Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 12-06-2012, 11:10 AM   #1
burgie
Senior Member
burgie's Avatar
Default Removing rust in air compressor tanks??
Greetings...
OK...so I bought a used Saylor-Beall compressor (80 gallon vertical tank, 2HP motor w/ Model 703 pump) from Craigslist. After removing all the plugs, including the 2-1/2" one close to the bottom, I inspected the inside of the tank (what I could see anyhow) and it looked pretty good. The tank is strong and solid and holds pressure perfectly.
However, it got me thinking about a rust removal liquid of some sort that I could pour in the tank and let sit for a period of time to clean up (dissolve) some of the light scale rust on the bottom of the tank? (Being a vertical tank only that bottom 3" - 4" has some light scale...the sides look great...).
I have heard about muratic acid, vinegar, a product called "Evapo-Rust", etc...but have no experience using any or these.
Any suggestions?
(PS...I am not looking for a rust converter like POR-15 or other similar product...just something I could pour in, let it do it's magic and then drain).
Thanks much...
Burgie
__________________
Bob "Burgie" Burgoyne
My woodworking site: http://www.creativelandscapeaccents.com
1964 Chevy C60: http://www.chevyc60.com/
burgie is offline   Reply With Quote
Old 12-06-2012, 11:17 AM   #2
chris fresh
Senior Member
chris fresh's Avatar
Default Re: Removing rust in air compressor tanks??
goe to lowes or depo and buy about 4 bottles of jasco rust converter,comes in a white bottle with red and blue lettering,works great.then drain it,gonna be fun rolling that tank around.
__________________
my snap-on resto ............http://www.garagejournal.com/forum/s...d.php?t=117739
my clausing dp resto...................http://www.garagejournal.com/forum/s...d.php?t=125051
my yost holland 33c resto.............http://www.garagejournal.com/forum/s...d.php?t=164585
my blast cabinet build..........http://garagejournal.com/forum/showthread.php?t=237444
chris fresh is offline   Reply With Quote
Old 12-06-2012, 11:33 AM   #3
pipsters
Senior Member
Most rust converters contain the same type of phosphoric acid in them. The biggest problem you will have is the scale part of the rust needs to be wire brushed away in order for it to be the most effective. You want something that will convert the rust to a black material.
pipsters is offline   Reply With Quote
Old 12-06-2012, 11:50 AM   #4
ndoran
Senior Member
the biggest problem you will have with anything that contains an acid is that you will not be able to fully remove it thus ensuring that when you begin using the compressor you will also produce a fine mist of acid fumes from the exhaust of any tools you use. Not good for the tools not good for your lungs or eyes and not good for anything else. Note you need cartridges rated for "acids" in respirators the regular cartridge will not protect you
ndoran is offline   Reply With Quote
Old 12-06-2012, 08:11 PM   #5
BMB
Senior Member
I've heard of people putting a length of heavy chain in the compressor tank and rolling it around to knock off the scale.
BMB is offline   Reply With Quote
Old 12-06-2012, 08:50 PM   #6
pipsters
Senior Member
Quote:
Have you ever used phosphoric acid to neutralize rust? I disagree with your assessment. It will dry completely and evaporate leaving only the converted rust behind.
Not to mention phosphoric acid is in Coca-Cola...it's not really that harmful...heck you could always just pour Coke down into your compressor...
Old 12-06-2012, 09:04 PM   #7
dumper
Senior Member
Not to mention phosphoric acid is in Coca-Cola...it's not really that harmful...heck you could always just pour Coke down into your compressor...[/QUOTE]
thats not a half-bad idea- the Coca Cola, that is. I sure many of us remember that experiment way back in grade school, where we put a tooth in a bottle of coke, came back in a day, and the tooth was gone! Dissolved.
dumper is offline   Reply With Quote
Old 12-06-2012, 09:09 PM   #8
thebeekeeper1
Senior Member
thebeekeeper1's Avatar
Evapo-Rust has no acid and works very well.
thebeekeeper1 is offline   Reply With Quote
Old 12-06-2012, 10:46 PM   #9
Steevo
Senior Member
Steevo's Avatar
Put a couple of hundred 1" ball bearings in it, put the plugs back in, and pick it up and shake it really hard for 20 minutes or so.
Or not . . .
__________________
My Workbench Build Thread
My Idaho Shop Build Thread
"I'd rather laugh with the sinners than cry with the saints, the sinners are much more fun" - Billy Joel
Steevo is offline   Reply With Quote
Old 12-06-2012, 11:43 PM   #10
RivennHewn
Senior Member
RivennHewn's Avatar
Quote:
Or not . . .
Or not....
RivennHewn is online now   Reply With Quote
Old 12-07-2012, 01:21 AM   #11
Danglerb
Senior Member
Danglerb's Avatar
A handful of small ball bearings and long narrow enough piece of tubing to reach in and give some air pressure to stir them up might take the surface rust off. Maybe get all that out, blow out as much debris as you can, then a dose of evaporust.
Once thats done what would you put in to prevent rust? Rustoleum paint?
Danglerb is offline   Reply With Quote
Old 12-07-2012, 04:35 AM   #12
chris fresh
Senior Member
or,you might want to look into a gas tank repair kit,they make them for motor cycle tanks and it has everything you need to solve the entire problem.preps the inside,and coats the inside.no more rust ever.
__________________
Old 12-07-2012, 04:36 AM   #13
chris fresh
Senior Member
bag of pea gravel from home depo will work great also,has sharp/rough edges and it's cheap.
__________________
Old 12-07-2012, 06:34 AM   #14
Geurt
Senior Member
Geurt's Avatar
You could also use electrolysis.
Geurt is offline   Reply With Quote
Old 12-07-2012, 02:14 PM   #15
ford67guy
Junior Member
I'm interested to see how others have tried to fix rust inside a compressor as well. I also picked up a compressor from CL and it works fine, but if I can somehow slow down the rust inside, that would be awesome.
I've used phosphoric acid from home depot and it works great, but how are you going to rinse it out? if it stays in the compressor, I think it would eat away the metal over time?
ford67guy is offline   Reply With Quote
Old 12-07-2012, 08:12 PM   #16
jhelrey
Senior Member
or just leave it...
jhelrey is offline   Reply With Quote
Old 12-07-2012, 08:22 PM   #17
PT Doc
Senior Member
PT Doc's Avatar
Quote:
Originally Posted by jhelrey View Post
or just leave it...
That.
PT Doc is offline   Reply With Quote
Old 12-07-2012, 08:22 PM   #18
Davefr
Senior Member
Davefr's Avatar
Or not . . .
Good idea, wrong product. Use drywall screws. They're cheap and extremely sharp.
Davefr is offline   Reply With Quote
Old 12-07-2012, 08:34 PM   #19
fordbroncodave
Senior Member
fordbroncodave's Avatar
if you have the big plug off the side of it, just use a garden hose and a sprayer and spray it with the most penetrating spray position. what falls off will come out the bottom drain and what stays is solid enough to pour a hardener over.
if I have my way, pour like a few gallons of motor oil in the bottom of the tank and let it sit for a few days and drain it. debris will come out with it and the motor oil that stays in is a natural water repellent. water will not interfere with the metal because of the oil coating
__________________
with a putt putt here, a putt putt there, hear a putt theres a putt, everywheres a putt putt... a john deere farms this land E I E I OH
my needs list:
http://garagejournal.com/forum/showt...fordbroncodave
fordbroncodave is offline   Reply With Quote
Old 12-08-2012, 02:27 AM   #20
ford67guy
Junior Member
hey fordbronco - I have a plug on the side. What's the easiest way to break those open? They are pretty tight. I've tried with a breaker bar and long bar at the end and couldn't break it lose.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
