Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 12-10-2012, 03:56 PM   #1
OldNeons
Senior Member
Default Best Portable 220 volt electric Space Heater Choice?
Looking for input here please: I have a portable electric Dayton space heater 3uv36. Brand new, plugged it into 220 cable for my table saw and I got more heat out of a $20 110volt under desk heater??? Are these things really worthless or what gives? Normally Grainger sells decent stuff - but this thing was almost $200 and I think I'm breathing hotter air. It is attempting to make heat (not blowing cold air), but it is nowhere near 5000 watts or 14,000 btuH that is advertised??
Any suggestions on fixing this - or an alternative?
I want something portable/temporary- not a permanent install. It will get me through next few weeks until my permanent furnace is installed in the shop and then I'll use it on jobsites when needed.
Thanks for any input
OldNeons is offline   Reply With Quote
Old 12-10-2012, 04:15 PM   #2
pattenp
Senior Member
pattenp's Avatar
Default Re: Best Portable 220 volt electric Space Heater Choice?
Obviously something is wrong. I have a similar heater and it blows heat like crazy. Are you sure you're supplying the correct voltage to it? Heater may be defective.
Have you re-corded or re-plugged the heater? That heater needs a 30A circuit.
pattenp is offline   Reply With Quote
Old 12-10-2012, 04:25 PM   #3
OldNeons
Senior Member
thanks for reply, factory cord with NEMA 6-30P hooked up to a 10 gauge cord tied into 30 amp 220 volt breaker (single phase of course). Also tried it at my dad's house with same results. Pretty simple system - bad element?
Old 12-10-2012, 04:38 PM   #4
TireTracks
Senior Member
TireTracks's Avatar
Does it have 2 heat ranges? The 50 year old one I use has 2 settings, and the lower one doesnt do anything.
__________________
Lover of old tools, stationary, power and hand.
Quote:
Originally Posted by Lotek View Post
You missed the important part "antique", dried out seals and leathers, operator unfamiliar with operation, little voice in my head keeps saying "Darwin":shocking:
TireTracks is offline   Reply With Quote
Old 12-10-2012, 06:01 PM   #5
malibu101
Senior Member
malibu101's Avatar
You said 3uv36. Are you sure it's not an 3VU36? That's what I have.
Mine says 5600-4200 watts - 240-208 volts - 23-20.3 amps.
I figured those specs should be close to what a dryer takes, therfore, give out as much heat as a dryer.
Mine blows a warm breeze but is FAR from a powerful heater. I say it does not even give out as much heat as a dryer does.
A well insulated garage on a mild evening and it should be noticeable.
A cold, windy night in a cold garage and this is just a tease. It will not heat the space too much if even noticeable at all.
I've had mine a few years and it still works as well as it does.
I bet if you look at the specs at Grainger the reccommended square footage it is designed for is way less than a garage.
malibu101 is offline   Reply With Quote
Old 12-10-2012, 06:54 PM   #6
Highbeam
Senior Member
Can't compare to a clothes dryer because a clothes dryer is burning up lots of heat evaporating the water into steam. Between the dryer and the outlet is a huge heat exchanger, tumbling wet clothes, sucking up the energy to boil water and to heat up the cold clothes.
The same wattage into a dry space heater should make way more heated air than a dryer does.
Highbeam is offline   Reply With Quote
Old 12-10-2012, 07:54 PM   #7
LG63
Senior Member
I have a very similar one sold under the TPI name and thought the same thing the first time I fired it up. I think the fan is simply too powerful for the temp rise that the heater produces. If the air wasn't moving as fast, I think it would "feel" better. It's not intended to heat a very big space but it you're willing to give it time, it will eventually warm up a 20 x 20 area provided you don't have major air leaks. I actually prefer radiant heaters since they heat objects not the air.
LG63 is offline   Reply With Quote
Old 12-11-2012, 08:32 AM   #8
5lima30
Senior Member
5lima30's Avatar
I have the red square construction heater from Northern Tool. It is 4800 watts and 13,200 BTU. It has the 6-30p plug. I paid $79 for it on sale. It works fairly well although the fan is somewhat loud to me. It does a decent job of heating my 16x28 garage that is well insulated.
__________________
Retired Police Lieutenant, Retired USAF Res, Glock Armorer
"I can do all things through Christ who strengthens me" Phil 4-13.
5lima30 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
