Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 01-31-2013, 12:51 PM   #1
mrjaw14
Senior Member
Default show me your DIY socket organizers
I have the HF 44" tool chest with the single full-length drawer that's 38" x 18".
I have the HF socket organizer and the 3/8" and 1/4" are fine, but the 1/2" are too long because I don't have a complete 1/2" socket set. I don't have 16mm, and several of the other sizes. My craftsman 1/2" socket set starts at 9mm...and yes I know that 9mm in 1/2 is kinda pointless, however I have it, and it has no home. Also the tray goes up to 27mm & 1 1/4 sae and I don't have or plan on needing sockets that large. I do have them in impact, but I have a separate organizer for those and will use those with a ratchet if I need a socket that large. so I have small sockets that don't have homes, and homes for large sockets I don't have.
That's the issue...now here's what I want: My socket set will evolve over time as I replace my cheaper stuff with nicer stuff. so I want the ability to arrange my sockets without a lot of empty space that I'd get with a hansen organizer if I don't have that size (like a 16mm) also I want labels. I don't like having to hunt for sockets. I thought about a magnetic socket holder, or some of those ernst style socket holders, but alas there's not an easy way to label anything that way. I know the ernst comes with tiny labels for the plastic socket clips, but in a high density drawer things would be spaced so close that the labels wouldn't be of much use.
I am thinking about dowel rods, painted blue and red for mm and sae, then printing labels and heat shrinking them onto the dowel rods. I don't really want to have a wood base, would make it large & heavy. I can't figure out a way to attach those to a ernst style or the metal socket clips that would be customizable like I want and still have labels
I'd be very interested to see your setups that might help me make mine.
mrjaw14 is offline   Reply With Quote
Old 01-31-2013, 01:00 PM   #2
Mike14k
Senior Member
Mike14k's Avatar
Default Re: show me your DIY socket organizers
I had somewhat the same issue with a lot of orphan socket sets and spares I had inherited. Gives me a place to store them and also add/subtract.
I made this assembly out of socket rails from HF and some scrap 1" aluminum in about 15 minutes. As they change, I just take a bolt out of the end, and slide the socket clips on and off.
http://www.flickr.com/photos/mtneer_man/7819974698/
Hope that helps.
__________________
Mike14k
I have four different shops in one house to take care of my:
Supercharged Jaguar XKR
Jaguar XJ8
Mercedes E-500
Jeep Commander
Honda TRX420
CanAm Spyder ES
Mike14k is offline   Reply With Quote
Old 01-31-2013, 01:08 PM   #3
Mike14k
Senior Member
Mike14k's Avatar
This might be overkill........
Another socket organizer I made years ago. I used an Excel spreadsheet, measured each socket diameter and plugged it in the spreadsheet. Then created a formula that worked out the C/L spacing for the wooden dowels the sockets slide over, so I had the same spacing in between. I used pre-cut joiner dowels. 1/4, 3/8 and 1/2"
I then converted that information in Visio to full size templates, attached it to the plywood and drilled the holes for the dowels.
That was back when I had a lot of time on my hands But it's worked well.
http://www.flickr.com/photos/mtneer_man/359112057/
__________________
Mike14k
Jaguar XJ8
Mercedes E-500
Jeep Commander
Honda TRX420
CanAm Spyder ES
Old 01-31-2013, 01:25 PM   #4
NoNN37
Senior Member
NoNN37's Avatar
do a search. a quick serach turned up these.
NoNN37 is offline   Reply With Quote
Old 01-31-2013, 01:39 PM   #5
mrjaw14
Senior Member
I've seen all those. they are A) wood bases, and B) not labeled. I was looking for more elegant solutions as indicated in my post. I'm getting real sick of people jumping on the "do a search" wagon. There's not a thread dedicated to DIY organizers that I found, and what about new stuff made since then....maybe people that made those have changed or have input after using it for a while.
besides, searching for threads isn't what keeps forums open. people talking does!
Old 01-31-2013, 01:50 PM   #6
NoNN37
Senior Member
NoNN37's Avatar
Well you said you wanted to do them with wood and dowels.
youll notice some have the bases made in sections so its not one heavy big-ass piece of plywood (its gonna get heavy with the sockets anyway). You can customize or replace that section instead of redoing an entire board. Then just buy a label maker and put the numbers.
Old 01-31-2013, 01:58 PM   #7
DirtRoad
Senior Member
These are one of those things that are cheap to buy and so many options out there. Dont see much point in making your own unless your extremely board.
__________________
My slooooow shop build
http://www.garagejournal.com/forum/s...d.php?t=173648
DirtRoad is offline   Reply With Quote
Old 01-31-2013, 02:13 PM   #8
mrjaw14
Senior Member
True, but I was thinking more along the lines of using them just for the retention and label portion. if I drilled a small hole in the bottom, then had a bunch of holes in my base material, I could rearrange the dowels at will by screwing them into another hole. The solutions I've seen thus far are permanently fixed to the wooden base, which is not easy to change if you change your setup. I'm torn, I want the nice labels the pre-made organizers offer, but all the options I've seen like the HF trays or the hansen trays are not configurable. The ernst and similar solutions are very configurable, but not easy to tell what stuff is
Old 01-31-2013, 02:29 PM   #9
d.mcfarland
Senior Member
d.mcfarland's Avatar
Quote:
You are way overthinking this, to the extent that nobody here is going to have what you want.
__________________
Items for sale or trade: http://www.garagejournal.com/forum/s...d.php?t=159356
d.mcfarland is offline   Reply With Quote
Old 01-31-2013, 02:46 PM   #10
Givl Reggin
For expandability and maximizing use of space, it's hard to beat rails...
I used Craftsman rails, black for inch and gray for metric.
Givl Reggin is offline   Reply With Quote
Old 02-10-2013, 09:01 PM   #11
mrjaw14
Senior Member
I ended up making my own organizers. Didn't get the socket size labels like I wanted. I thought about short dowel rods painted red or blue with a small screw going into the top of the metal socket clip. I tested it, and it worked well except that I couldn't get it perfectly straight so I abandoned the idea for now. I wanted to show what I made and get your thoughts on how it turned out
Old 02-10-2013, 09:29 PM   #12
usmc_noma
Senior Member
I like the way that turned out. The only thing I'd do differently is keep the same size together, ie 1/4", 3/8", 1/2". Currently I have them just thrown on a rail together with the same size, deep/short, and 6pt/12pt in my top drawer. I'd like to get a bigger box or a top box before I organize more.
usmc_noma is offline   Reply With Quote
Old 02-10-2013, 09:54 PM   #13
Sloasszx3
Junior Member
That looks pretty good. I'm still trying to make a nice setup like that.
Sloasszx3 is offline   Reply With Quote
Old 02-10-2013, 10:39 PM   #14
84TurboBuick
Senior Member
84TurboBuick's Avatar
These are what I made at one time.
After I built my toolbox, I went with something else.
__________________
“One only needs two tools in life: WD-40 to make things go, and duct tape to make them stop.”
Make your own toolbox!!!..........
http://garagejournal.com/forum/showthread.php?t=50256
http://garagejournal.com/forum/showthread.php?t=39014
84TurboBuick is offline   Reply With Quote
Old 02-11-2013, 02:27 AM   #15
Conductor562
Senior Member
Conductor562's Avatar
I bought a set of Hanson trays for 1/4", 3/8", and 1/2". They had some odd sizes on them (to me at least) such as 1" on the 3/8" tray. Is anyone actually using a 1" socket in 3/8" drive Being the particular bastard that I am, I just started buying the fillers.
__________________
Does the guy that dies with the most tools win?
Looking for Plomb War Finish combos larger than 11/16"
TOOLS IN ACTION Blog
Conductor562 is offline   Reply With Quote
Old 02-11-2013, 08:31 AM   #16
mrjaw14
Senior Member
Quote:
This is exactly why I made my own. I have the 44" HFT box, which is a good box don't get me wrong, but it's not very deep. The hansen style organizers just took up too much room. I have 8 rails on the one I made that fits into a 16"x12" footprint that I can arrange any way I want. I actually have the black plastic HFT organizers for my 3/8" and 1/4" sockets. I use the one I made for 1/2" drive and adapters for all 3 drive sizes. here's a pic of the whole socket drawer
Old 02-11-2013, 01:52 PM   #17
Conductor562
Senior Member
I'm going to end up making something. The Hansons go all the way down to 10MM and 3/8" in 1/2" drive, but only go up to 27MM in Metric. Seems to me it would have made much more sense to stop at 13MM and go to 30MM.
The 1/4" trays go all the way to 15MM which seems weird when you consider the 1/2" tray starts at 10MM.
The 3/8" tray goes to 1" despite the fact that most 3/8" sets stop at 7/8" and there are no posts for spark plug sockets.
just seems weird to me.
__________________
Old 02-11-2013, 03:23 PM   #18
HaroRider
Senior Member
HaroRider's Avatar
Heres my setup, limited space in my small Craftsman box.
However I didnt really need to label them. In time I would like to get a bigger box and get better organized, but this is the best I could do with the limited space I have.
__________________
Quote:
Originally Posted by willy3486 View Post
Arguing with a woman is like trying to keep a starved grizzly bear with a tapeworm from eating you while you are in a straight jacket with leg chains on and tied to a cannon ball. Chances are its not going to be a good outcome for you in either case.
HaroRider is offline   Reply With Quote
Old 02-11-2013, 05:00 PM   #19
sberry
sberry's Avatar
I sort by size and frequency. Part of my clain to fame is being able to use a common socket and extensions where other people seem to need to come up with something convoluted. I have a box with the "sets" in but 99 times out of a hundred its right there. I dont want to look or sort thru all the stuff I use once in a blue moon, it doesnt even need to be highly orgaiized, will walk to get a socket I use on occasion but I have the commons and the drives easy to reach.
A better tool wouldnt help, an easier one does. A flat rate guy would find it a treat to work in my shop, even parts of my messy box are not bad as the frequency of use for specialty items is low, any given task takes but a few tools.
sberry is offline   Reply With Quote
Old 02-11-2013, 06:06 PM   #20
ABRM
I don't have a pic but all I did was take a piece of wood that I painted, and drilled holes through it. Then I cut some Dowel sticks for socket posts. Worked well and was cheap. For my next box, I plan on getting some Hansen trays.
ABRM is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
