Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Search this Thread Display Modes
Old 12-08-2012, 10:34 PM   #1
jhelrey
Senior Member
jhelrey's Avatar
Default 2001 Honda Civic Front End Clunk
I replaced the following because they needed to be. IE: Ripped bushings, leaks, etc.
Both lower control arms and bushings
Lower ball joints
Complete front struts
Wheels all rebalanced
Wheel bearings
Sway bar link ends
Still got a clunk
jhelrey is offline   Reply With Quote
Old 12-08-2012, 10:36 PM   #2
Toolhorder
Senior Member
Toolhorder's Avatar
Default Re: 2001 Honda Civic Front End Clunk
Lower ball joints
Wheel bearings
Sway bar link ends
Still got a clunk
Did you use Honda OEM parts?
Toolhorder is offline   Reply With Quote
Old 12-08-2012, 10:37 PM   #3
SKAutomotive
Senior Member
Sway bar bushings. That's my blind guess. Get a pry bar and see if you can slide that sway bar back and forth.
SKAutomotive is offline   Reply With Quote
Old 12-08-2012, 11:01 PM   #4
jhelrey
Senior Member
jhelrey's Avatar
Quote:
No, clunk has always been there. Car lived its life on gravel until I bought it.
Old 12-08-2012, 11:01 PM   #5
jhelrey
Senior Member
jhelrey's Avatar
Quote:
Going to toss it on the lift tomorrow and go through it again
Old 12-08-2012, 11:23 PM   #6
Garage5.9
Senior Member
Garage5.9's Avatar
When is the clunk clunking ?
Garage5.9 is offline   Reply With Quote
Old 12-09-2012, 07:38 AM   #7
Big-Foot
Senior Member
Big-Foot's Avatar
Strut bearings buried up in the strut tower. Unless you buy the high end aftermarket strut kits or OEM, they typically don't come with them...
__________________
Regards - Randy
http://www.GT-Forty.com
Big-Foot is offline   Reply With Quote
Old 12-09-2012, 07:46 AM   #8
aussiek2000
Senior Member
aussiek2000's Avatar
Under what conditions does it clunk. Motor/trans mount comes to mind.
aussiek2000 is offline   Reply With Quote
Old 12-09-2012, 08:04 AM   #9
checkthisout
Senior Member
Geez.
Tie-Rod ends (inner or outer either side, "nibble" steering wheel back and forth while listening for clunk, if clunk is heard place your hand on the tie-rod while assistant continues "nibbling" steering wheel ), the sway bar bushings themselves (put your hand on the swaybar while somebody rocks the vehicle side to side).
Both these assume your new stuff is good and that your fasteners are tight.
A better description of the noise and conditions would help us help you.
checkthisout is offline   Reply With Quote
Old 12-09-2012, 08:17 AM   #10
jhelrey
Senior Member
jhelrey's Avatar
Quote:
Over bumps at all speeds... More noticeable at slow speeds though. Def. from right front side. I'll try to update more today after it's been on the lift. I've maintained this car since new and all of the above parts were installed before I bought it. The front struts I just did because I pulled the bearing plate off, and I could compress the strut with my hands and it wouldn't come out like it should have
Old 12-09-2012, 08:17 AM   #11
jhelrey
Senior Member
jhelrey's Avatar
Quote:
Monroe Quick Struts
Old 12-09-2012, 08:31 AM   #12
Big-Foot
Senior Member
Big-Foot's Avatar
Monroe Quick Struts
I have used those before and I know that they have a couple of variations. Did yours come with the bearing and mount? That's the part that actually bolts to the sheetmetal in the strut tower.
The only other thing I can think of is if your engine cradle (lower control arms are bolted to it in many typical cases) is tight. Also check that your steering rack is tight and that the bushings are not cracked, worn or oil soaked..
I have a set of Monroe quick struts here now for the wife's PT Cruiser and they have the bearings.
__________________
Regards - Randy
Old 12-09-2012, 08:31 AM   #13
2Big2Ride
Senior Member
2Big2Ride's Avatar
Had one of those clunks a long time ago on a front wheel drive car that was not obvious, it was an inner tie rod joint. Slow speed, not at high speed, especially if the road surface wasn't smooth.
2Big2Ride is offline   Reply With Quote
Old 12-09-2012, 08:42 AM   #14
jhelrey
Senior Member
jhelrey's Avatar
Yes, came complete! I actually thought of the engine cradle, etc. My buddy is a mechanic as well as I am a very part time one. We both had it on the lift and found a clunk in the rear. Drive on lift with the rear of car lift via pinch welds. Def. get a clunk with a pry bar under driver rear wheel. Problem is with the unibody, it echos so we could not isolate the noise.
Old 12-09-2012, 08:43 AM   #15
jhelrey
Senior Member
jhelrey's Avatar
Quote:
My tires are tight. No up down wobble or side to side.
Old 12-09-2012, 08:53 AM   #16
Big-Foot
Senior Member
Big-Foot's Avatar
Sounds like you should have nailed the strut issue...
Double check the torque strap/bone from the engine to the core support area. Sometimes these things can be real bastards to find as you well know...
You'll need a few beers to get into the right frame of mind to do this but ----- check on a couple of the Honda Civic forums to see if anyone else has had this problem and if they found the solution...
Of course most those guys would just crank up the wattage to their sub-woofers and the clunk would go away!
__________________
Regards - Randy
Old 12-09-2012, 09:01 AM   #17
crankshaftdan II
Senior Member
crankshaftdan II's Avatar
Send a message via Yahoo to crankshaftdan II
I had a simular problem with a 01 corolla-mine was the sway bar links and only at 35 mph or less. Look for bare metal marks on the sway bar where you have a radius in the bar and it makes contact with the suspension. Mine was very small and a bright light(LED) shinning on the black/rusty parts made it stand out. Mine would rattle every time I would roll over a crack in the asphalt or joints in the concrete!
__________________
Swap/Trade/Buy/Sell/Use Tools.
Currently looking for USA made ratchets-any drive size-nice condition without owner's marks.
Also looking for ANY s-k Superkrome wrenches-sets-individual pieces in new/like new condition withOUT owner's marks.
I prefer to swap rather than purchase-will purchase if necessary. Contact me if you prefer by e-mail @
dhdslimbow@yahoo.com
crankshaftdan II is offline   Reply With Quote
Old 12-09-2012, 09:01 AM   #18
jhelrey
Senior Member
jhelrey's Avatar
LOL Big... been there already. Only thing I haven't checked is axle play. Some are saying that is the root of their problem.
Old 12-09-2012, 09:37 AM   #19
Hghgrad
Senior Member
Have you checked the lower control arm bushings?
The rear lower control arm bushings tend to wear out.
Hghgrad is offline   Reply With Quote
Old 12-09-2012, 10:15 AM   #20
SKAutomotive
Senior Member
Lower ball joints
Wheel bearings
Sway bar link ends
Still got a clunk
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
