1900, brick "technology" advanaced, so that they were relatively hard throughout. Before this time, the face or "outer crust" (if you will) was hard, but the interior wasn't nearly as strong, so if you chipped the face, it would start to degrade the brick.
Save yourself a lot of hassle and heartbreak, and read this:
http://www.nps.gov/hps/tps/briefs/brief02.htm
So, what happens is that water gets into the brick, and the clays expand and crack it worse, and then once you loose that protective outer shell, the brick more or less begins to disintegrate. Using modern mortar can speed this process up, so generally when you're restoring an old brick home, it's best to use a lime mix (still obtainable). Otherwise, you get this:
__________________
Old 11-28-2012, 02:27 PM   #12
kartracer23
Senior Member
kartracer23's Avatar
While I agree that that mortar is important on brick, I don't know that it's super important (or as important) on concrete block. I think everyone missed that that was the OP's question. Concrete block vs. brick is a totally different animal.
I just did a basement foundation wall with hydraulic cement and am not concerned at all about it damaging the block.
I'm on our local historic commission & we bring in experts at times to test the mortar to make sure we're using the right mortar for the old bricks in different buildings. A lot of masons will just slap whatever they have in the truck in there, not realizing how much damage they cause.
kartracer23 is offline   Reply With Quote
Old 11-28-2012, 02:40 PM   #13
STINEY
Senior Member
STINEY's Avatar
Eeww.
Unfortunately, it would appear mine are in the early stages of that state of demise. Not quite that bad, but in the same ballpark.
Thanks for the info!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
