Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 02-09-2013, 01:48 PM   #1
Greatwhitewing
Senior Member
Default Most reliable snow blower?
My POS Home Despot blower let me down again finding Nemo. I just had it serviced and wouldn't even sputter when I needed it most.
Looking for the best brand for reliability starting. Ariens seems to be pretty well reviewed.
Nothing better than going to the tool geeks though... I mean that in the best possible way..
Greatwhitewing is offline   Reply With Quote
Old 02-09-2013, 02:06 PM   #2
kossuth
Senior Member
kossuth's Avatar
Default Re: Most reliable snow blower?
Well honestly the best snow thrower is you. They will all have issues from time to time. Now I realize that was not your intended answer. But let's see if can help you get it going. First thing I would check is does the one you have now have spark when you turn it over? If it doesn't then I would remedy that problem. Could be a shorted shutdown switch or a little critter decided to build a nest up along the coil pickup. If it has spark I will bet the gas either has water in it and has frozen up the carb/fuel line. Some fresh gas as long as the carb is fine should get it going. If the carb is iced your gonna have to get some heat into it to thraw it. That's kinda a dicey deal but if your snowed in your safe and quick options are limited if you can't heat your garage.
If your dead set on a new unit there are plenty of good units out there. The MTD brands are ok. You also have Arines which are good. Mostly what it boils down to though is the electric start models are easier to get going though.
kossuth is offline   Reply With Quote
Old 02-09-2013, 02:07 PM   #3
Jsf721
Senior Member
I have an Ariens that has been reliable with minimal maintenance. Really just use it 3-4 times per winter though. Electric start is sweet.
Jsf721 is offline   Reply With Quote
Old 02-09-2013, 02:09 PM   #4
clark_nicholas
Senior Member
clark_nicholas's Avatar
Toro
clark_nicholas is offline   Reply With Quote
Old 02-09-2013, 02:09 PM   #5
Greatwhitewing
Senior Member
Has spark so the safety switch isn't hindering. I am sure it's the carb, always is.
Yes, I use stabilized fuel. It even started a few days ago. yes I checked for fouled plug.
Old 02-09-2013, 02:11 PM   #6
IMStuner
Senior Member
IMStuner's Avatar
Default
I have a 20 yr old Honda hs828 track drive and starts up with one pull every time.
IMStuner is offline   Reply With Quote
Old 02-09-2013, 02:12 PM   #7
kossuth
Senior Member
kossuth's Avatar
Carb is probiably iced up. Probiably no way to to get heat in the garage or safely heat the carb? That issue will happen regardless of brand though. That's more of a product of the shitty gas they sell anymore which pulls water into by its nature.
Old 02-09-2013, 02:14 PM   #8
Greatwhitewing
Senior Member
Quote:
all the other snow blowers were working today...
Had dry gas from still from the recent service.
Old 02-09-2013, 02:20 PM   #9
Skin
Senior Member
assuming you don't want to spend 2+ grand for a new snowblower you're left with just 2 engine choices. Chinese Honda clones which suck and Briggs and Stratton which suck less.
for a decent 2 stage that really only leaves you with Ariens and Simplicity. Everything else either uses sub par materials and or a Chinese engine. If it doesn't say Briggs on it, its Chinese. I say this as most everyone, including Toro and Ariens (depending on the model) is slapping their name on said Chinese engines as a house brand.
Skin is offline   Reply With Quote
Old 02-09-2013, 02:32 PM   #10
Motorhead Extraordinaire
Senior Member
Motorhead Extraordinaire's Avatar
I have had my Ariens ST8-24 for 22 years, and the Ariens before that for 20 years before I gave it to my brother and he used it for another 10 years.
Rock solid reliability for 42 years. Guess what brand I am buying next? An Ariens with a B&S engine.
__________________
Joe Germann, owner of Motorhead Extraordinaire
Distributor of Lista International.
Follow us on Facebook for Lista specials.
Motorhead Extraordinaire is offline   Reply With Quote
Old 02-09-2013, 03:01 PM   #11
honcho
Senior Member
Used to be that Tecumseh Sno King engines ruled in the snowblower market with good price / performance ratio. However, I'd look for something OTHER THAN MTD with a Honda GX engine--probably a Honda snowblower with a GX series engine.
honcho is offline   Reply With Quote
Old 02-09-2013, 03:04 PM   #12
John316
Senior Member
John316's Avatar
http://gold.mylargescale.com/scottychaos/ariens/
John316 is offline   Reply With Quote
Old 02-09-2013, 03:14 PM   #13
zkling
Senior Member
Is it a 2 cycle or 4 cycle powered blower? What engine is on it?
98% of the time the problem with the 2 cycle engines is that the fuel passages get plugged up. A quick dissemble of the carb and blow out with an air compressor will solve the problem. Careful not to blow out the needle seat. Most of the 2 stroke blowers I have seen use float type carbs, so not many critical gaskets to fail unlike the smaller chainsaws and weedeaters.
I have been very happy with our small Toro 5hp 2stroke Tecumseh powered blower. It works great for the ~5" and under snow we get here in southern Ohio. Granted it is going on 10 years old so not sure what the new quality is.
As for electric start.... If you blower won't pull start within 4 pulls you have an engine problem. I personally think the electric starts are just a pain, add weight and expense to the units. Then again I am a younger guy.
zkling is offline   Reply With Quote
Old 02-09-2013, 03:14 PM   #14
JoeyMitch
Senior Member
JoeyMitch's Avatar
ARIENS ARIENS ARIENS ARIENS!!!!! They are the best of the best!! We bought the 11528 3 years ago and had a 26" storm after we bought it and it was fantastic! We do the neighbors and everyone else just for fun too. We also have an Ariens 722 single stage that we use on <10" storms. The lifetime warranty paddles are nice but too bad they don't sell that blower anymore. We bought both of ours from a dealer and the dealer is great because he was very helpful. We had a Craftsman and it was good for one year and then we blew the head gasket. Once you buy an Ariens you will not look back. I like that they are pretty much all metal and both of ours are MADE IN USA!!! Below is a video of our Ariens 11528 Deluxe in action with 25" of snow (My dad is the one using it). Sorry the quality is bad. The camera got a little wet. I also have two other videos of us starting them after sitting all summer. Hope this helps!!!
http://www.youtube.com/watch?v=17WgR23KfLg
__________________
Joey Mitchell
18 Years Old
Obsessed with Fishing and Tools!!!
2000 Jeep Cherokee XJ Sport
2012 Pathfinder Silver Edition
JoeyMitch is offline   Reply With Quote
Old 02-09-2013, 03:19 PM   #15
Egghaus
My dad has a Honda HS55, must be 25 years old. Starts on the first pull every time.
Egghaus is offline   Reply With Quote
Old 02-09-2013, 03:43 PM   #16
buco
Senior Member
buco's Avatar
Honda. The best.
buco is offline   Reply With Quote
Old 02-09-2013, 04:00 PM   #17
firebox40dash5
Senior Member
Old Gravely walk behind with a snowthrower... incredibly overbuilt, and overkill.
My uncle has a 10hp Pro IIRC, with a 34" snowthrower that I had rebuilt for him last year. It had been sitting for years, but amazingly fired right up for me. The downside is you'll get almost as much of a workout as you would shoveling, but it's the fun kinda workout. I weigh about 185, and with that snowblower on it, it takes my full weight on the bars to lift the front off the ground.
firebox40dash5 is offline   Reply With Quote
Old 02-09-2013, 04:06 PM   #18
PinchPoint
Senior Member
My Wife!
PinchPoint is offline   Reply With Quote
Old 02-09-2013, 04:08 PM   #19
rct
My Simplicity blower with the 8 hp Briggs engine has been reliable and easy to start for 11 years. Essentially all the current major players (Simplicity, Ariens and Toro) use Briggs and Stratton engines and Honda snowblowers use, well Honda. I think larger 2 stage snowblowers with easier to service 6+Hp 4 stroke engines are better than the smaller blowers with smaller 2 or 4 stroke motors for long term ease of starting. Living near Buffalo, I never once drained the blower, but did run it once-twice each summer. I think I changed the oil once and still on the original plug.
rct is offline   Reply With Quote
Old 02-09-2013, 04:08 PM   #20
b1ghwx
My shovel starts every time, needs very little maintenance and keeps running until I am ready to quit.
If you need a blower - the brand really doesn't matter one wit..... you have to maintain it. The most frequent problem is the carb. I would always run some seafoam or similar in the gas to keep the fuel system clean.
b1ghwx is offline   Reply With Quote
Old 02-09-2013, 04:09 PM   #21
PinchPoint
Senior Member
I had a John Derre 10 hp 32" wide it never failed me for a good 10 years. Then in November my neighbor burned my garage to almost the ground. And the big green machine was toast.
Old 02-09-2013, 04:11 PM   #22
the1nonlyjl
got the craftsman yearrrrrs back i think in 2001...9 hp 29" with electric start... two stage... its still hanging in there like an ox.
the1nonlyjl is offline   Reply With Quote
Old 02-09-2013, 04:21 PM   #23
Greatwhitewing
Senior Member
4 cycle
Old 02-09-2013, 04:24 PM   #24
Greatwhitewing
Senior Member
This was 25 inches of heavy wet snow for a large driveway. NOW WAY with a shovel..
Old 02-09-2013, 04:51 PM   #25
j.c.whitney
Senior Member
j.c.whitney's Avatar
Bought a 1970 Toro SnowHound 20" from the School District in 1986. Replaced the belt and both tires about 10 years ago, starts first or second pull.
__________________
Wanted: Snap On KRA 4860DPCM
j.c.whitney is offline   Reply With Quote
Old 02-09-2013, 04:57 PM   #26
zkling
Senior Member
4 cycle
What model or style of engine? Have you cleaned out the carb thoroughly? And replaced the diaphragm?
Old 02-09-2013, 05:03 PM   #27
Greatwhitewing
Senior Member
It was recently serviced professionally because it wouldn't start and started when done. Had the POS serviced3 times now..
Old 02-09-2013, 05:04 PM   #28
silver2000
silver2000's Avatar
I have found that Hondas to be the absolute best, nothing else ever came close for me. I have bought numerous Honda's kept them got a slightly better and now use on of their HS1132 Tracked model, just worked great for our Mass blizzard.
I have also bought every one of them used, always get them off season and if you get the right person who wants to sell you can save more than 60% and many times find one like new.
I love them but don't think I could pay full retail.
It should be noted that this message is courtesy of me running on a Honda generator since we have had no power for almost 2 days now, the Honda small engines are phenomenal.
silver2000 is offline   Reply With Quote
Old 02-09-2013, 05:06 PM   #29
twincam00
Senior Member
twincam00's Avatar
Honda makes THE BEST snowblowers, but the insane price of them keeps them from being popular
I would go with an older Ariens, theyre pretty bulletproof and hold their value well
twincam00 is offline   Reply With Quote
Old 02-09-2013, 05:15 PM   #30
zkling
Senior Member
Wow I would definitely be talking to those "professional" service shops. Something is not right here. What is the make and model of engine on it?
I just hate to see you give up on a unit that may need a minor adjustment.
Old 02-09-2013, 06:23 PM   #31
Greatwhitewing
Senior Member
I have to go look, don't remember..
Old 02-09-2013, 06:39 PM   #32
jdjm
In Oct. 2011 we bought a toro with a B&S engine on it. Its a 26 cut. I was told by the dealer that this was the last year Toro was using B&S engines. They now will have a chinese engine built to Toro specs just like the honda uses.
jdjm is offline   Reply With Quote
Old 02-09-2013, 06:59 PM   #33
kc-steve
Senior Member
kc-steve's Avatar
I've heard good things about Ariens but I bought what was available with a big storm bearing down on me two years ago. I bought the last one they had, a mid-sized two-stage 27-inch Snapper (with reverse).
Since then I haven't had the chance to find out about all the bells and whistles it has (no snow) but recently had a difficult time getting it started using the pull start.
HOWEVER, I noticed an extension cord in the package. It was an AC plugin for using the electric start. That dude cranked over fast and started right up using the electric cord.
Even though I take good care to maintain it, start it up from time to time, I'll never buy another without an electric start.
Steve
__________________
Junkyard Tools rescued from the junkyard
Feedback
kc-steve is offline   Reply With Quote
Old 02-09-2013, 07:14 PM   #34
padronanniversary
Senior Member
Honda without a doubt. I have had ariens cub cadet, Jd
And they have all failed me. My Honda bought three years ago starts up every time, throws heavy crap the others would bog down on.
I only wish the one I bought had the joystick for the chute rather than cranking it
padronanniversary is offline   Reply With Quote
Old 02-09-2013, 07:31 PM   #35
Slip_Kid
Senior Member
Slip_Kid's Avatar
Quote:
Originally Posted by PinchPoint View Post
My Wife!
Sweet!!
Slip_Kid is offline   Reply With Quote
Old 02-09-2013, 07:31 PM   #36
MDI,09
Senior Member
MDI,09's Avatar
If it was just serviced call whoever serviced it and get your money back. I work on the side as a mechanic and I would want to know if I failed or could help. Edit: I have a two stroke Toro I got for free because it wouldnt run. Used it the last two years.
MDI,09 is offline   Reply With Quote
Old 02-09-2013, 07:41 PM   #37
Slip_Kid
Senior Member
Slip_Kid's Avatar
My 21 year old MTD with B&S engine is still going strong. It struggled today with 24in of wet snow but it got the job done. When this one dies I would like to get a used Honda. I would not be without my Honda generator, it never let me down yet.
Old 02-09-2013, 07:54 PM   #38
Terra Nova
Senior Member
Terra Nova's Avatar
Whatever one that you use fuel stabilizer in and run it out of gas if it'll be sitting more than a couple days. Seriously. I have an Ariens and would recommend that, a Toro or a higher end Simplicity.
My shovel is 100% reliable but it gets annual tune ups too (sharpen with flap wheel, wax, tighten any loose rivets or replace with stainless steel bolts & nyloc nuts...)
Terra Nova is offline   Reply With Quote
Old 02-09-2013, 08:12 PM   #39
Skin
Senior Member
Honda's are built like tanks but are WAY overpriced for what they are. Literally double the price of the higher end competition. Electric starts aren't standard across the model ranges like most other brands and infact aren't even offered on 2 stages until you hit $2800.00 price range, and they dont have other newer options like a differential or the ability to unlock an axle to pivot steer. For 1400-1600 you can get a really nice Ariens Platinum, electric start is standard and its got an automatic differential built into the axle so just a little turning pressure disengages one axle allowing turning on the spot. Simplicity is priced higher with the nice units starting around $1800 but they're easily built as well as a Honda with higher end Briggs engines and they pivot steer by a simple trigger system.
Quality wise of the chassis if Honda and Simplicity are a 10, Ariens are a solid 8, still leagues better than the common Craftsman, MTD and Murray units sold today.
I like Toro too but as stated their larger PowerMax models are all equipped with Chinese engines now.
Old 02-09-2013, 08:37 PM   #40
vssjim
Alliance Member
I have had a Snapper with a Techumse engine for ten years, but every spring it gets full service and fuel drained out them fogged before storage. Only parts have been some shear pins in the augers which is normal to shear on ice blocks.
vssjim is offline   Reply With Quote
Old 02-09-2013, 08:44 PM   #41
ephotrod
Senior Member
ephotrod's Avatar
Any well maintained one.
ephotrod is offline   Reply With Quote
Old 02-10-2013, 12:15 AM   #42
KCarGuy
Senior Member
KCarGuy's Avatar
I dont know about todays Snowblowers...But,
I am still using my Father-in-Law's 1967 Toro.
Pulled it in my garage the other day...Filled it with Gas, checked the oil, and 3 pulls later...she was running and throwing Snow.
I cant even imagine that in 2058, someone may be writing...Hey I am using my Dad's old 2013 snowblower.
(because too many parts are being molded out of Plastic)
KCarGuy is offline   Reply With Quote
Old 02-10-2013, 03:48 AM   #43
Greatwhitewing
Senior Member
Mine has electric start except the POS starter pinion closer resembles a pulley. Starter spins real good but motor just sits there and snickers at me..
Steve
Old 02-10-2013, 06:44 AM   #44
Philly20
Junior Member
I bought a Husky 24" 2-stage electric start from TSC a few years ago and have had no trouble with it. Starts right up evey winter...even with me neglecting to drain the gas or add sta-bil each spring. I've only had to run it really hard in just a few storms, however.
Philly20 is offline   Reply With Quote
Old 02-10-2013, 07:20 AM   #45
Matt M, PA
Senior Member
Matt M, PA's Avatar
I bought my Ariens 6 years ago in August as Home Depot still had it....and it was marked way down. It has the Tecumseh Snow King engine with the plug in electric start. I run it dry at the end of every season.
Matt M, PA is offline   Reply With Quote
Old 02-10-2013, 07:33 AM   #46
cburnscrx
Senior Member
cburnscrx's Avatar
Honda. See other posts.
cburnscrx is offline   Reply With Quote
Old 02-10-2013, 08:26 AM   #47
Greatwhitewing
Senior Member
Okay, so looked at the 3-4 brands mentioned. I really like Honda stuff but paying roughly 2x the price of the others is a tough pill to swallow. I am 55 now and hope to retire to a place where snow in only on the news. I assume the Honda would also have the highest resale value??
Old 02-10-2013, 08:31 AM   #48
MG44
Senior Member
The most important thing is make sure it does not have an off shore generic engine.
I sent my father to Home Depot a few years ago with $2000, I told him to get me two of the biggest snow blowers they have for my shop and one for a small apartment complex I bought. He came back with two real nice Yard Machine snow blowers, 179cc machines. Man they really throw some snow, never stalled, and never got clogged up.
Long story short we had a very warm winter last year, almost no snow. So neither machine got used. I went to start the one at the shop this year and it was getting no gas. I took off the carb. bowl & float, the needle valve was corroded to its bore! We soaked it, tried removing, and it broke. MTD could not get me the needle valve for my particular off shore, chinese, no name brand engine model. They had to sell me an upgraded version of the carb. Its running now, but that $850 snow blower needed a $75 carb instead of a $5 needle valve.
MG44 is offline   Reply With Quote
Old 02-10-2013, 08:44 AM   #49
Beaumont67
Senior Member
Beaumont67's Avatar
I bought a mint used Honda 624 (track drive) snow blower, 15-20 years ago for $1100.
- it was garage kepy and only used 7 times (Canadian retail was ~$1800 back then)
Last year rebuild the skid plate - bottom steel wear plate worn out from scraping the paved driveways.
Still starts and runs like new and will throw snow 40 feet...strongest 6hp I have seen in a walk behind.
I also prefer the 24" wide models, easier to man handle and fits in tight places (like along sidewalks)
- never a starting issue, in almost 2 decades (I run premium gas with SeaFoam added & synthetic oil)
Option #2 would be an old Ariens 24" wide / they will take a 5.5hp Honda motor (or clone) very nicely.
Option #3 would be an old 8hp Toro.
I would never buy the likes of a new MTD brand...waste of good $$, even if its the gold series.
Beaumont67 is offline   Reply With Quote
Old 02-10-2013, 09:15 AM   #50
Beaumont67
Senior Member
Beaumont67's Avatar
If I ever sold my Honda 624 snow blower, around here I could still get $800 to $1000 range.
- very low depreciation, isn't bad...but I started out buying excellent used
- has never been taken into a shop, for costly repairs ($$)..never needed
(unit will be handed down to our adult son, one day...no sense in selling top quality)
The true Honda overall design & manufacturing quality reminds me of the mini bikes in the early 1970's.
- there was many crap mini bikes being made & the Honda CT70 was over engineered and build to last
(and I have a mid 1980's Honda 2 wheeler now - and a commercial 13hp liquid cooled Honda generator)
I like to buy, only once.
Old 02-10-2013, 09:17 AM   #51
RPH
Senior Member
Honda, track drive makes it a snow eating machine. Have had mine for over twenty years. Starts on first or second pull. Cost is high at first but over the years it's ended up only pennies per day and you the best every time you use it. I live in a lake effect area on Lake Huron. Threw out toro's. Honda as other have stated.
RPH is offline   Reply With Quote
Old 02-10-2013, 09:26 AM   #52
CoryZ
Senior Member
Quote:
Originally Posted by honcho View Post
... However, I'd look for something OTHER THAN MTD...
I'll second this. I have a MTD. It was free and I still can't wait to replace it. Cheap junk that doesn't handle much beyond what is easily done with a shovel.
CoryZ is offline   Reply With Quote
Old 02-10-2013, 09:36 AM   #53
storm77b
Junior Member
Default
Ariens, hands down.
storm77b is offline   Reply With Quote
Old 02-10-2013, 09:39 AM   #54
volaredon
Senior Member
screw Honduh, older Ariens (they still make a model comparable but not thru big box stores and not cheap) or older Toro are the way to go
On the JD blowers; the "TRS" series are made by either Murray or MTD; the heavier ones are Ariens machines painted green instead of orange. Watch for cast iron gear cases on the impellers and axle locks where you can lock both drive wheels together; if your Deere has these it is definitely an Ariens.
There are Ariens, Toro and older Sears machines still throwing snow, 30-40 years old!
Tecumseh engimes have taken a bad rap among the most recent ones but the Snow king engines never seemed to get the "bad engine" message;
IF you but a newer 9within last 3 years or so) at least get one with a Briggs, many of the newest don't even have a brand ID on them; some are "powermore" who the He11 makes them? They all need maint now and then you want something you can get parts for and even though tecumseh is gone, parts are still pleintiful especially "common parts" and now that the aftermarket is picking up on small engines like it did 40+ years ago on cars
parts wont be an issue on tehse.
The best 2 things you can do for them; 1) put Stabil in the gas for the off season I start mine up and warm up the engine 3-4 times over spring summer and Fall just to keep things lubed up
and 2) check under the shroud for a "mouse house" built while the machine was stored.
MOST box store brands sold today are made by MTD with different colors of paint, being the only differentiation. Troy bilt Cub Cadet Sears Bolens MTD 'themselves" are all built by the same company now a days but again beware of the engines currently being installed on them!
volaredon is offline   Reply With Quote
Old 02-10-2013, 09:40 AM   #55
volaredon
Senior Member
Quote:
depends on how old it is. older=better if they have had any semblance of maintenance.
Old 02-10-2013, 09:54 AM   #56
bigbearcraig
Senior Member
I have an electric start Ariens. I've had no problems, and starts so easily I don't even use the starter. Always starts on the first pull.
bigbearcraig is offline   Reply With Quote
Old 02-10-2013, 01:01 PM   #57
Packard V8
Senior Member
I can't really comment on the long-term durability of my 1978 Simplicity with the 8hp Briggs & Stratton, but so far, so good.
jack vines
Packard V8 is offline   Reply With Quote
Old 02-10-2013, 01:07 PM   #58
Gary S
Senior Member
There is no "best" snowblower. The best one would be one that lasts forever, but forever is too long for a snowblower to last.
That being said, the older snowblowers had better engines than the new ones today. (we all know why).
I'd look into getting someone's old used one in good condition.
Gary S is offline   Reply With Quote
Old 02-10-2013, 01:37 PM   #59
Skin
Senior Member
You cant just buy an old machine and call it good. Generally speaking 20-40 years is very hard on a snow blower so expect many of the bushings and bearings to be shot and the gear case could probably use a rebuild. Frankly speaking just from what I've seen, be prepared to pay someone who knows what they're doing another $400-$500 in parts and labor to restore an old machine to perfect working order.
The only older machine I would buy would be Ariens branded. They're the only company who still fully supports their machines with replaceable parts dating all the way back to the 60s. MTD and Murray have gone through numerous revisions/ownership changes so generally speaking parts for something 20-30 years ago can be non-existent beyond the common things like belts. Toro is a bit better but still, go back to the 70s-80s and you'll see a lot of components discontinued.
Not everyone sells only carb assemblies, Toro is pushing those Chinese engines hard and does offer individual parts for them. That said they still suck. One huge problem with them was the Chinese fuel line they were installing that deteriorated and gummed up the carb or froze the needle like you experienced so make sure its a good fuel line like Greenbar. That still wont save you from the crap metal they use on the carb bowls which will rust after a few years no matter what, never mind the rest of the fuel tank which is likewise powder coated mild steel and also likes to rust.
I was joking with someone the other day that I like working on those machines because the fuel system becomes trashed so quickly while the rest of the machine is basically new. Makes for few other issues and quick turn around .
Old 02-10-2013, 01:52 PM   #60
Gary S
Senior Member
We have tons of older used snowblowers around here.
http://www.bismanonline.com/content/...e&q=snowblower
Anybody who wants one can easily find one in good condition.
Old 02-10-2013, 02:30 PM   #61
Modifieddriver
Senior Member
Best solution is to relocate. You'll save in the long run.
Moved in '77 and left all this behind for the next guy:
Snow blower, snow board, snow boots, snow bunnies, snow chains, snow drifts, snow plow, snow men, snow mobile, snow sleds, snow tires, snow shovel and the overall cost of snow removal with all its other associated costs/disadvantages like salt, rust, frost lines, etc.
You couldn't get my ass back up there even if you aimed me in that direction and put a lit stick of dynamite up my butt.
Modifieddriver is offline   Reply With Quote
Old 02-10-2013, 03:31 PM   #62
RKA
Senior Member
I'll echo the Honda vote. I'm on my third blower. First was a single stage HS520A. unbelievably efficient and easy to start. I still have this one. Second was a track drive HS724. A child could start it on first pull every December. It had a lot of torque, but the engine was a bit small for what I put it through and I wanted a wider bucket. I convinced myself I could get something newer and better for the price of a used Honda. Last year I got an Ariens Pro 28", but it sat for the unseasonable mild winter. Last Dec I pulled it out of the shed, changed to oil, burned off the old gas and put in some fresh stabilized fuel. Yesterday, about 15 mins into the job, the motor sputtered out. The job was completed by the single stage Honda! I found some mild corrosion in the bowl! To say I'm pissed is an understatement. With proper maintenance, neither of my Honda's have given me any grief over the years. The ariens has already begun on its first pass in the snow.
Do look for a nice condition used Honda. The new prices are hard to justify. Used you can get them for 50% give to take. If you sell it in a few years, you'll get your money back. I made $100 on my HS724, without trying. Bought it within a week of looking and sold it within a week of placing the ad.
RKA is offline   Reply With Quote
Old 02-10-2013, 03:57 PM   #63
kc-steve
Senior Member
kc-steve's Avatar
Steve
This thread got my curiosity up about starting my Snapper. Back when I had trouble it was 10-degrees outside after a snow. Today, it is 55-degrees outside. It started with one pull, no electrics.
And that makes sense because in very cold weather there can be many things besides the engine (B&S 250 cc) that would prevent an easy start. My guess is that I may have purchased a 5-gallon container of gas when the local blend was still a summer blend. I use a gas stabilizer, but the EPA has forced many communities to change the "blend" every 6 months, hence, gas shortages, high prices, and snowblowers that won't start with one pull of a pull cord.
I'm getting up in years, So like I said, I will never buy another without an electric start.
Steve
__________________
Feedback
Old 02-10-2013, 08:46 PM   #64
IMStuner
Senior Member
IMStuner's Avatar
Default
I paid extra for electric start when I got my Honda HS 828 track drive and only use it once to try it out, that was 20 years ago. It's a awesome feature but I haven't needed it yet.
Old 02-11-2013, 04:46 AM   #65
Greatwhitewing
Senior Member
Absolutley nothing within 50 miles, not even another POS like mine...
Old 02-11-2013, 10:26 AM   #66
Herb
Senior Member
Herb's Avatar
I have wondered quite a bit lately, why aren't there any diesel engine snow blowers available? My two tractors and generator are diesel powered and they always start without the issues gasoline can present.
Herb is offline   Reply With Quote
Old 02-11-2013, 10:28 AM   #67
Farmall450
Senior Member
Farmall450's Avatar
Exactly.
__________________
Why Farm Half When You Can Farmall?
1959 1/4 HP Craftsman Pre-Block Restoration
Quote:
Originally Posted by countryroad82 View Post
I'm left handed so there are a lot of things that just don't seem right to me
Farmall450 is offline   Reply With Quote
Old 02-11-2013, 11:12 AM   #68
geotek
Senior Member
geotek's Avatar
1970's Yardman 7040-1 SnowBird. Purchased for $50 at a yardsale. Carb is messed up but still runs! Fires on first pull.
File Type: jpg Snowbird Blower 2013 First Use 5 - Copy.jpg (122.9 KB, 66 views)
__________________
If I knew what Plan B involved, I never would have given up on Plan A.
geotek is offline   Reply With Quote
Old 02-11-2013, 11:25 AM   #69
Super Scout
Senior Member
We have a 1953 Simplicity that starts everytime we need it. 3 pulls and it purrs like a kitten. Not sure if Simplicity's are still built that way or not. But they were certainly good units 60 years ago.
Super Scout is offline   Reply With Quote
Old 02-11-2013, 12:26 PM   #70
Cyclonegrey
Junior Member
Simplicity is the way to go. My small 22" 5 hp simplicity kicks the crap out of my neighbors 36" 10 hp warehouse store model. Had it for 10 years and never even hiccuped once! The neightbor is amazed how my "little" blower can just hammer through 12"+ without even slowing down. It's the small details that make the simplicity outlast and out perform the competition. Stronger gearboxes, better materials, HD component's as well as just thoughtful design makes them the best. I wouldn't get anything but a Simplicity. Pricey but like I said 10 years without a single failure is worth $$$ when you need it to start.
Cyclonegrey is offline   Reply With Quote
Old 02-11-2013, 02:25 PM   #71
Glacial_Speed
Senior Member
While it's fun to try to pull out the superman card and say "I've got a good shovel for any amount of snow", I finally figured being hunched over in pain for the next week is less fun.
I searched for a snowblower two years ago and ended up buying a used 2003 simplicity with a 305cc B+S motor (off ebay, from Agawam, MA). It's nice, channel type arms and a solid feel, and good features like a lever to unlock one wheel so you can turn it around very easily. And the electric start is a big plus if the briggs feels lazy.
Cyclonegrey is right, there's a number of small details that make Simplicity a good machine. Also like the 2 reverse gears.
The front is only about 20 inches high so I was having to make two passes on most of the driveway. I suppose I could have attached a board over the drift bars, but my driveway isn't THAT big. It never did bog down and I had to make sure I wasn't throwing the snow too high and filling in my neighbors driveway. It says 10hp on it, but the same 305cc displacement was also used on the 11 and 12 hp models.....hmmm.
Of course now I need to start up the chainsaw after the rain stops because of a few downed trees.
BTW If you need aviation fuel, AirNav.com will get you a listing of places by zip code (even in Massachusetts).
And always have a few extra shear pins for your machine, that end of driveway slop from the town plow is always full of ice and debris.
Glacial_Speed is offline   Reply With Quote
Old 02-11-2013, 02:32 PM   #72
Twomato
Senior Member
Twomato's Avatar
My Wife!
+ 1 + shovel.
Twomato is offline   Reply With Quote
Old 02-13-2013, 05:10 PM   #73
Greatwhitewing
Senior Member
I stopped by a dealer and he loves the Toro even over the Ariens. Said the 2013 models are Toro motors made by Toro in the USA. I am going to try to check on that info. I sure liked the features and layout of the powermax?
Old 02-13-2013, 05:58 PM   #74
ndoran
Senior Member
Gas goes stale real quick, more of an issue on small engines. The rule of thumb I have is: never use gas more than 30 days old and buy it from a station that has high turnover. I learned this again the hard way in the fall. I always store my blower with no gas in it. When I went to check the blower I put gas in that was left from the last cut of the fall grass about two months old. the blower would not start. Checked everything: spark good, compression good, opened the carb everything spotless no debris. Put it back together put fresh gas in it and started straight away.
ndoran is offline   Reply With Quote
Old 02-13-2013, 06:38 PM   #75
vartz04
Senior Member
vartz04's Avatar
Garden tractor (old heavy one) with a plow is cheaper than a snowblower if you have a place to store it. My cub cadet with a plow was $215. Needs a rebuild cause it smokes a lot but it runs and I used it all winter. Gonna put about $400 into it this spring rebuilding and repainting and it will be good for another 40 years. Starts every time i turn the key.
vartz04 is offline   Reply With Quote
Old 02-13-2013, 07:30 PM   #76
Kev442
Senior Member
Kev442's Avatar
If you don't want your carb/needle/bowl corroded, quit buying the cheapest octane gas with ethanol in it. The 91 octane around here is still real gas. Buy 2 gallons fresh in December and it'll make it to March, no problem.
Dad's: 1986 Simplicity w/B&S 8 hp
Mine: 1995 Murray Estate with 7 hp Snow King
Dad's cost twice as much and is almost twice as nice. The Snow King was/is a great motor though, no issues with it at all.
I pity the fools who buy the HD/Lowes crap with china motors.
Kev442 is offline   Reply With Quote
Old 02-13-2013, 07:54 PM   #77
Skin
Senior Member
If that was the knowledgeable people at a true small dealership that told you that inform them they need to update their information. They're Chinese engines 100%. You can call Toro's customer service and ask them for yourself (Toro has really great customer service). All Toro branded engines, without exception, are 100% made in China.
Old 02-13-2013, 08:08 PM   #78
zmaxmotorsports
Senior Member
zmaxmotorsports's Avatar
Quote:
My case 85xt snow shovel is diesel!
File Type: gif shrug.gif (275 Bytes, 373 views)
zmaxmotorsports is offline   Reply With Quote
Old 02-14-2013, 04:47 AM   #79
Greatwhitewing
Senior Member
Very interesting. He told me the NEW engines were made in USA with a straight face. Either he is woefully uninformed, a shiester, or there is new information you don't know or were told wrong by Toro? Someone is mistaken
I'll perhaps do as you suggested and call Toro.
The good news is my old POS blower did start yesterday so my primary issue is likely ethynal related and fixable with the right fuel and additive choices. A good carb rebuild might be in order as well.
Now to start working on the elctric start issue. Spinning starter motor. Hopefully that issue is only the starter pinion????
Old 02-14-2013, 06:48 AM   #80
afdavey
Junior Member
afdavey's Avatar
Default
Honda - GX engine - track drive...
Say no more.
Sent from my iPhone 5 using Tapatalk
afdavey is offline   Reply With Quote
Old 02-14-2013, 03:30 PM   #81
Senior Member
In my humble opinion most sales people do not know their products very well. I have seen this so many times it scares me. Check the facts yourself or toss a post up here and someone will be able to help with the reality, just like in this case.
Do you know what the difference is between a product Made in USA vs. one made in China? ..... A job for an American worker.
__________________
Old 02-14-2013, 04:04 PM   #82
Bkf350SD
Senior Member
I have quite a few snow accounts and i run Ariens 2 stage machines(with the tec snow king) and toro single stage machines.
I would buy a toro powermax if it had the briggs or tecumseh on it. Those are nice machines as well.
Bkf350SD is offline   Reply With Quote
Old 02-14-2013, 04:13 PM   #83
GTO
Senior Member
GTO's Avatar
I have an Ariens 824,works fine for me.
If I had the money and more snowfall during the winter I would buy a Honda Track model.
GTO is offline   Reply With Quote
Old 02-14-2013, 07:59 PM   #84
gordyy
Senior Member
gordyy's Avatar
Send a message via Yahoo to gordyy
Well for my money you can't go wrong with these
Either one eats it no matter what is in front of it
__________________
I am not a complete idiot
Parts of me are missing
gordyy is offline   Reply With Quote
Old 02-26-2013, 12:12 PM   #85
1320stang
Senior Member
1320stang's Avatar
So, my dad is 72 and mom is 68, they live in Enid, OK which got 10+ inches of snow last night. Just got off the phone with them and they're just finishing up an hour and a half of shoveling snow in their driveway. I'm guessing maybe 2400 sq/ft of driveway. Problem is, my sister & I live 1.5 hours away. We don't often get a lot of snow, usually sleet or ice, but I've been kicking around getting them a snow blower for a couple years. Not sure what to get, looking for suggestions, electric or gas?. They still get around great (they just shoveled 2000 cu/ft of wet snow, duh!!) but I'd like to make it easier on them. We would really like for them to move down to Edmond near us, but they're friends and such are all up there, as is my father's work.
__________________
_________________________________________________
Larry Hampton
1963 Fairlane 2 door post
1965 Mustang Coupe
1973 F-100 longbed
2002 Pontiac Grand Prix
2003 Explorer SportTrac
2005 Honda Accord
2008 Mercury Mountaineer
2015 F-150 Screw 5.0 2wd
Quote:
Originally Posted by raccoon View Post
PS: I'm a girl..
1320stang is offline   Reply With Quote
Old 02-26-2013, 12:34 PM   #86
kc-steve
Senior Member
kc-steve's Avatar
It'll probably melt in Enid OK before ya get a chance to buy one. Here. that's another story, but my Snapper is doing the job. Starting easily now that I have fresh gasoline.
Steve
__________________
Feedback
Old 02-26-2013, 01:11 PM   #87
skiingman
Senior Member
Quote:
Something no bigger than a 24. The bigger machines eat more snow faster, but unless you spend a ton of money they are more difficult to hustle around. A good 24 (a GOOD one) will do the job in no time and be a pleasure to use.
skiingman is offline   Reply With Quote
Old 02-26-2013, 10:55 PM   #88
1320stang
Senior Member
1320stang's Avatar
I'm guessing that's 24" wide? I'm a little uninformed about snowblowers as they don't really sell them down here......... or basements.
I'm likely going to have to order one or bring one from down north. When is the best time to buy? late spring?
What would be cool would be a convertible machine, snow blower in winter, rototiller in the summer. I need to call DR or get on that invention show with those two goofballs.
__________________
Larry Hampton
1965 Mustang Coupe
1973 F-100 longbed
2005 Honda Accord
PS: I'm a girl..
Old 01-28-2015, 05:31 PM   #89
rbunch4468
Junior Member
Really? A two year old snow blower thread?
My Ariens crapped out due to ethanol fuel jelly. I've learned ALOT in the past three days. DO NOT replace the Tecumseh carb with an Oregon POS China replacement. I did, and it sucks. I bought a rebuild kit for the original and now it starts on the first pull. I bought the Oregon carb locally because we had a storm approaching. After extremely hard starts, I was able to clear the snow from the storm, but the price was a worn out pinion on the electric starter. Oregon carb? What a POS. Storm has passed, and now that I've rebuilt the original... All is well.
Local small engine repair guy says Honda provides the best reliability. He has a Simplicity... and hates it!
rbunch4468 is offline   Reply With Quote
Old 01-28-2015, 05:43 PM   #90
chrisexv6
Senior Member
My ariens is now 8 years old. I've never once had to clean the carb. I store it in the off season after running through a mixture of trufuel, seafoam, marvel mystery oil and marine stabil.
Thing still starts on the first pull even after everything it's been through here in southwestern ct
chrisexv6 is offline   Reply With Quote
Old 01-28-2015, 06:58 PM   #91
kctyphoon
Senior Member
kctyphoon's Avatar
absolute, without question, the two best snow throwers (i REFUSE to call them blowers cause its so dumb) are honda and yamaha (if you can find one). i had an older craftman that worked good, but every season without fail, nuts and bolts would vibrate off the thing and leave me stranded.. after a few years, i sold it, bought a brand new Troy Bilt from lowes, used it once - is was horrible - sold it.. i bought a 25 + year old tracked Yamaha YS624. at 6hp - it will throw light snow as high as my second story roof.. no electric start needed - starts every year
when it come to anything that needs to be reliable, or actaully do what it says it will - you cannot do any better than honda or yamaha. generators, snow blowers - anything with an engine - yes - they are expenisive, but its usually a life - long machine..
http://youtu.be/Q1noho1NpNo
http://youtu.be/3cLt7nRl6zY
if you live, or have a connection in Canada you can get the new Yamaha's (only recently), but the old ones at 20+ years old are better then all the crap that sells at the home centers.. the wheeled throwers are just as good...
i used the brand new troy bilt on wet snow, - it wouldnt even make the heavy stuff clear the chute.. hallf what it tried to expell just fell all over the machine. might be good for light fluffy stuff - but anything with a little weight, your lucky with 4' ...
just for entertainment value - check out the new yamaha's - AWESOME
http://youtu.be/0lfFMW6TfrU
kctyphoon is offline   Reply With Quote
Old 01-28-2015, 07:09 PM   #92
kctyphoon
Senior Member
kctyphoon's Avatar
FOR ANYONE USING WHEELED SNOW BLOWERS WITH SKID SHOES--
i had these on a previous machine.. these are an absolute must have IMO.. makes life so much easier, and keep the front chute of the machine from getting bent and rusting from uneven sidewalks, driveway aprons...
http://youtu.be/dtYR0xbFSsk
AND another usefull mod for any snow thrower -
https://m.youtube.com/watch?v=EMAgb3QNEE8
Old 02-03-2015, 07:42 AM   #93
Butkusrules
Junior Member
The problem with Honda is that they are sometimes twice as expensive. I can buy cub cadet run it for 10 years then throw it away and buy another brand new one for the price of a Honda. There Honda is not that much better then cub cadet or anything else. Not to mention consumer reports says Hondas throw for shit but again probably not a huge difference from best thrower.
Butkusrules is offline   Reply With Quote
Old 02-03-2015, 08:57 AM   #94
Senior Member
theoldwizard1's Avatar
Off season MAINTENANCE !
  • Replace (upgrade) shoes/skids
  • Remove wheels and grease the shaft before the wheel "rust welds" to the shaft.
  • Remove the auger. Clean and grease the shaft.
  • Replace all rusty nuts and bolts with stainless steel.
theoldwizard1 is offline   Reply With Quote
Old 02-03-2015, 09:08 AM   #95
77thor
Senior Member
77thor's Avatar
I have an older Ariens w/Tecumseh Sno King engine... great machine.
Never had a breakdown(knock on wood)...
77thor is offline   Reply With Quote
Old 02-03-2015, 09:19 AM   #96
DonPowers
Senior Member
DonPowers's Avatar
Location: Northern Maine, On The Hair At The End Of The Dog's Tail
I bought an 8 hp TroyBilt in the early 90s and gave it to my son in law a few years ago, its still running. The newer MTD models may not be as good though.
Bought a Honda 828 Tracked machine in 07, fantastic machine, its like a little bulldozer and chews through anything. Has hydrostatic drive which can go from a slow crawl to very fast and anywhere in-between. Much better than the friction disk that most other machines use. Was 12 below yesterday and it started right up with the pull cord. Has electric start but I don't recall ever using it. Also, the honda will chuck snow 60 ft or so. It was around 3k when I bought it. A friend bought a used one this winter for $800.
Also have a Kubota BX2660 with heated cab and 50" front mount blower, bought in 09. A bit of overkill but comfortable and fast. Tractor also has plenty of other uses with loader and other implements.
DonPowers is offline   Reply With Quote
Old 02-03-2015, 09:42 AM   #97
CJM8515
Senior Member
CJM8515's Avatar
Have an 20 year old MTD, 5hp/24". Wish I had opted for the 8hp/28" model at the time but oh well. It clears things pretty well, doesnt like thick wet snow or harder packed snow all too much and will bog down. About 10 years ago I sucked up the paper and ruined the crank to the engine since it bent, replaced it with a tecumseh 5hp again and all has been well. The electric start is the only thing that doesnt work, but 2 pulls and ti fires right up.
Everything I own will fire right up no problem because I winterize everything and it then doesnt gum up the carbs.
CJM8515 is offline   Reply With Quote
Old 02-03-2015, 09:50 AM   #98
chrisexv6
Senior Member
Ive started using TruFuel in my winterization process. Drain out whatever remains at the end of the season, add a few splashes of TruFuel mixed with Marine Stabil (the blue stuff), Seafoam and a little MMO for good measure. Run the engine for a few minutes, then turn off the fuel valve and let the engine run until it dies.
Next winter when I start up I get lots of smoke coming out (smoke = good in this case). The carb has never once been gummed up for the 9 years Ive owned my Ariens 926LE. After this season I might treat it to a new friction disk, or at least have a spare on hand just in case (still on the original with no signs of stopping)
Old 02-03-2015, 09:53 AM   #99
BFHtime
Senior Member
I recently bought a used craftsman 9hp 29" snow blower. I think is from the 80's. It has a Tecumseh engine. It starts on the first pull, even at 0 degrees F. When I purchased it the owner was not sure if the electric start worked, because it was never used.
BFHtime is offline   Reply With Quote
Old 02-03-2015, 09:55 AM   #100
Skin
Senior Member
Quote:
Actually they are. You'll be sending your second or third machine to the landfill and the Honda will still be trucking along. Its not a brand without faults but their build quality is second to none.
Old 02-03-2015, 09:56 AM   #101
chrisexv6
Senior Member
Quote:
Yeah the Tec Snow King engines seem to be bulletproof. Guzzle gas and make noise like no tomorrow, but as long as you keep the oil level correct I dont think you can ever kill one.
Problem is its hard to find replacements so you either end up rebuilding what you have, repowering with something more modern (not necessarily an easy job) or buying a whole new blower.
Old 02-03-2015, 10:00 AM   #102
Senior Member
I live northwest of Boston and we just got hit with 30" last week followed by 15" yesterday. I just finished cleaning two big driveways and about 100' feet of walk with my 24 year old Ariens ST8/24. I bought my first Ariens in November 1971, ran it till 1991 then bought my present one. I gave the old one to my brother who ran it for another 10 years.
That's a combined 54 years using Ariens snow blowers up here in New England and not a single failure or disappointment in all those years.
Guess what brand my next slow blower will be?
__________________
Old 02-03-2015, 10:07 AM   #103
Nele
Senior Member
Hondas look mean and well built
Nele is offline   Reply With Quote
Old 02-03-2015, 10:07 AM   #104
PMD1966
Agree on the Ariens with the Sno-King engine. Thought it was expensive 12 years ago when I bought it. Other than a few shear pins in the impeller and oil and spark plugs it hasn't needed any repairs.
PMD1966 is offline   Reply With Quote
Old 02-03-2015, 10:07 AM   #105
Nele
Senior Member
Especially track driven ones
Old 02-03-2015, 10:37 AM   #106
Kracin
Senior Member
Kracin's Avatar
in my humble opinion, if people wanted the jobs, they would still be here. not to steal the thread, but there are hundreds of thousands of jobs available that nobody wants, cause it doesn't involve singing, dancing, or making youtube videos.
Kracin is offline   Reply With Quote
Old 02-03-2015, 11:23 AM   #107
ecotec
Senior Member
ecotec's Avatar
I bought my Honda HS622 in 2002 on a huge sale. It has been trouble free this whole time. If you set the choke and throttle it starts on the first pull. I have been quite lax in maintenance on it, and it still runs perfect.
We got our biggest snowfall since '74 the other day, and it handled it perfect. I have zero regrets.
ecotec is offline   Reply With Quote
Old 02-03-2015, 12:32 PM   #108
arms1970
Senior Member
I got an old Montgomery ward 24" 5hp. Got me through 21 inches in Chicago that just fell. Many winters before that. I was just finishing up and I did throw a drive belt. So I will replace that this weekend. No PLASTIC on this thing what so ever.
arms1970 is offline   Reply With Quote
Old 02-03-2015, 03:50 PM   #109
day
Junior Member
I have had 2 Toro blowers and they have performed awesome(I live in Colorado).
day is offline   Reply With Quote
Old 02-03-2015, 04:29 PM   #110
Rickster
Senior Member
Rickster's Avatar
Old 2-cycle Simplicity I bought used from a landscaping guy going out of business. Every spring I run it out of fuel and empty any remaining from the tank with an old turkey baster. In the late fall I get a fresh Premium gas & oil mix ready. Starts right up in the dead of winter. I may have replaced the plug when I bought it several years ago.. I can't remember, but the guy did throw in some new wheels and a base scraper that I installed.
__________________
Rickster
Everything is for sale!
My eBay Sales
Rickster is offline   Reply With Quote
Old 02-03-2015, 06:29 PM   #111
Casey69
Senior Member
Quote:
anyone know if the newer home depot Ariens snowblowers are any good, or are they just box-store quality with a premium price?
$1000 Ariens:
http://www.homedepot.com/p/Ariens-De...z0wwdxZ1z0uxk9
Casey69 is offline   Reply With Quote
Old 02-03-2015, 07:02 PM   #112
Showkey
Senior Member
Quote:
$1000 Ariens:
Post # 134 in the link below talks about the dozens of models and the different "grades" in the Ariens lines. Big box blowers may not be the same machine as the power equipment dealers. ????????
http://www.advrider.com/forums/showt...=540295&page=9
The snowblower debates are similar to the best pickup truck discussions. The link is 13 pages and 185 posts.
I just donated my 30 year old HS50 Honda blower to my son after his 15 year old Ariens became a maintenance nightmare. I purchased a used Honda 7 hp HS724 with hydrostatic trans with wheels
__________________
Honda ST1300, NC700, CX500 Turbo (2),
TRX500, TRX300, C70, CT70, XR250, ATC70 (2)
Sprinter RV, 93 Miata, 1950 GMC Pickup
Showkey is offline   Reply With Quote
Old 02-03-2015, 07:06 PM   #113
Skin
Senior Member
$1000 Ariens:
That model is identical to what you would buy at a small dealer. When you buy online they (Ariens) even pull them from the same warehouses and have independent dealers assemble and deliver them. The only Ariens I know of to be made to "box store" quality are the Sno-Teks.
If you can though support your local dealer. You aren't saving a dime going through Home-Depot and you wont get any favors from the dealers if you have out of the box troubles.
As far as the quality of the units, the engines are all Chinese from the Sno-Tek line all the way to the Professional series. I kind of hate them and many are suffering debris issues in the carbs. The unit itself is a great buy for a grand, but its a far cry from a Honda (two to three times the price) or your fathers/grandfathers snowblowers. Ariens has basically countered inflation by cheapening the units year after year. Go check the price tag for a machine in 1990 and I bet a comparable unit today is roughly the same price. That doesn't happen without some form of component cheapening. Great for people who are budget minded but less so for people expecting the quality of 20 years ago.
If yours is this type, refurbish it, don't buy new, you will be disappointed. The drive system on this model is essentially bullet proof and they've even replaced (superseded) the split aluminum gearcase with a nice cast iron model.
Old 02-03-2015, 09:02 PM   #114
Butkusrules
Junior Member
Sorry I'm a big Honda guy, owned 2 Acuras. But if you told me I could have a 10 year old Honda Accord or a brand new Taurus I'll take the Taurus.
Old 02-03-2015, 10:54 PM   #115
kctyphoon
Senior Member
kctyphoon's Avatar
the only problem with that scenerio is that cars have gotten better in the last 20 years, while most places that make snow throwers have figured out how to make the cheapest thing they can manufacture that can still be considered a snow thrower.. think to yourself if anyone is going to be bragging about owning a throw away troy bilt somone bought from Lowes 25 years from now.
my 6hp 25 yr old yamaha will throw light snow to the second floor of my house.. your lucky if a 7hp model today will throw anything mre than 5 feet.
Old 02-03-2015, 11:09 PM   #116
kctyphoon
Senior Member
kctyphoon's Avatar
im not saying cheaper models don't have their place - but you simply cannot compare the quality vs performance aspect.. its like comparing snap on and craftsman - except you can expect alot more maintenance over the course of owning a chinese knock off engine and a few snow storms where it wont start at all when you need it. (enter every cheap generator even made). many honda / yamaha items dont even have an electric start simply because its not needed.
Old 02-03-2015, 11:17 PM   #117
steed andersen
Senior Member
steed andersen's Avatar
Quote:
I am still repairing some of those old Montgomery Wards (Gilson) snow blowers. Solid,heavy metal on those old beasts. Some are from the early 70's and still going.
steed andersen is offline   Reply With Quote
Old 02-04-2015, 06:38 AM   #118
boosteddsm92
Senior Member
I'm going to say Honda but I don't think I could ever pay new price for one. I picked this HS828 up for $100 a couple years ago in perfect working order.
Already had a Yard Man 24" w/a Tecumseh Snow King 5hp motor. Never had a bit of trouble with it but I just couldn't pass up this Honda. This Honda throws snow further than anything I've ever seen.
boosteddsm92 is offline   Reply With Quote
Old 02-04-2015, 06:43 AM   #119
warmpancakes
Senior Member
warmpancakes's Avatar
I have a ariens 2 stage from the 80s, with electric start, pull start is broke, headgasket just blew, but it still throws snow its build like a tank and weighs alot, look like shit its loud. even with a blown headgasket it still throws snow further than the neighbors new blower
__________________
" if it can be done wrong, I've usually done it at least three times"
"If you want to walk the heavenly streets of gold.......you gotta know the password, "Roll, tide, roll!"
Bear Bryant
Note: This post may contain misspellings, grammatical errors, disorganized sentence structure, or may entirely lack a coherent theme. These elements are natural to the process of writing, and will only add to the overall beauty of the post.
warmpancakes is offline   Reply With Quote
Old 02-04-2015, 06:56 AM   #120
upgrading
Senior Member
upgrading's Avatar
Quote:
Lookin good.
You suck.
Someone I know just bought a new Ariens.
Has a very tiny gas tank on it.
upgrading is offline   Reply With Quote
Old 02-04-2015, 08:35 AM   #121
Senior Member
Quote:
Originally Posted by John316 View Post
Unquestionably, the pre-1990 Ariens, Craftsman, Toro were better built. Most of those had "real" transmissions and heavier gauge steel in the housings. About the only thing missing on some of those older units is electronic ignition.
Old 02-04-2015, 08:52 AM   #122
woody 73
Senior Member
I bought the following from sears new in 2005:
http://columbus.craigslist.org/for/4786847970.html
It has never let me down even for one second, starts every time never had the tank empty, changed the oil a few times and it runs like a champ. Not sure if that helps you out?
woody 73 is offline   Reply With Quote
Old 02-04-2015, 11:42 AM   #123
lars
Gravely Snow Cannon. It has that name for a reason.
https://www.youtube.com/watch?v=PZBfvdzH-pI
That coupled with a Gravely with a Kohler K series engine is nearly indestructible.
lars is offline   Reply With Quote
Old 02-04-2015, 12:55 PM   #124
arms1970
Senior Member
Quote:
All kinds of videos of these old beasts on youtube tossing snow like its nothing. My neighbor buys a new snow blower every 2 years it seems. If it doesn't start he runs to get a new one. Pencil pusher. Lol
Old 02-04-2015, 01:03 PM   #125
mazdarules
Junior Member
I love my yamaha YS1028J, its a beast.
mazdarules is offline   Reply With Quote
Old 02-04-2015, 04:31 PM   #126
Hop2it
Hop2it's Avatar
I have a 1975 ariens 5 hp it works great we just had a storm that left about 14-16" it sure saved my back.
Doug
Hop2it is offline   Reply With Quote
Old 02-04-2015, 05:03 PM   #127
Jlbc212
Senior Member
Jlbc212's Avatar
Honda! Love my HS928!
Jlbc212 is offline   Reply With Quote
Old 02-04-2015, 05:18 PM   #128
upgrading
Senior Member
upgrading's Avatar
Quote:
That big blue meanie looks cool.
Old 02-04-2015, 06:48 PM   #129
rtole
Senior Member
I know a guy around here that has many nice older ones he has repaired. He doesn't advertise on bisman.
rtole is offline   Reply With Quote
Old 02-04-2015, 07:03 PM   #130
rtole
Senior Member
I had to buy one a few years ago, while I think the Hondas are the best of the newer machines, I was not able to pay that much so I had to compromise. I went with a JD 928 e. It has a 14 inch impeller and most of that size have a 12. (In the consumer grade lines) my JD is the same as a simplicity. It will throw really far, but shear pins always break if you get into frozen snow. I am only slightly happy with it, but neighbors got craftsman, and mtd........they break all the time. If I could go back, I would rather had something else, but I was strapped for cash and could not buy a Honda at the time. Now I will use it as long as I can.
Old 02-04-2015, 07:17 PM   #131
kctyphoon
Senior Member
kctyphoon's Avatar
thats probably the best deal on a Honda in that condition ive ever heard of.. you could probably get about $1500 for that.. some guy was selling a track model that size for $350 - i emailed him at midnight and said consider it sold it you still have it.. (of course it was already gone)
i paid $800 for my tracked yamaha ys624 from the original yamaha dealer that ordered it new... telling people i paid that much for something thats probably from the 80's doesnt come without its looks - but clearing the snow in front of my house using one hand gets its share of looks too..
Old 02-04-2015, 08:45 PM   #132
Beaumont67
Senior Member
Beaumont67's Avatar
Default Re: Most reliable snow blower?
Living out in the country, my dedicated 1992 John Deere 318 with hydraulic 1 stage blower (48" wide) gets the job done.
Had some 2-3 foot snow banks here, this week and does a fair job, scraping snow close to the pavement.
Few weeks ago, changed the oil from Mobile1 to AMSOIL (10w30, 4 stroke synthetic) and installed a NAPA Gold WIX filter.
(hour meter at low 502.4 run time, on the 18HP Onan, original paint garden tractor)
- few weeks ago, installed a Canadian Tire blue top AMG truck battery and bought one new 4 ply front right tire
- nothing stopping JD this winter
Old 02-04-2015, 08:51 PM   #133
fanatic
Senior Member
fanatic's Avatar
I have an Ariens that is about 4 years old and like it a lot but, it doesn't take abuse like the older units.
I replaced the drive disc last year, not sure what engineer thought that thin rubber vulcanized on a metal disc would be a good drive system but, other than that I haven't been able to break anything else....yet.
fanatic is offline   Reply With Quote
Old 02-04-2015, 09:09 PM   #134
chrisexv6
Senior Member
Friction disc drive setup has been around for a LONG time. My Ariens is now 9 years old and I havent replaced the disc even once. Im buying a spare to have around but its still going strong on the original.
There is a procedure in the manual for checking the tension on the engagement cable/spring....you might want to check on that. Maybe its engaging too much or not enough and causing premature wear on yours.
Old 02-13-2017, 06:13 AM   #135
kctyphoon
Senior Member
kctyphoon's Avatar
Mines 30 years old and still going strong.. every year all I do is spray some carb cleaner in the carb, drain and replace the old gas, and it starts every year no problem.
Old 02-13-2017, 06:31 AM   #136
ilovevocs
Senior Member
That's a you suck deal.
Casting a vote for Honda.
ilovevocs is offline   Reply With Quote
Old 02-13-2017, 08:17 PM   #137
IMStuner
Senior Member
IMStuner's Avatar
I had this Honda since 1994 and it's been reliable.
IMStuner is offline   Reply With Quote
Old 02-13-2017, 08:30 PM   #138
F150tech
Senior Member
I have had an Ariens st824 for 15 years, change the oil and the spark plug every season, never has it failed me even in some of the blizzards we have had in the northeast over the last few years. It has the Tecumseh snow king engine.
F150tech is offline   Reply With Quote
Old 02-13-2017, 08:30 PM   #139
someone else
Quote:
I've got a 928E as well, but aside from the basically 1 sheer pin a year, it's been stellar. Fires every time, runs great every time, clears snow, every time.
someone else is offline   Reply With Quote
Old 02-13-2017, 09:45 PM   #140
dkmc
Senior Member
Location: Upstate NY, in the Flats near the corn fields
I had an MTD 8HP I got cheap with low hours.
The thing was a pile of tin and belts, POS.
Sold it and bought an older Skid Steer.
Haven't hardly had any snow last 3 winters to use it!
dkmc is offline   Reply With Quote
Old 02-13-2017, 09:59 PM   #141
MacMcMacmac
Senior Member
MacMcMacmac's Avatar
I was looking at the Yamahas a few years ago. Absolutely awesome machines.
Don't buy any of the cheap Murray units. I bought a Brute 27" at WalMart a few years ago and hate it. Feels cheap, and it has a mind of its own as to when it will decide to drive the wheels or not. Snow gets in on the disc and it just sits there. Unless the platter backs off its bearing, and then it drives itself all the time and you have to go chase it down the road. That was a cold repair job! Blowers must have the worst use to repair ratio of any type of power equipment.
The motor has been ok (Briggs), but the muffler shield split the first winter. I agree that a 24" would be the sweet spot for size. The 27 is a bit of a handful in a tight driveway.
MacMcMacmac is offline   Reply With Quote
Old 02-14-2017, 08:00 AM   #142
kctyphoon
Senior Member
kctyphoon's Avatar
I bought my sister a cheap used craftsman a few years ago. It's a 5hp, single speed dial stage, and I gotta say the thing was pretty impressive when I used it. It's small, 22" I think. Doesn't throw snow very far, but it always works and is great for those small storms we get..
Old 02-14-2017, 08:28 AM   #143
maxpower_hd
Senior Member
Mine is a 1964 Areins and I have never had much of an issue with it. IMO you will not find anything as simple to use or troubleshoot now. I changed the belt this season for the first time. I have owned it since 1993. I do have to remove and clean the carb every couple of seasons. I typically clean the plug at the same time. I change the oil yearly. That's about it.
__________________
"I don't fail. I succeed at what doesn't work." -Chris Titus
maxpower_hd is offline   Reply With Quote
Old 02-14-2017, 08:47 AM   #144
thickhead
Senior Member
thickhead's Avatar
Quote:
Just seeing one of those again made me both nostalgic and pissed off at the same time. I spent many, many winters dealing with one just a bit older than that one.
My Ariens 11528DLE has been doing 4 driveways (help neighbors) per storm for the last 8 years without a fault, but dont buy from a big box store - go to a dealer.
Otherwise I'd get a Honda, but would love to try a blue Yamaha beast!
thickhead is offline   Reply With Quote
Old 02-14-2017, 09:11 AM   #145
chrisexv6
Senior Member
I have an Ariens 926LE that I bought, new, from Home Depot back in 2006. It was on clearance (oh the days when they stocked WAAAAAY too many blowers and after Feb you had your pick of massively discounted new blowers)
Here we are about 11 years later and the thing still starts on the first pull. I upgraded it to AutoTurn last season, but other than that and oil changes the thing has done everything Ive asked of it with no issues along the way.
If I had to buy another blower today, there is no question it would be an Ariens. If I could get a stellar deal I would buy it from HD again, but if not Id give my local dealer the $$$.
Old 02-14-2017, 09:16 AM   #146
Weird Tolkienish Figure
Senior Member
I run my SB dry at the end of every season. I will be purchasing a fuel pump this year to siphon the gas out.
Weird Tolkienish Figure is offline   Reply With Quote
Old 02-14-2017, 09:30 AM   #147
Tonellin
Senior Member
Ariens 1128 with tecumseh engine. Starts and runs flawlessly every time with nothing more than new oil and spark plug every season
I've read many threads about NOT buying your snowblower at a box store. There is a reason why they are hundreds of dollars less than your local power machine dealer like plastic being substituted in wherever possible.
Mine was bought from a Ariens dealer over a decade ago and has been worth every penny. Weighs well over 300lbs and shows no sign up slowing down with these tough new england storms
Tonellin is offline   Reply With Quote
Old 02-14-2017, 09:37 AM   #148
chrisexv6
Senior Member
Back when the 11528 and my 926LE were "new", there were plenty of posts by snowmann (I think his real name was Paul?) talking about how Ariens did NOT make models different for HD than for dealers. There were some dealer exclusive models (as there still are), but a 926LE, 11528LE, etc at Home Depot were exactly the same as at a dealer. And if you think about it, why would anyone want to spend money on a production line to make something "just a bit different" depending on its destination location?
NOW, yes, you can buy the black Sno-Tek models and they are definitely watered down compared to the "real" orange colored Ariens models. But it sure looks like a Deluxe 30 from HD is the same as a Deluxe 30 from a dealer. Obviously your support network is better from a small dealer (or, not, depending on your dealer) but machine wise I still think they are apples to apples if the model is the same.
What I find interesting is my local Lowes....all the John Deere blowers they've had in the past have dealer stickers right on them. Seems like they are all assembled and setup by a local dealer before being for sale at Lowes. I think thats changed (not even sure they carry JD anymore?) but its interesting that I could have gotten a "dealer" prepped John Deere from Lowes.
Old 02-14-2017, 09:47 AM   #149
Tonellin
Senior Member
Interesting thanks for the clarifying information. That makes a lot more sense than ALL ariens snowblowers being different whether you buyer at dealer or big box
Old 02-14-2017, 10:06 AM   #150
PMD1966
Ariens STE824. Purchased 1998. Sta-Bil and drygas in the gas. Change spark plug and oil every year. Electric start, but starts with one pull at 5 degrees. Tecumseh engine.
Old 02-14-2017, 10:27 AM   #151
Senior Member
Quote:
I don't think they are sold in the US anymore ! Canada, yes.
The biggest problem with 2 stage snow blowers is lack of maintenance. Simple things like removing the wheel and drive sprockets ever few years, cleaning the shafts and then lubing them before reassembly.
Old 02-14-2017, 01:56 PM   #152
kctyphoon
Senior Member
kctyphoon's Avatar
There's a guy in Staten island advertising one on eBay.. he musta smuggled it in from Canada.. had it advertised on there last year too..
Old 02-14-2017, 02:41 PM   #153
diggerrick
Senior Member
diggerrick's Avatar
Laugh all you want, but I've had a 2-stage Craftsman snow blower going on ten years, and the only problems I've had are a couple broken shear pins (my fault - they did their job), and the chute rotating rod popped out once. It starts every time (electric start) even after sitting for months. I keep the tank full.
diggerrick is offline   Reply With Quote
Old 02-14-2017, 07:57 PM   #154
94EG8
Senior Member
The best snowblower you're going to find is a Honda. I've worked on just about every major brand of 2 stage machine out there, a lot of them in large numbers. You never see Hondas with starting issues. You just give them a single half hearted pull and they go. Beyond the fact that they always start they also throw snow way further than anything else, and then general construction is better than anything else. They're heavy where they need to be, but light in areas that don't need the extra strength so the machine doesn't weigh a ton. The hydrostatic transmission is great too, and I can't say i've ever seen or heard tell of anything having any issues with it. You can't really appreciate just how much better they are until you use one.
assuming you don't want to spend 2+ grand for a new snowblower you're left with just 2 engine choices. Chinese Honda clones which suck and Briggs and Stratton which suck less.
I used to do this for a living, those Chinese Honda clones are way better engines than a lot of people seem to think. They're light years ahead of the old the old Tecumseh Snow King engines, and somewhere between a B&S and a real Honda. Very close to a real Honda depending on the brand of clone.
94EG8 is offline   Reply With Quote
Old 02-14-2017, 08:55 PM   #155
Skin
Senior Member
Quote:
The problem is generally not with the block or crank, its the bits bolted on around it. They're garbage, comparatively speaking. One of the biggest issues is the use of metal tanks, being super cheap, and not cleaning them. Powermore (MTD) sticks a magnet in them to collect filings which then just sit in the tank. LCT (Ariens/Husqvarna) doesn't do anything so they migrate into the carb and cause running problems. Also plenty of broken recoils and dry rotting rubber. A Tecumseh isn't going to win any innovation awards and stinks to hell when running but they were reliably built and would run for decades. Im not seeing remotely close to the same reliability in the new stuff. Some of the designs make you want to throw the whole thing into the dumpster too like having to dismantle most of the engine to replace an electric starter.
This is an old thread but Briggs aren't much better anymore since everything for the last few years has also started coming out of their China facilities but their QC seems set to a higher standard. Not too much to complain about with the Loncin Toro's either.
Its not the fact that its made in China, its the fact that its poorly made in China.
Yamaha has their entire snowblower made in China-as are Subaru Robin small engines which were also quite decent (short lived in snow applications though). Point is if these other equipment manufacturers would stop being so cheap we'd get a better product.
Skin is offline   Reply With Quote
Old 02-14-2017, 08:59 PM   #156
cgrutt
Senior Member
cgrutt's Avatar
Had a few snowblowers over the years. Snapper, Toro, Craftsman. By far the best one was a Massey Ferguson but that was made for a subcompact tractor. Thing was a beast. I used to do my neighborhoods sidewalk about 1/2 mile every snowstorm. Currently have a 38" Simplicity which is pretty nice. They all worked well though.
__________________
www.AvidArms.com
cgrutt is offline   Reply With Quote
Old 02-14-2017, 09:04 PM   #157
timbitca
Senior Member
timbitca's Avatar
Love my Yamaha YS624 from the early 90s. Got it free from my Dad who was the 2nd owner. Need to put new belts in it, didn't have time since I got it when winter was already started but it still works fine. It just shoots like a Craftsman does instead of a Yamaha.
Barely used it in January but used it enough in the last two days to make up for that. 1.5' of the white s*** fell and calling possibly for another foot Thursday.
This summer its going to get a tear down with some more new parts and maintenance that's overdue.
Sent from my A0001 using Tapatalk
timbitca is offline   Reply With Quote
Old 02-14-2017, 09:22 PM   #158
Packard V8
Senior Member
Quote:
Originally Posted by Greatwhitewing View Post
My POS Home Despot blower let me down again finding Nemo. I just had it serviced and wouldn't even sputter when I needed it most.
Looking for the best brand for reliability starting. Ariens seems to be pretty well reviewed.
Nothing better than going to the tool geeks though... I mean that in the best possible way..
My Simplicity is only 40 years old, so I can't speak to how long it will last, but the Briggs & Stratton 8hp still starts first pull every time.
But in real terms, starting and durability are two very different factors. Starting is the engine manufacturer and has nothing to do with Ariens. Durability is how well the components other than the engine are designed and built.
jack vines
Old 02-14-2017, 09:35 PM   #159
James-W
Senior Member
I have a Toro snowblower that I bought back in the early 1980's. In about 2005 I had to replace the Briggs engine. Originally it had a 3.5 HP engine on it, now it h as a 5.5 HP engine. Works great and I have not had any problems with it other than the engine replacement and I had to have the gearbox rebuilt once. So in about 35 years I have had two things go bad on it. I would say it has given me pretty good service.
James-W is offline   Reply With Quote
Old 02-14-2017, 10:05 PM   #160
MN_Runner
Senior Member
I have a 2011 Honda HS928WAS, which was bought new. It has been a great machine without any issues. It is very easy to start and maintain. I also have a 2013 HS520AS and it is perfect for those 2"-5" snow. I recommend Honda snowblowers and lawnmowers.
MN_Runner is offline   Reply With Quote
Old 02-14-2017, 10:15 PM   #161
kctyphoon
Senior Member
kctyphoon's Avatar
I did this to my YS624 - https://youtu.be/EMAgb3QNEE8
Throws light snow as high as my second story roof...
Old 02-15-2017, 08:29 AM   #162
timbitca
Senior Member
timbitca's Avatar
That's a great idea, would have never thought about that. I'll have to add that to my to-do list. Definitely won't have time to do it for this storm, but I may have time to get to it in the coming weeks, if not hopefully I remember this summer.
Old 02-15-2017, 08:31 AM   #163
chrisexv6
Senior Member
It helps more in certain cases, based on the clearance between impeller and auger housing. I think the clearance on my Ariens is about 1/4" so it might help, but not as much as those with larger clearances.
Judging from the fact that I actually hit my neighbors house with small ice chunks over the weekend (luckily I didnt break any windows), throwing farther isnt necessarily a good thing
Old 02-15-2017, 09:22 AM   #164
cgrutt
Senior Member
cgrutt's Avatar
I like the idea alot but would be concerned about throwing impeller out of balance which could cause rapid deterioration of shaft/housing, etc. Also would consider using stainless nuts and bolts for attachment vs self tapping screws considering the environment.
__________________
www.AvidArms.com
Old 02-15-2017, 09:54 AM   #165
bmwpowere36m3
Senior Member
Quote:
I wouldn't worry about it... considering the mass and speed of the impellor. You could always do it on two paddles (180* apart).
bmwpowere36m3 is offline   Reply With Quote
Old 02-15-2017, 12:37 PM   #166
covert
covert's Avatar
My 16 year old Craftsman with a Tecumseh engine is a tank. Did a full rebuild in the summer, runs like a top. Used ones are very plentiful here in the Great White North, and if the engine ever dies, I can just swap it out with another. I'd suggest looking for a used but well maintained one; we have a ton show up for sale in the spring. Also keep eyes open at yard and estate sales, or people who are downsizing (eg. older folks moving into a retirement home or smaller place with yard maintenance). Deals are out there.
covert is offline   Reply With Quote
Old 02-15-2017, 01:22 PM   #167
Bluejoe
When it comes to tools or equipment it's best to purchase a good brand that has been around. One reason is quality of equipment and that when it breaks down or needs maintenance parts there available. Nothing against Sears but one day I needed a part for an older snowblower. The guy at counter said it's a 20 plus year machine and parts are discontinued. There was no internet or EBay at the time. This is a piece of equipment that you should only need to buy once so purchase a decent brand. Most people don't like to spend a lot of money on anything only to use it fours months out of the year. I think Ariens or toro would be first place to start. Just purchase the correct one for your needs.
Bluejoe is offline   Reply With Quote
Old 02-15-2017, 01:42 PM   #168
kctyphoon
Senior Member
kctyphoon's Avatar
I wouldn't worry about it on the grounds that the snow your throwing through the impeller is not balanced to begin with..
Old 02-15-2017, 01:53 PM   #169
rlitman
Senior Member
The impeller is mild steel. Galvanized (or even just zinc plated for that matter) screws are more than corrosion resistant enough. Keep in mind that you're snowblowing BEFORE applying salt, not after.
Quote:
Yes. Do two vanes, 180 degrees apart. I've never seen a snowblower impeller with an odd number of vanes. Four is the most common, though the monster at my office has 6.
I would not suggest doing more than two vanes. It just puts unnecessary drag on the engine.
rlitman is offline   Reply With Quote
Old 02-15-2017, 02:04 PM   #170
rlitman
Senior Member
That's a reasonable argument. Not sure how much cooking you do, but are you familiar with a Kitchenaid mixer? They now make a beater attachment that has a silicone wiping edge that scrapes the bowl as it turns. The genuine Kitchenaid version only has one rubber edge. The fake aftermarket ones have two (or more). What I've read, is that the extra strain from the two edged ones can damage the motor.
Kitchenaid:
Aftermarket:
Old 02-15-2017, 03:51 PM   #171
kctyphoon
Senior Member
kctyphoon's Avatar
When I modified my impeller, I bought a new straight paddle from HD, cut to size and used self tappers I think. Left zero clearance and used the pull cord to judge which one was too tight and then just took it down with a rasp.. figured friction would do the rest and let them wear in. My thrower NEVER clogs, and like I said, throws snow higher than anything else I've ever owned.
One of the cops even stopped to complain cause it was going so high in one direction, the wind was blowing some back into the street.. police hate that here in jersey. It's funny, when I lived in Staten Island and Brooklyn, you shoveled snow INTO the street so the plows could push it away. In Jersey they act like you're planting an I.E.D on the roadway god forbid any snow touches the pavement.
Old 02-15-2017, 04:17 PM   #172
kctyphoon
Senior Member
kctyphoon's Avatar
I'd respectfully disagree with this.. it's really a machine designed to throw weight, and be operated under some degree of strain, like a generator.. still, if it's not a powerful engine, just use a penny as a spacer between the added paddle and housing if that's a concern. The actual size the paddles wind up being cut down to are very small. Much smaller than you'd imagine.. The added weight is really insignificant. Once installed, If you can pull the cord without feeling any strain or resistance, there should not be any problem. I left mine slightly snug, and after running my thrower though one cleanup, I could not even feel any drag afterwards when I pulled the pull cord. I've had mine like this for 2 seasons I think, not including this one (since I still haven't needed to use it yet). It really does prevent any ice build up, and just helps to remove a bit more snow..
I always enjoy the "holy shit" look on people's faces when they drive around seeing most people's machines throwing snow 5 feet away, and then they pass my house.. lol
Old 02-15-2017, 04:35 PM   #173
rlitman
Senior Member
Disagree with the drag part? I agree that if it doesn't fight you when you pull the cord, you should be good to go. Ok, how about this wording? "Any more than two rubber wipers is not beneficial."
As for spacing, when I shot the screws in mine, the rubber shifted a little, and the whole impeller wanted to stick. I trimmed the tips of the rubber with my Fein tool until it just scraped the housing. You could hear it rubbing when you turned it over by hand, but not any more after the first serious use.
Old 02-15-2017, 07:18 PM   #174
Advan
Senior Member
Advan's Avatar
I've seen it all, and I'm going with Yamaha, Honda, and 25+ year old Ariens. Everything else is light-gauge, Chinese-engined shit.
Advan is offline   Reply With Quote
Old 02-15-2017, 08:35 PM   #175
oldldh
Senior Member
oldldh's Avatar
SNOW???
What is that???
I'm unfamiliar with that term...
What could it be???
(We're having a cold snap at the moment...)
Mid 60's...
Mid 70's by the weekend...
__________________
It's my fantasy...I can make it as big as I want...
Young men have fantasies...Old men have delusions...
I speak three languages fluently---English, Sarcasm, and Profanity...
oldldh is offline   Reply With Quote
Old 02-15-2017, 08:45 PM   #176
MikeF2316
Senior Member
MikeF2316's Avatar
Mine has 3 blades. It's hard to get a good picture, with the gearcase being so shiny and in front of it. But now you can say you have seen one with an odd number of vanes.
__________________
That which cannot go on forever won't.
If you have one foot in a bucket of boiling water and the other in a block of ice at -40, on average you're comfortable!
MikeF2316 is offline   Reply With Quote
Old 02-15-2017, 09:05 PM   #177
kctyphoon
Senior Member
kctyphoon's Avatar
Quote:
The old yamaha's have a 3 blade impeller.. the small 2 stage Troy Bilt models also do.. I wouldn't be surprised if a lot are like that.
Old 02-15-2017, 09:22 PM   #178
cgrutt
Senior Member
cgrutt's Avatar
There are alot of three blade impellers actually. Toro, Ariens, MTD, Craftsman, John Deere, Cub Cadet all made models using them.
__________________
www.AvidArms.com
Old 02-15-2017, 09:35 PM   #179
btdobie
Senior Member
btdobie's Avatar
Just stopped by to drop in another vote for Honda. I have an HS50 that's almost 20 years old. Never more than 2 pulls even after storage.
__________________
Sometimes what you do to your garage is just as fun as what you do in your garage.
Check out my step by step DIY natural gas line install.
http://www.garagejournal.com/forum/s...d.php?t=343945
btdobie is offline   Reply With Quote
Old 02-16-2017, 06:59 AM   #180
whofan
Junior Member
Toro power Max snowthrower are good machines.
NO shear pins and they don't clog up.
whofan is offline   Reply With Quote
Old 02-16-2017, 07:29 AM   #181
Tonellin
Senior Member
Why is no shear pins a good thing?
Old 02-16-2017, 08:53 AM   #182
rlitman
Senior Member
Ok then. I guess I'm not all that surprised either. All I can say is that the number of snowblower impellers I've looked at up close could be counted on my fingers and toes.
It helps more in certain cases, based on the clearance between impeller and auger housing. I think the clearance on my Ariens is about 1/4" so it might help, but not as much as those with larger clearances...
Yes, the more the clearance, the more of a difference it will make.
Closing the gap up prevents clogs, but the real reason that the snowblowers throw further with the mod is because the increased radius increases the vane tip speed.
On my Ariens, the impeller spins at 1090RPM (gauged by my laser tach with the throttle set to rabbit). Increasing the impeller diameter from 13.5" to 14" (closing the 1/4" gap), brings your tip speed from 3852FPM to 3995FPM. On the big machine at work, the gap is around 5/8", and closed, the tip speed can reach 5500FPM, which puts you into the blowing snow up and over hills territory.
Old 02-16-2017, 08:56 AM   #183
rlitman
Senior Member
Because shear pins suck. They're a cheap/easy solution to a man-made problem. The problem is that many machines use a shaft off the impeller that drives a worm gear that runs the auger, and a jam in the auger will damage the worm gear without shear pins. But that's not the only way to do it, just one of the cheapest.
Another option is to run a shaft with a belt driving the auger directly. The machine at work has separate PTO powered hydraulic motors for both the auger and the impeller. That arrangement allows you to drive them in reverse to clear a jam without leaving the cab.
Old 02-16-2017, 09:24 AM   #184
polizei1
I've been using a Toro Power Max for a few years now, works great, no complaints.
polizei1 is offline   Reply With Quote
Old 02-16-2017, 09:54 AM   #185
timbitca
Senior Member
timbitca's Avatar
The new Yamaha units don't have shear pins either. From what I understand they aren't available in the USA?
Old 02-16-2017, 09:55 AM   #186
kctyphoon
Senior Member
kctyphoon's Avatar
No, nearest place to get one is Canada if you have the means..
Old 02-16-2017, 10:07 AM   #187
maxpower_hd
Senior Member
Well I have an update. I guess I should not have posted about my 1964 Ariens because the next day I broke the handle off. I was able to tack weld it and get through the rest of the storm but it broke again right at the end of what I had to do.
Now (another thread) I had to clear the snow raked off the roof with a torn bicep and my machine is now broken. I went and got me an Ariens Platimum 24 SHO. I have to say it is a BEAST! So the old one is still running and can be fixed. But I'm thinking 53 years might be enough. Especially since now I know how good this new one works.
I was sending packed snow bank snow 35 feet and plastering my neighbors house with it! I have to be more careful now. LOL
__________________
Old 02-16-2017, 11:19 AM   #188
Skin
Senior Member
They don't use a purpose made shear pin, they never have. They've always used a grade 5 bolt but if you jam something you can still break it. I've also seen them not break and continue to practically cut the shaft of the auger in two which is impressive. Toro builds a very strong auger gear case.
That said just because another brand uses shear pins doesn't mean they always work either. I had this gem last year.
IMG_1784
Old 02-16-2017, 05:45 PM   #189
AJ1978
Senior Member
TORO 421 I used this little 4 HP MONSTER when I was a kid growing up, still works and is a backup for my parents.
Most of these new machines are just not built to last, I am following this thread. I have a early 2000's MTD 10 30 its a good machine but quality even then is lacking.
AJ1978 is offline   Reply With Quote
Old 02-16-2017, 07:01 PM   #190
timbitca
Senior Member
timbitca's Avatar
Well, something had to give at some point. I've been bragging the thing so much here that you knew it had to break at some point. Throttle cable on the Yamaha snapped just as I was finishing up tonight. I did sort of abuse it this week though...
For starters here's what the yard looked like on Jan 25th, I snapped this picture to send to my family up north in jest because we had gotten a "storm" that morning, mind you we hadn't gotten snow in nearly a month, and they had about 7' of the white stuff up home. (I might have poked the giant here, think I'm paying for it now)
Got this dumping on Feb 10th, sign of things to come... Old girl blew through this like nothing.
On Sunday/Monday we got this, went out twice to blow on Sunday and still had this to deal with on Monday afternoon.
This was the backyard after I had to re-route my little road (little harder to see because of the lighting but it's on the left):
And this was today, another full foot of snow fell again:
Yamaha took it like a champ though, takes to snow like a fat kid to candy, the more you shove in it's face the more it gobbles down. Blew right through this bank the nice plow man left for us:
Look at the snow on the other side of my garage!
Just as I was getting done widening the driveway the damn throttle cable snapped, sucks especially that I just replaced it 3 months ago.
I was probably going to buy one of the new 624's if my father wouldn't have given me his. A friend of mine has a new 928 and it's a beast! I'd love a new one, but even if I throw 200$ of parts at this one per year I'm still good for 10 years before paying a new one.
If there's ever talk of them leaving the market again though, I will be buying one for sure.
I might need your help too if you can... Will need to order a new throttle cable (again) and while it worked the way I had it setup, I'm still not sure I had it in there the right way and looking at the blown up diagram, I think I'm missing a few small parts and I just can't visualize how they go together.
tl;dr we got over 2 feet of snow in a week (not counting what the wind brought to me), and I broke my blower.
Old 02-16-2017, 07:07 PM   #191
Ike4160
Junior Member
Love my Honda 928 track drive. It has cut through multiple feet of snow and starts every time. I don't even bother getting it out of the garage unless there is atleast a foot of snow. Tractor with plow does the small stuff.
I installed an hour meter on it and logged 10 hours during first weekend of ownership.
Ike4160 is offline   Reply With Quote
Old 02-16-2017, 09:13 PM   #192
kctyphoon
Senior Member
kctyphoon's Avatar
If you need any pics, just let me know what you need..
If this helps any in the meantime, I keep all these pics saved on my iPad. Luckily the website name is on them. Check it out.
http://www.cmsnl.com/yamaha-ys624t-s...?model_q=ys624
Parts are pretty scarce as I'm sure you know.. we have to pray the tracks never break.
Although, there's always this option. Only new machine in the states I know of, and happens to be right by me.. been on eBay since last year as far as I know...
http://pages.ebay.com/link/?nav=item...d=252710674113
Old 02-16-2017, 09:18 PM   #193
timbitca
Senior Member
timbitca's Avatar
Thanks!
I have all the schematics. I found a zip file years ago online with a bunch of manuals. When my father gave me the blower I sent them to the print shop at work and had them put in a binder to keep out in the garage. Comes in handy.
If you look at the control cable schematics, I don't have parts 11-18 and I think that might be part of my problem, but without having seen them put together (father had broken the cable also and the guy who "fixed' it for him did it half assed.) So I don't have anything to go on besides the schematic.
Old 02-16-2017, 09:46 PM   #194
kctyphoon
Senior Member
kctyphoon's Avatar
Thanks!
Either of these help? Not sure I captured what you need.
That little latch deal just allows both handles to be held engaged with just holding the left handle down.. nothing like removing snow with one hand..
Old 02-16-2017, 09:49 PM   #195
94EG8
Senior Member
Quote:
Honestly, we had far fewer problems with those Chinese carbs than we had with the Tecumsehs. I did worked on some Powermores. I can't remember if I worked on any LCTs or not but I did go to a training seminar on LCT. The only cool thing I remember was they either had or were planning to build engines that had an identical footprint to the old Snow Kings so they could be used as a direct replacement. For what it's worth I've seen tons of Tecumseh Snow Kings throw rods. I've seen tons of carburetor issues with them, seen lots of exhaust valves too tight, mufflers that break off from the excess vibration and tons of broken recoil starters. Yes the carbs are simple enough to service (especially compared to the old B&S Sno Guard FloJet carbs), but the bowls are paper thin and develop leaks, the original brass floats again are paper thin and develop leaks. The engines vibrate so bad mixture screws never seem to stay adjusted and on the newer fixed jet versions they're set so lean you need to run with choke on the first notch far longer than you should have to. The old OHV Snow Kings for the late '80s used to kick back so badly they would break your wrist (or in some cases your jaw) Tecumseh's fix? Retard the mechanical timing one tooth. That has to be one of the biggest hacks I've ever seen. I have done a couple of them and it does work and the engine runs well after, but I can't believe they wouldn't come out with redesigned camshaft. Tecumseh dug their own grave and I wont miss them. I will say they did have a good ignition system though.
We used to put quite a few cams in B&S engines, the compression release would fall off sometimes.
Quote:
Honda discontinued the HS50 over 30 years ago, that thing is older than you think.
Old 02-16-2017, 10:32 PM   #196
Skin
Senior Member
I don't remember any Tecumseh OHV engines under 13HP until around 2000.
Occasional mechanic problem is to be expected, they made millions upon millions and they were made to a low price point. Snapped conn rods became a far bigger concern during low oil levels or being run up an incline. I honestly cant say I've seen more than maybe 3 or 4 out of many hundreds that chucked the rod with proper oil. Also never had carb problems that any other brand didn't suffer from though they are harder to bring back after fuel varnish. Never saw a leaking aluminum bowl either and i'd take that "paper thin" bowl over the garbage steel of the China carbs any day. I still like them for their simplicity although I agree completely they dug their hole when they couldn't be bothered to innovate. As far as the new stuff, trust me things are breaking far faster than anything on a Tecumseh ever did. Imagine instead of seeing the occasional fantastic failure every single engine manufactured during a 2 year period has metal filings in the fuel system and crankcase. Gets old pretty quick.
Old 02-17-2017, 09:50 AM   #197
timbitca
Senior Member
timbitca's Avatar
Helps a lot actually. And I now remember using it one-handed many moons ago. Didn't really think much of it recently, put that can't be my problem either, so I won't bother ordering the parts seeing as I don't absolutely need them now.
Old 02-17-2017, 10:58 AM   #198
Bluejoe
Yes I'm liking that big blue beast. I want one
Old 02-17-2017, 12:14 PM   #199
kctyphoon
Senior Member
kctyphoon's Avatar
Yea completely removed, everything still functions.. there are a few vids posted on YouTube showing how to solder some of the attachment pins back onto the cable if that helps.. hopefully if you need a new cable they can still be ordered from Yamaha.
This is what sucks having a machine like this that's so old. They rarely break, but the smallest thing can become a big problem if you can't find the parts.. good luck.
I heard a rumour that the tracks f on the new models will fit the old machines, but I don't know if that's actually been confirmed or not.. I occasionally look on eBay and Craigslist to see if a cheap parts machine turns up. It's very annoying when I see the same model thrower in good shape, with a very low asking price of like $200, and it winds up being halfway across the country..
Old 02-17-2017, 12:17 PM   #200
finn
Senior Member
[QUOTE=Skin;6315772
Yamaha has their entire snowblower made in China-as are Subaru Robin small engines which were also quite decent (short lived in snow applications though). Point is if these other equipment manufacturers would stop being so cheap we'd get a better product.[/QUOTE]
Subaru is closing down production of their industrial products division, which includes Suburu engines for lawn and garden applications . They will be done by September 2017.
Yamaha picked up some of the larger v-twin commercial lawn care engine product lines, but you won't see Subaru engines in new snow blowers.
finn is offline   Reply With Quote
Old 02-17-2017, 01:05 PM   #201
6PTsocket
Senior Member
Quote:
Originally Posted by Jsf721 View Post
I have an Ariens that has been reliable with minimal maintenance. Really just use it 3-4 times per winter though. Electric start is sweet.
I like my Ariens, too. Since it always starts on one or two pulls, I have yet to try the electric start. I will save it for the day that it doesn't kick right over. Hopefully, never. One reason I bought it is the cast iron gear case. That is an upgrade from the aluminum gear cases found on cheaper machines.
6PTsocket is offline   Reply With Quote
Old 02-17-2017, 06:49 PM   #202
MikeF2316
Senior Member
MikeF2316's Avatar
Thanks!
Are you adjusting the throttle (actually more of a governor) as you're blowing snow? I just move the lever to full speed, start it, and when I'm done, I move the lever to minimum which ground out the spark too. I can't see ever wearing out a throttle cable.
__________________
Old 02-17-2017, 08:46 PM   #203
timbitca
Senior Member
timbitca's Avatar
Bah. Just realised I wasnt explaining myself the best. I broke the clutch control cable.
Old 02-17-2017, 08:48 PM   #204
Skin
Senior Member
So Robin is effectively going away? That's sad, they'd been around for a long time. Guessing they couldn't be bothered to compete with China.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
