Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
Hey, guys.... found a interesting ratchet at the pawn shop today for $4.50 that I thought would be of interest. It is a "Double Duty" 1/2" x 3/8" ratchet "Made in USA by Proto for Vogel Tool Co. Double Duty" . I found a patent for this oddity and looks to be of 50s vintage: http://www.google.com/patents?id=ynhpAAAAEBAJ
This ratchet body looks like a typical Proto pear head ratchet, what this this thing sticking out the wrong side? LOL!![]() ![]() ![]() Anyone know anything about the VOGEL TOOL CO.?![]() Oops! I put the spring in backwards (small part facing away from the body right?, I fixed it! Unfortunately, some of the teeth broke off of the drive (they fell out when I cleaned the head; I doubt they have replacement parts for this puppy! The head design is classic Proto and the only difference I can see is the addition of the extra drive.
__________________
"I can't stop buying those $1 Snap-On 1/2 wrenches!" Don't Worry Its OK, your NOT alone; tool addicts of the world UNITE! Being able to reach into your rollaway and finding the right tool for any given situation/repair; is the ultimate power trip! Last edited by billymade; 06-27-2008 at 05:11 PM. |
#2 |
Senior Member
Wow, I really didn't know that they made those back then. I've seen newer versions being sold but they are usually the cheaper imported ones. I'm always amused when I see an old version of something that is being marketed by someone else as being a newer innovation.
#3 |
Senior Member
Outstanding find, Billymade! I bought one of those ratchets on Ebay a couple of years ago. I can't remember exactly what I paid for it, but it was a whole lot more than $4.50. Ya did good my friend.
#4 |
Senior Member
If the main gear is broken, maybe you can get a rebuild kit and convert it to one drive size only. You may not want to do this, but I'm curious to see if it would fit perfectly.
#5 |
Senior Member
I was thinking the same thing; everything looks so typical Proto inside I would be surprised if they went through the trouble of changing all the tooling. I suspect it would convert to a "normal" ratchet easily! Anyone see any differences in the the machining of the head? I don't have another one to compare it to but looks similar to other Proto pics I have seen. Believe it or not it ratchet pretty well, it just "skips" a little bit when it comes to the broken teeth but I am just turning by hand not using it under load at this point.
__________________
"I can't stop buying those $1 Snap-On 1/2 wrenches!" Don't Worry Its OK, your NOT alone; tool addicts of the world UNITE! Being able to reach into your rollaway and finding the right tool for any given situation/repair; is the ultimate power trip! |
#6 | |
Senior Member
Quote:
#7 |
Senior Member
| Thread Tools | |
| Display Modes | |
