Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 01-12-2013, 05:23 PM   #1
red73mustang
Senior Member
Default Genie Garage door opener no power
My Genie Intellicode chain drive H2000C garage door open just went dead. I confirmed that the outlet it was plugged to is still live with a voltage sensor.
Is there a reset button on these? I noticed right before it died that the plug was partilly out so maybe a circut breaker tripped on it (I hope?)
Thanks, Chet
red73mustang is offline   Reply With Quote
Old 01-12-2013, 05:32 PM   #2
Gary S
Senior Member
Default Re: Genie Garage door opener no power
Have you read the manual?
Gary S is offline   Reply With Quote
Old 01-12-2013, 05:49 PM   #3
red73mustang
Senior Member
It came with the house, If I had a manual I would have read it.
Old 01-12-2013, 05:56 PM   #4
Gary S
Senior Member
http://www.managemylife.com/mmh/owne...pener-L0910363
Old 01-12-2013, 06:00 PM   #5
LEVE
Senior Member
Here's the manual:
Genie Manual
LEVE is offline   Reply With Quote
Old 01-12-2013, 11:35 PM   #6
PT Doc
Senior Member
PT Doc's Avatar
If you can't figure it out then call genie. Some of them have lifetime parts, labor and motor coverage. Mine does.
If you got nothing then you could have a fried circuit board or 2. They are really awash to swap out. The genie tech support is really good with troubleshooting you through the diagnostics. Are your lights on the safety sensors on?
PT Doc is offline   Reply With Quote
Old 01-12-2013, 11:39 PM   #7
darcyh
Senior Member
Over they years, I have owned 3 Genie openers at three locations and have found their support to be very good although I have not needed it much. Even if the part is off warranty the replacement prices are very reasonable.
darcyh is offline   Reply With Quote
Old 01-13-2013, 12:09 AM   #8
jhelrey
Senior Member
Use a multimeter to check for voltage. All it takes is one wire to cross the wire for that outlet and you will get a false signal.
Ask me how I know?!?!
jhelrey is offline   Reply With Quote
Old 03-03-2013, 07:37 PM   #9
red73mustang
Senior Member
Door opener "magically" started working again!! Could colde weather / moisture in the North East have affected it ?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
