Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 03-30-2013, 09:20 PM   #1
chipper
Senior Member
chipper's Avatar
Default Do not try this at home
I have the hf 44 top and bottom toolboxes.Today i was in the garage staring at it and wanted to switch the two deep drawers from the top for 4 shallow drawers from tje bottom so this involved moving a couple slides and. swaping the drawers easy enough ......wrong drawers are not compatible the locks are different but worse then that is the slides are completely. reversed meaning you can get the drawer in but you can't get it out so once i found the locks wouldn't work it took me forever to it back to normal
chipper is offline   Reply With Quote
Old 03-30-2013, 10:37 PM   #2
Armstrong1720
Senior Member
Default Re: Do not try this at home
Lol that would be my luck !!!!
Armstrong1720 is offline   Reply With Quote
Old 03-31-2013, 01:23 AM   #3
Big-Foot
Senior Member
Big-Foot's Avatar
Ouch! That sux!
Thanx for the heads up!
__________________
Regards - Randy
http://www.GT-Forty.com
Big-Foot is offline   Reply With Quote
Old 03-31-2013, 03:42 AM   #4
larry4406
Senior Member
Man this is not good to hear.
I have ordered slides to do this exact conversion. The deep drawers from the top chest only have a single slide while the deep drawers in the bottom roller have dual slides.
My plan was to add the new slides to the top chest where the deep drawers are and then swap the deep drawers with narrows from the bottom chest.
What is the difference in the locks?
larry4406 is offline   Reply With Quote
Old 03-31-2013, 04:59 AM   #5
chipper
Senior Member
chipper's Avatar
The top box is a 45 degree lock and the bottom is a 180 degree lock ...take out two dtawers and compare the backs you'll see ...this is how it is on my box i can't imagine yours would be any different
Old 03-31-2013, 08:32 AM   #6
pilotman81
Senior Member
pilotman81's Avatar
Bummer man! Thanks for the post, my sister's bf was looking to do the same thing with his box last week when I left for TX. Just texted him to cease and desist! Thanks again!!
pilotman81 is offline   Reply With Quote
Old 03-31-2013, 12:27 PM   #7
larry4406
Senior Member
Well I pulled out the drawers from the chest and the roller bottom.
I have the old red crinkle style.
The drawer locks are different, while the slides appear swapped left to right as the release lever is oriented different.
The drawers themselves are the same size.
Looks like I will be having to swap the slides and the locks.
Thanks for the heads up.
Old 03-31-2013, 12:34 PM   #8
CJCar
Senior Member
Default
I just did this with no issues with the slides. The locks are different. The bottom drawers have a mechanism riveted to the back. I just drilled the rivets and popped them off. This allows the drawers to slide the whole way in the top chest. I'm not worried about locking it but the tabs for the top could be made easily enough.
CJCar is offline   Reply With Quote
Old 03-31-2013, 03:02 PM   #9
chipper
Senior Member
chipper's Avatar
Correct i wish i knew this when i started..its gonna be a good look good luck to ya post some finished product pics
Old 04-24-2013, 05:06 AM   #10
larry4406
Senior Member
Ok - the drawer conversion is done.
Couple of key points associated with this conversion:
1. The upper chest double drawers use single slides while the bottom roller double drawers use double slides. The holes and slots for addition of the slide in the top chest are factory punched.
2. I used 3/16" pop rivits which required slight enlargement of the holes after the slides were fully seated.
3. The slide halves were not interchangeable top chest to bottom roller. Thus, I had to remove the slide halves that were attached to the drawers and keep them in their original locations.
4. The lock mechanism is different between the chest and the roller. The roller uses a swing type latch mechanism while the chest uses a small piece of bent metal.
5. I match marked all drawers and then drilled rivits and swapped the locks. I made my own bent metal pieces for the top chest lock conversion.
6. All drawers now lock perfect after the converison.
7. I also have two 7-drawer cabinets and swapped the single drawers between them.
File Type: jpg 4. Location for New Slide Top Chest.JPG (74.9 KB, 388 views)
File Type: jpg 6. Drilling for the Bottom Roller Latch.JPG (109.4 KB, 385 views)
Old 04-24-2013, 05:07 AM   #11
larry4406
Senior Member
Few more pictures
File Type: jpg 8. Bottom Roller Latch Conversion Complete.JPG (68.3 KB, 221 views)
File Type: jpg 10. Top Chest Latch Conversion Complete.JPG (86.3 KB, 236 views)
Old 04-24-2013, 06:11 AM   #12
nine4gmc
Senior Member
nine4gmc's Avatar
good job, thanks for taking time to show the work. that is a killer amount of storage!!
nine4gmc is offline   Reply With Quote
Old 04-24-2013, 06:20 AM   #13
RCStocker
Senior Member
I have some of those HF boxes and they are great for the money. I am too lazy to change things. LOL
RCStocker is offline   Reply With Quote
Old 04-24-2013, 07:49 AM   #14
PECVD2
Senior Member
PECVD2's Avatar
Nice Job Larry and thanks for the info/pictures. I may just have to do the same as I hate the deep drawers in the top box.
__________________
PICS or it didn't happen!
PECVD2 is offline   Reply With Quote
Old 11-15-2013, 04:40 PM   #15
TheWhiteMamba
Senior Member
Just found this off a different thread. Thanks for the pics and write up Larry! Just about solidifies the fact that I'll have to buy this combo soon just to do this as well...
TheWhiteMamba is offline   Reply With Quote
Old 11-15-2013, 09:39 PM   #16
cagullett1
Senior Member
Do you have an item number for the slides that you ordered? Did the slides you ordered match the slides to the top cabinet, or the bottom chest?
cagullett1 is offline   Reply With Quote
Old 12-15-2013, 04:09 PM   #17
John316
Senior Member
John316's Avatar
Just thought I would update this thread for reference. I successfully changed around my drawers as pictured and also added slides to two of the larger drawers (originally in the top cabinets) that only come with one set of slides. I still have two drawers (one narrow and one wide) that have only one set slides. I may add slides to these in the future, but for now I am happy to use these for lighter duty storage.
Here is the part # for the slides as I ordered them (late October 2013):
Item # Qty Description
13605 2 90320 DRAW SLIDE 1 PC
The above got me 4 individual slides--2 sets. The part description uses the term "1 PC" as you can see, but the part # is for a set of slides.
John316 is offline   Reply With Quote
Old 12-15-2013, 04:28 PM   #18
Farmall450
Senior Member
Farmall450's Avatar
Quote:
Wow...wonder why they did that?
__________________
Why Farm Half When You Can Farmall?
1959 1/4 HP Craftsman Pre-Block Restoration
Quote:
Originally Posted by countryroad82 View Post
I'm left handed so there are a lot of things that just don't seem right to me
Farmall450 is offline   Reply With Quote
Old 12-15-2013, 04:36 PM   #19
The Ratchet Man
Senior Member
The Ratchet Man's Avatar
Is that part number for the top slides or bottom?
The Ratchet Man is offline   Reply With Quote
Old 12-15-2013, 04:39 PM   #20
John316
Senior Member
John316's Avatar
Both. On older versions of the box it may be different, but on mine which is a more recent version the slides are interchangeable between top and bottom box. It's the locking mechanism that differs of course. It was the bottom drawers of the top box that only come with one set of slides. I added slide but also moved drawers to the bottom cabinet
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
