Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 05-25-2008, 07:48 PM   #1
maximum
Junior Member
Default How to extend my garage door?
Looking for some advice on modifying my standard garage door of about 7 feet in height. I want to put a 4 post lift but the door will run into the car when it is elevated. I've located some track that would extend the vertical section on each side but I wanted to know if anyone has done this. I could get at least 2 more feet if there's no problem. Appreciate any guidance.
maximum is offline   Reply With Quote
Old 05-25-2008, 11:10 PM   #2
PhantomEB
Senior Member
PhantomEB's Avatar
Send a message via MSN to PhantomEB
Default Re: How to extend my garage door?
I kinda did this but in a different way, I wanted full clearance of the door opening so at first I got some more track, then piggybacked it which didnt work, busted all the rivets then bent it right where I butted the new to the old.
Second try worked better, capped it backside and topside with 2x2 angle iron and tack welded the door track to the angle iron. WORKS great, just have to push the door up higher as my opener has to be disconnected since it wont pull it to where I want it to.
PhantomEB is offline   Reply With Quote
Old 05-26-2008, 09:06 AM   #3
Northstar9126
Senior Member
What if you lengthened the arm that connects the door opener to the door?
Northstar9126 is offline   Reply With Quote
Old 05-26-2008, 12:48 PM   #4
kbs2244
Senior Member
I used a standard length door opener with 8 foot high doors and 10 foot high ceilings by mounting it about 18 inches away from the door opening. I found the right location by running the traveler all the way to the end of the track.
(In a normal install the traveler never gets closer than 18 to 24 inches to the door opening and that part of the track is wasted.)
You do have to put in front to back bracing since the track isn’t braced against the door header anymore.
Then I used a piece of that angle iron with all the holes punched in it to make an extension for a longer arm. It worked fine.
Pay attention now. This is important.
Since you do not now have the very top rollers on the door resting past the start of the curve in the track you have to play with both the length of the arm and the location of door end of the track so that at the start of the lift you are pulling up, not sideways. Otherwise you are pulling sideways against the track edges not inline with the track length.
And that will bust up your door.
This is why the arm has that curve in it.
Be patient. You will not get it right the first time.
This kind of geometry lesson is what the jackshaft style openers avoid.
kbs2244 is offline   Reply With Quote
Old 05-26-2008, 08:48 PM   #5
JohnZ
Senior Member
I have 18' x 8' sectional doors and a 12' ceiling. Had the door in front of my lift bay converted from its original standard configuration to "high-lift" by adding a dummy section at the top (not visible from the outside), raised the horizontal tracks to 8" from the ceiling, raised the operator track to 2" from the ceiling, stronger torsion springs, lengthened the existing drawbar. The extra dummy section solves the geometry problem of translating the horizontal pull of the opener to an initial vertical pull on the door.
JohnZ is offline   Reply With Quote
Old 05-26-2008, 11:25 PM   #6
SharkD
I recently had a completely new track and Liftmaster 3850 installed. The door is a 10'x7' (WxH), originally with a 12" radius curve and the opener hanging about 2' below the 9'8" ceiling.
Now, it's a 32" radius, with the opener about 6" below the ceiling. The door is about 2' higher and raises and lowers much more smoothly. The opener arm had to be extended, using the old arm and the new arm, bolted together.
The install cost $500 for the new track, including the high-lift.
SharkD is offline   Reply With Quote
Old 05-27-2008, 07:07 PM   #7
maximum
Junior Member
Thanks all. I went ahead and did the job on Monday. All I ended up using was some old track for some extensions and was able to raise it up about 32 inches. I will need to do the "dummy" extension like you did so I can run the electrics instead of the old fashioned human assist.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
