Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 02-04-2013, 06:20 PM   #1
mrjaw14
Senior Member
Default Rust-oleum spray enamel won't dry!
I've got a piece of painted metal that I roughed up and sprayed with Rust-oleum spray enamel....2 days ago. Sprayed outside, and quickly brought inside where it's warm. 2 days later after drying in 70 degree house it's still tacky and wet.
someone told me it was due to their new "green" formula....anyone else haveing trouble with paint not drying?
mrjaw14 is offline   Reply With Quote
Old 02-04-2013, 06:26 PM   #2
BlindViper
Senior Member
Default Re: Rust-oleum spray enamel won't dry!
did you put on a bunch if light coats or 1 or 2 heavy coats?
BlindViper is offline   Reply With Quote
Old 02-04-2013, 06:26 PM   #3
930dreamer
930dreamer's Avatar
I place painted item in front of the salamander heater for a few minutes.
__________________
I can take it apart.
http://stores.ebay.com/930dreamer?_rdc=1
930dreamer is offline   Reply With Quote
Old 02-04-2013, 06:44 PM   #4
Bobf
Senior Member
I used rustoleum spray cans for probably at least 20 years, until last year. They did something to the product and or spray tip in that they plug up and quit with 2/3 in the can. I had several cans all do the same thing. In the past when finished I've always turned the can upside down and sprayed inside a trash can until the paint stopped, then wiped the plastic nozzle and it was ready to go the next project. Not anymore. I started using Krylon some time last year and haven't had those problems.
Bobf is offline   Reply With Quote
Old 02-04-2013, 07:18 PM   #5
sloorider
Junior Member
Does not cure well in low humidity I believe to be the problem.
sloorider is offline   Reply With Quote
Old 02-04-2013, 08:51 PM   #6
NewShockerGuy
Senior Member
NewShockerGuy's Avatar
If they are small items bake them in the oven.
I sprayed my blue metal brackets for my shelf flat white then baked them for 285 degrees for about 40 minutes. Came out quite well. :-)
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 02-04-2013, 10:09 PM   #7
rburke65
Senior Member
rburke65's Avatar
I have not had good luck with Rustoleum spray paint recently. Their nozzles are crap!
rburke65 is offline   Reply With Quote
Old 02-04-2013, 10:48 PM   #8
Kevin C
Senior Member
Kevin C's Avatar
http://www.rustoleumibg.com/images/t...s_TDS_Rev4.pdf
The data sheet says humidity needs to be below 65% for proper drying. Under "normal conditions its pretty slow to dry. It has mineral spirits. The MSDS for mineral spirits lists its flash point at 100.4F. Could to be why it drys slowly and needs lower humidity.
Kevin C is offline   Reply With Quote
Old 02-05-2013, 07:52 AM   #9
Cryptic1911
Senior Member
Quote:
isn't that a big no-no? I've read that the residue from burning the fuel creates fisheyes in paint
Cryptic1911 is offline   Reply With Quote
Old 02-05-2013, 11:05 AM   #10
Modifieddriver
Senior Member
For years I always have that slow drying problem with Rust-O-leum.
Although hard to find around here, my favorite spray can paint is Plastikote.
Modifieddriver is offline   Reply With Quote
Old 02-05-2013, 11:45 AM   #11
JakeKohl
Senior Member
JakeKohl's Avatar
They changed their formula several years ago and it made it impossible to layer colors without getting a crackle finish where the two colors overlap. I even talked to their support folks by phone, and there wasn't much to be done besides lay down multiple fog coats and have to sand to a decent finish...I know that sounds like a lot of work for a rattle can paint job but it's hard to justify buying two $45 quarts of automotive quality paint to paint a 3 foot r/c sailboat.
__________________
Jake Kohl
Greenville, SC
My Garage Journal Build Thread
"People complain about it being too expensive. People complain about it being too small. Nobody complains about it being too big."
JakeKohl is offline   Reply With Quote
Old 02-05-2013, 12:31 PM   #12
dmeadow
Senior Member
dmeadow's Avatar
-Nigel
^^^This.
Same thing worked for me with some small brackets and black paint. Wait for SWMBO to be out for awhile, though. It does create a tell tale smell.
dmeadow is offline   Reply With Quote
Old 02-05-2013, 12:43 PM   #13
chipper
Senior Member
chipper's Avatar
It could be a reaction to the original paint if its important to you strip it to bare metal and start over
chipper is offline   Reply With Quote
Old 02-05-2013, 01:21 PM   #14
sselander
Senior Member
try finding something other than Rustoleum at HD - NOT.
I have to go to the local hardware store or car parts store to get Krylon.
I did not know until recently that Krylon is owned by Sherwin-Williams.
Rustoleum has a huge presence at the big boxes.
Interestingly Krylon industrial also owns Duplicolor and VHT which are found in the car parts store.
http://www.kpg-industrial.com/
The parent company of Krylon is Sherwin-Williams:
http://en.wikipedia.org/wiki/Krylon
The parent company of Rustoleum is RPG InternationalL
http://en.wikipedia.org/wiki/RPM_International
sselander is offline   Reply With Quote
Old 02-05-2013, 02:12 PM   #15
mrjaw14
Senior Member
humidity here is 40-50% in the house right now. Last night it was still really tacky like 3 days later. I got out my heat gun and heated it for a few minutes. that seemed to make it worse, but then once it cooled down over night it feel drier this morning. I was wondering about the oven, but my wife wouldn't like that smell too much lol. I may just have to deal with the long dry times on this project and then switch to krylon as you guys are suggesting.
I think to coat the other side I'm going to try heating the surface of the metal with a heat gun to 90-100 degrees, then spray a few thin coats a few minutes apart. That'll probably need to dry for 3-4 days...but somehow knowing that it'll take that long is better than worrying about wtf won't it dry when not expecting to take that long...I guess it's all about managing expectations
Old 02-05-2013, 10:21 PM   #16
Worldpowerlabs
I have had some luck with heating small parts in the oven once the paint is sprayed onto them. I've had better luck with preheating the parts a bit (perhaps to 100 - 110F) before painting. Sometimes heating after painting has caused wrinkling.
I'm not a fan of Rustoleum in aerosol cans -- it does take a long time to dry. The only way I'll use Rustoleum is if I can brush it on or spray it out of an HVLP gun. Either way, I add Valspar catalyst. It still takes a while to harden, but eventually it does.
Worldpowerlabs is offline   Reply With Quote
Old 10-04-2016, 06:22 AM   #17
Wally57
Junior Member
Quickest solution when Rust-Oleum spray paint won't dry...
Spray additional coat of similar based Rust-Oleum Clear over
tacky paint as a topcoat. Spray when humidity is lowest
{eg. noon-3m on a clear day} to help prevent being tacky.
Thanks, Brian
Wally57 is offline   Reply With Quote
Old 10-04-2016, 06:51 AM   #18
mmb617
Senior Member
mmb617's Avatar
Rust-Oleum in the spray bombs used to be good paint. Not anymore. And the nozzles they use now are really bad. It'll be a cold day in the netherworld before I buy any more of their paint.
__________________
OFR - old fart racing. We're not real fast, in fact a lot of folks call us half fast racers.
mmb617 is offline   Reply With Quote
Old 10-04-2016, 10:11 AM   #19
rcktsled
Senior Member
Amazon has a great selection of spray paint, just about every brand, every color, and it's usually cheaper than Lowes or HD. I never buy spray paint locally any more, just order it online.
rcktsled is offline   Reply With Quote
Old 10-04-2016, 10:40 AM   #20
Blk88GT
Senior Member
Send a message via MSN to Blk88GT
I've had the same thing happen, junk paint was the result.
Blk88GT is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
