Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Display Modes
Old 06-06-2008, 09:34 AM   #1
Engineer2283
Junior Member
Default Crusher run shed foundation
I'm going to be building a shed in the near future and have a quick question about the stone base. It'll be an 8'x10' shed with a 10'x12' base. I'm going to use #1 crusher run as a base and build the shed, on skids, on top of the stone. The base will be "framed" into the ground with either PT 4x6's or 4x4's. Is there a correction factor or sorts to better determine the number of yards of run I'll need? I don't feel like being a yard or so short/extra. Any help is appreciated.
Engineer2283 is offline   Reply With Quote
Old 06-06-2008, 09:39 AM   #2
boiler7904
Senior Member
boiler7904's Avatar
Default Re: Crusher run shed foundation
All of the stone suppliers I've ever dealt with measure stone by the ton. The supplier I use says that 1 ton of crusher run will cover 100 square feet when 2" deep or 200 square feet when 1 "deep. I just used 10 tons as a base for my new patio. Their coverage rate was right on for my project.
__________________
2004 Ford Escape XLT
2005 Chevy Colorado Z71 4x4
2006 2 car garage in progress
Quote:
Originally Posted by bmwpower View Post
Oh, and it's BMWPower. I do have powerful BM's but wouldn't want everyone to know all my secrets.
boiler7904 is offline   Reply With Quote
Old 06-06-2008, 09:42 AM   #3
Wardster
Senior Member
Aggregate is usually ~2 ton per cubic yard. Get some measurements, calculate the yardage, and add 10% for waste. That will get you close.
-Wardster
Wardster is offline   Reply With Quote
Old 06-06-2008, 09:49 AM   #4
Engineer2283
Junior Member
Thanks!
I was going by yards b/c I'll probably be getting the stone from 1 of 2 landscaping suppliers. The aggregate/concrete suppliers either don't deliver or want triple what the landscaping suppliers charge for delivery.
Old 06-06-2008, 09:49 AM   #5
Old Moparz
Senior Member
Old Moparz's Avatar
Once you have the area where the shed is going cleared & leveled, you should be fine with 3 or 4 inches of stone. A simple math formula to determine the quantity is length, times width, times the thickness of stone.
10' x 12' x 0.33' (0.33' for 4") = 39.6 cubic feet.
Divide 39.6 cf by 27 to convert it to cubic yards.
39.6 cf /27 = 1.46 cy of stone.
Some places sell stone by the ton, so if you want to convert 1.46 cy to tons, you can multiply it by 1.5 to 1.8 to get that number. That factor varies slightly, but 1.8 is what I always use since moisture content & the fines in the stone will vary.
1.46 cy x 1.8 = 2.64 tons.
I'd round up & order about 2 cy or 3 tons & you should be safe.
__________________
Bob
Old Moparz is offline   Reply With Quote
Old 06-06-2008, 10:07 AM   #6
Engineer2283
Junior Member
I had the math part down already. Thanks again... time to order some stone.
Old 06-06-2008, 10:34 AM   #7
Old Moparz
Senior Member
Old Moparz's Avatar
Quote:
Cool, I should have figured that with your user name, but you never know.
__________________
Bob
Old 06-06-2008, 10:40 AM   #8
Engineer2283
Junior Member
No worries... I dropped out of pre-calc in high school b/c it was too hard. Picked up calculus 2 years later and went on a math run without a problem. Only 1 class shy of a minor.
Old 06-06-2008, 01:24 PM   #9
W-Cummins
Too much stuff
W-Cummins's Avatar
The tons vs yards thing may to be a regional deal. When I lived in OR and MT I got it all by the yard, Here in Iowa it's tons. BTW the tons deal is a total rip off you pay more $$ for the wet fines . Of course here gravel is a rip off in general, there is nothing but limestone here and it's $$$$$. I have over 5k in crushed limestone and will have probably over 10k before I'm done. The yard measurement is the fair way to sell it as it's consent, but it's harder for the plant/pit to measure than the weight, so I think lots of places that were selling it by the yard are now using tons too...
William...
__________________
My Garage Journal shop pictures
1998 Dodge 3500 12 Valve TST 10, 3K GSK, ddp stage IV injectors, SB con-Fe
1987 Chevy 3500 24 valve Cummins, Nv4500, DD#2 injectors, Edge Comp
1955 Ford F100
1941 Chevy Panel
W-Cummins is offline   Reply With Quote
Old 06-06-2008, 07:17 PM   #10
russlaferrera
Senior Member
The stone yards I have delt with purchase their stone by weight (ton). I makes more sense to sell it by weight, and more accurate.
russlaferrera is offline   Reply With Quote
Old 06-06-2008, 09:34 PM   #11
boiler7904
Senior Member
boiler7904's Avatar
Quote:
Except when the stone is wet. Some yards will apply a moisture correction factor to the weight on the scales if they know it's wet. Others will just add some material to make up for it.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
