Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 12-15-2012, 03:14 PM   #1
xxtreem11
Junior Member
Default Restoring a Craftsman 113.27520 10" table saw
Hey all...
I picked up this saw from Craigslist for $75 bucks. It looked to be in good shape and had both extension wings, full fence and the original motor so I jusmped on it. Now here comes the teardown of this bugger. Damn this thing is he-e-e-e-e-avy. but there's nothing a little muscle and WD-40 can't solve.
xxtreem11 is offline   Reply With Quote
Old 12-15-2012, 04:10 PM   #2
billp603
Senior Member
billp603's Avatar
Default Re: Restoring a Craftsman 113.27520 10" table saw
Heavy is good! What's the piece of plywood inside? I If it's fixing something broken I'd get the correct machined part to go in there.
One trick I have used to clean up and polish the machine surfaces on saw tables is to put a scotchbrite pad under a 1/4 palm sander with some WD-40 or Boeshield T-9.
billp603 is offline   Reply With Quote
Old 12-15-2012, 04:40 PM   #3
Senior Member
Outlawmws's Avatar
Nice find! But that motor appears to need to be moved up on the mounting plate a bit so the belt does not rub...
__________________
-Outlaw
NINE's (Nine4GMC) Flood recovery thread: Please help if you can; at least give him and his some moral support!
Outlaw's Camp Gear Thread
Outlaw's Shed Thread
Outlaw's Garage Sale
- For sale or trade... Last Update w/new items 8/21/2012 - P9, (More auto books)
Outlaw's Garage sale - Feedback
"It might be for sale or trade, it never hurts to ask..."
Outlawmws is offline   Reply With Quote
Old 12-15-2012, 05:16 PM   #4
xxtreem11
Junior Member
Thanks! The piece of plywood is a makeshift dust collection system. Not too shabby, but I might try something else. The motor needs a "little" adjustment. The belt may be a little long... or the motor mount needs moved back... or the motor need adjusted higher... or....
I've started tearing it apart. The arbor and blade adjustments were binding a little and the blade was spinning, but not very freely. Hitting all the bolts with some WD-40 made the tear down very easy.
First decision. It looks like the arbor bearings need replacing. They're smooth, but not smooth enough. So the question is... Sears still has the one bearing and the arbor with the bearing. Do I buy them from sears or go with a better bearing (Accurate) and have the one pressed onto the arbor. Decisions, decisions.
Motor teardown is next. If the motor needs bearings too, then I'd rather get them all at the same time.
Old 12-15-2012, 05:22 PM   #5
Packard V8
Senior Member
Those are great old saws. I've owned several and have two in storage at present. Clean it up, fix what it needs and use it. Just don't put much money in it. You'll have difficulty getting more than your $75 back if you try to sell it. Hard to find a better user saw at that price, but they're thick on the ground and don't bring many offers on craigslist. There are at least a dozen for sale here today.
jack vines
Packard V8 is online now   Reply With Quote
Old 12-16-2012, 10:53 PM   #6
xxtreem11
Junior Member
Got everything torn apart now. Got my list for Accurate bearings. I need 2 6202LL 5/8 bearings for the arbor shaft and 2 6303 double sealed bearings for the motor shaft.
Now to start tearing down the rest of this so that I can take a wire wheel to the steel, give all the rusted stuff an electrolysis bath and degrease the rest of the innards.
Here's a question for all you seasoned garage guys and restorers.... the Craftsman logo plate on the front of the saw is riveted on. Same with the spec plate on the the motor. What's the best way to take them off and put them back on when I'm done?
Old 12-16-2012, 11:27 PM   #7
justanengineer
Senior Member
justanengineer's Avatar
Location: Amongst the DEEP snow in the north country of northern NY...
Masking tape, unless you think someone's going to look underneath them.
I have that exact same saw and love it. Best $25 Ive ever spent. I bought its lil brother recently for $15 w/perfect paint to rob the motor for a Cman jointer Im currently restoring. Those saws are no Unisaw, but miles ahead of a box store aluminum saw.
__________________
"I am, and ever will be, a white-socks, pocket-protector, nerdy engineer -- born under the second law of thermodynamics, steeped in the steam tables, in love with free-body diagrams, transformed by Laplace, and propelled by compressible flow." - Neil Armstrong RIP
justanengineer is offline   Reply With Quote
Old 12-16-2012, 11:54 PM   #8
Senior Member
Outlawmws's Avatar
It might be a rivet, or it might be one of those rivet "screws" that can be tapped out from the back side. check yours. If it is a real rivet, those are hard to come by in those sizes, and I usually mask them off. and strip and paint.
__________________
-Outlaw
Old 12-18-2012, 07:34 PM   #9
xxtreem11
Junior Member
well... i did the ole "dremel a slot in them and screw them out" routine. They're U Drive screws. I'll have to pick some up. Hopefully the local Home Despot has some.
Old 12-18-2012, 08:11 PM   #10
Packard V8
Senior Member
Yes, Accurate Bearing is a great go-to.
No, the bearings in the Craftsman are nothing special. Any local bearing house should have them by the boxful. Save yourself the shipping and pick up an AX series belt for the saw while you're there.
jack vines
Old 12-19-2012, 11:37 PM   #11
xxtreem11
Junior Member
So I put the arbor end of the assembly into the hot soapy bat and let it sit for a day. Then started scotch briting and brushing the snot out of it. I didn't want to repaint it. Adding a little WD-40 and it came out pretty good, even if I do say so myself. Now I only wish that I had a larger tub than this 5 gallon one so I can do some multiple parts at a time. It's definitely going to make spooge-bathing the top and wings interesting.
Before:
After:
Old 01-02-2013, 10:03 AM   #12
xxtreem11
Junior Member
So, now that I'm back from loading up the 'ole 4WD sleigh and carting the family across a few states to see the inlaws, it's time to continue our regularly scheduled restoration.
So, I'm trying the old soak rusted bolts in vinegar trick to see if the rust will come off enough to wipe off. I also got a wire wheel for my grinder to get the remainder off and polish them up. I was going to give all the bolts an electrolysis bath, but did not see a way to keep them all together and tied electrically. After I get the bolts all clean, I'm going to spray them with some clear coat.
I still need to spooge the arbor tilt and height adjustment shafts and the top and extension wings, and I think I'm going to use aircraft remover to get the paint off the base, motor housing and bell ends. Then wipe them with some naptha and shoot some color.
Old 01-30-2013, 05:53 PM   #13
tinkergeek
Senior Member
The large black plastic mixing pans for concrete may give you the space you want. Or for that matter, a large sturdy box of the right size lined with heavy plastic may make it possible to immerse the entire top.
tinkergeek is offline   Reply With Quote
Old 01-30-2013, 11:41 PM   #14
Senior Member
Outlawmws's Avatar
Quote:
The larger size should do the trick for an Ebath for the table. use a grid of rebar on the bottom, a couple of bricks to hold the table off the bottom, and another brick or two outside the table for supporting a top grid and fire it off.
If the tubs aren't large enough one of those cheap kids wading pools will also do the trick
__________________
-Outlaw
Old 08-15-2014, 12:39 PM   #15
Dave Norton
Junior Member
I just acquired one of these saws. It seems to be in fair condition except that the swinging plate that the motor sits on is broken. It is cast iron, and I need help finding a replacement. Tried to find a local welder, but, since it is cast, he wanted $100 minimum fee to weld it.
Dave Norton is offline   Reply With Quote
Old 08-15-2014, 03:11 PM   #16
Senior Member
Outlawmws's Avatar
Try Eprey for the motor plate if no one here has one. These get parted all the time.
__________________
-Outlaw
Old 08-15-2014, 04:12 PM   #17
bisley45
Senior Member
bisley45's Avatar
Nice saw you have there I have on just like it that I did a restore on some time back you will love it. Here is a pic of mine all cleaned up.
bisley45 is offline   Reply With Quote
Old 08-15-2014, 04:46 PM   #18
gus1962
Senior Member
Bisley45 , that's a well restored table saw. How is it performing? I wish I'd find a sweet machine on CL someday. I've been waiting for a good one to come out in my area.
gus1962 is offline   Reply With Quote
Old 08-15-2014, 06:07 PM   #19
ozyborn
Senior Member
The twist link belts from Harbor Freight seem to hold up well. I hate to use anything from there but the belts are nice
I have rebuilt several of these. I seem to collect them
ozyborn is online now   Reply With Quote
Old 08-17-2014, 04:02 PM   #20
s2kattracks
Senior Member
Ditto, I am using a belt from there as well and its holding up fine.
s2kattracks is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
