Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-10-2005, 02:35 PM   #1
MyMopar
Garageaholic
Default Electrical wire size, what size to run?
2 questions regarding wire size.
1) For a 220 volt welder (Miller 175) what size wire should I run say for a 10' length? and what size breaker?
2) For a 7500 watt generator, what size wire should I run for that back to the panel?
The welder would be 2 hot and ground so that would be wire (size)/2 correct?
I know the generator is going to be 4 wire, 2 hot, neutral and ground, so it would be wire (size)/3 correct?
MyMopar is offline   Reply With Quote
Old 11-10-2005, 08:03 PM   #2
TOMWELDS
Garageaholic
Default
With a cord (like an extension cord), you include the ground :EX; 1 white 1 black 1green = 12/3, if 12 gauge.
With cable, (like romex or BX), you dont include the ground :EX; 1 white 1 black 1 bare = 12/2, if 12 gauge.
I dont own the 175 but i think miiler recommends a 30amp circuit. The machine comes with a 50amp 250volt plug. That's standard with most welders. Install 10/2 RX or BX in the wall. 30amp breaker 2pole, and a 6-50R receptacle (50amp 250 volt recep.).
__________________
LICENSED ELECTRICIAN
BAKERY MECHANIC
TOMWELDS is offline   Reply With Quote
Old 11-10-2005, 08:09 PM   #3
TOMWELDS
Garageaholic
Default
With the 7500 watt generator, if you're making a quick cord for using on a jobsite or camping, #10 would be ok. If you're making a hookup to use during a black out, use 8/4 cord. 7500watts = 31.25 amps @240volts. technically that's for #8 wire.
__________________
BAKERY MECHANIC
Old 11-10-2005, 08:12 PM   #4
Fast Orange
Senior Member
Fast Orange's Avatar
Default
1) What is input amperage for welder? If 50A,use #6 AWG.
2) For 230V/7500W=33A-Use #8 AWG
Concerning # of conductors in different types of cables- X=wire AWG
X/2 romex= 1 white,1 black, 1 bare-MC cable is the same
Rubber cord-X/2= 1 white, 1 black-NO GROUND
X/4= 1 white, 1 black, 1 red, 1 green
George
Edit-You beat me to it,Tom-I gotta learn to type quicker.
Fast Orange is offline   Reply With Quote
Old 11-10-2005, 09:52 PM   #5
Stuart in MN
Senior Member
Stuart in MN's Avatar
Default
The thing about welders is that the wire size depends on the duty cycle. The lower the duty cycle, the smaller the wire size. That's why a welder may have a 50 amp plug connected to wire that otherwise is only good for a 30 amp circuit. This is covered in article 630 of the NEC.
The owner's manuals for your welder and generator should have the factory recommendations for wiring. If you don't have copies you can probably find them online, I know Miller has the manual available on their website.
Stuart in MN is offline   Reply With Quote
Old 11-10-2005, 10:23 PM   #6
TOMWELDS
Garageaholic
Default
Sberry is the best one for info on duty cycles and the like.
__________________
BAKERY MECHANIC
Old 11-14-2005, 08:34 AM   #7
MyMopar
Garageaholic
Default
Thanks, I was looking to confirm some info and now it is crystal clear.
Old 11-14-2005, 12:21 PM   #8
CraigFL
Senior Member
Default
I'm lazy so I just go to Home Depot and they tell me the wire size to run based on their wire(different wires have different current ratings for the same size). That way I don't have to look it up in the NEC. If I was using a standard 50A outlet, I would probably run 50A rated wire and a 50A breaker and mark it as such.
CraigFL is offline   Reply With Quote
Old 11-14-2005, 03:12 PM   #9
79rallysport
Wanted dead or alive
79rallysport's Avatar
Default
What I did when wiring my welder, I used 50A rated wire with a 30A breaker (the welder reqired a 30A circuit). This way, if for some reason I upgrade to a welder that requires a 50A circuit, all I have to do is switch out the breaker and the wire is already to go. FYI, the circuit was only about 3ft long but it was in the wall and can't be changed later.
__________________
Freedom is never more than one generation away from extinction. It is not ours by inheritance; it must be fought for and defended constantly by each generation, for it comes only once to a people. Those who have known freedom and then lost it have never known it again.
79rallysport is offline   Reply With Quote
Old 11-15-2005, 12:16 AM   #10
TOMWELDS
Garageaholic
Default
That's the best way: #8 (50amp) and you can use any breaker up to 50amp.
__________________
BAKERY MECHANIC
Old 11-15-2005, 02:56 AM   #11
muddy
Senior Member
Default
I have a Miller 250 but I don't think the internals are alot different from your 175 at least I know the Miller 200 is about identical. Anyways, the input amps is what is important according to my electrician and 50 is the input for my 250......... Keith
muddy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Under ground phone wire 86swb General Garage Discussion 25 10-26-2006 01:00 PM
wire breaker requirements for equipt. mdshore348 General Garage Discussion 9 03-05-2006 06:30 AM
Wire size question Wildfire General Garage Discussion 5 03-01-2006 09:01 AM
Ampacity of 8 ga aluminum wire? MN_Pete General Garage Discussion 4 12-28-2005 12:35 PM
Increase your wire size! sca037 General Garage Discussion 18 07-19-2005 05:57 PM
