Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 06-03-2013, 12:59 AM   #21
greasemonkey44
Senior Member
greasemonkey44's Avatar
Default Re: Adding extra Leverage to a Combo Wrench
i use a longer wrench, double wrench, pipe, or a deadblow
usually the dead blow does the trick or an impact
__________________
Quote:
Originally Posted by countryroad82
I don't break tools very often, when I do it is in grand fashion and normally my fault.
greasemonkey44 is offline   Reply With Quote
Old 06-03-2013, 02:22 AM   #22
All
Senior Member
Square tubing. Insert open end of wrench on the diagonal.
The diagonal of a square is significantly longer than the diameter of a circle for a pipe roughly the same outside diameter as a comparative square tube's width from flat to flat.
Try it. You'll like it.
All is offline   Reply With Quote
Old 06-03-2013, 04:04 AM   #23
Drew_flux
Senior Member
pipe or a 2" socket and a extention
__________________
Originally Posted by Greatbear
Trains?
As the old saying goes, electric trains are like
titties. They're meant for kids but their dads play
with them the most.
Drew_flux is offline   Reply With Quote
Old 06-03-2013, 06:26 AM   #24
sberry
Senior Member
sberry's Avatar
A tubing on occasion, a hammer if needed. With this version the bolts are adjustable and the heads could be modified but its a last resort kind of thing, low duty cycle.
sberry is offline   Reply With Quote
Old 06-03-2013, 08:25 AM   #25
Kracin
Senior Member
Kracin's Avatar
Quote:
Originally Posted by Chuck122 View Post
Every time I'm about to double wrench, it looks to me a thought the wrench is not meant to be stressed that way, then I feel like a dork and find another way
imho it's less about "using it the wrong way" and more about "using it in a situation that calls for it", like when you have a wrench somewhere in a deep spot, and absolutely need some more torque on it, and can't get a socket on it, but can't get the leverage you need. it's far less taxing to use this method than to put a hammer to the end of it. in my opinion.
Kracin is offline   Reply With Quote
Old 06-03-2013, 08:32 AM   #26
fbdyws6
Never used them but these look kind of cool for people worried about connecting wrenches the way pictured above.
http://www.amazon.com/E-Z-EZRWC100-M.../dp/B004WIWIRE
fbdyws6 is offline   Reply With Quote
Old 06-03-2013, 08:41 AM   #27
lilredex
Senior Member
Made this up and used it a couple of times before finding my 3/4" drive sockets.
programs to take screenshots
Kind of like sberry's arrangement better, takes the stress off the open end.
lilredex is offline   Reply With Quote
Old 06-03-2013, 09:31 AM   #28
richfinn
Senior Member
I like to use my serpentine belt tools if I need more leverage (size permitting), but I have linked spanners together as well for years and years and never damaged one
richfinn is offline   Reply With Quote
Old 06-03-2013, 09:37 AM   #29
the gypsy
Senior Member
I prefer this idea more than putting wrench to wrench. It gives you more choice of angles to work in.
the gypsy is offline   Reply With Quote
Old 06-03-2013, 10:05 AM   #30
sberry
Senior Member
sberry's Avatar
I actually like yours better from design. I put a 1 1/4 pipe on a long handle double box Cman,,, 36 inch added leverage, came with a snap, must have been in hundreds of ft pounds.
Old 06-03-2013, 10:11 AM   #31
rick carpenter
Senior Member
Who makes the beefiest box end wrench? Some mfr not worried about slimness or tight access. If cheap enough, you could just cut off the open end and use whatever pipe length you need. Or use ironworkers' spud wrenches.
rick carpenter is offline   Reply With Quote
Old 06-03-2013, 10:47 AM   #32
Jim51
Junior Member
Exact principle I was thinking of using to build my own out of some scrap bar stock. Nice link, perfect solution.
Jim51 is offline   Reply With Quote
Old 06-03-2013, 10:47 AM   #33
4x4gearhead
Senior Member
4x4gearhead's Avatar
I usually double my wrenches up like mentioned here. I have found however that it isnt always effective with my modern snap on combinations as they are too thin. I have a piece of 1 in wide by 1/8" strap with a couple prongs welded on it perpendicularly similar to Sberry's and Lilredex. I have seen an actual manufactured version of these tools before and have considered buying one, Ill try to find the link.
__________________
How many ratchets will be enough?
4x4gearhead is offline   Reply With Quote
Old 06-03-2013, 10:51 AM   #34
4x4gearhead
Senior Member
Here is a picture of a Lee Valley made extender, didnt have time to look around at prices, but this looks like something Id like to have.
__________________
Old 06-03-2013, 11:25 AM   #35
TangoFoxTrot
Senior Member
TangoFoxTrot's Avatar
Quote:
I have one of those and I've used it quite a bit. It's held up really well.
It's a great solution for when you need large wrenches and something like a cheater bar is just too small to slip over a wrench end.
TangoFoxTrot is offline   Reply With Quote
Old 06-03-2013, 11:42 AM   #36
4x4gearhead
Senior Member
Nice! thanks for the input, Im currently looking into getting one, It would be great for reaching hydraulic hoses i'd bet.
__________________
Old 06-03-2013, 04:53 PM   #37
beamrider
Senior Member
Looks familiar somehow......
beamrider is offline   Reply With Quote
Old 06-26-2013, 07:17 AM   #38
ndoran
Senior Member
Quote:
Originally Posted by beamrider View Post
I've seen this in the catalog a few times, don't think its worth $25 tho...
http://www.leevalley.com/US/wood/pag...=1,43456,43407
Personally, it's always been wrap a rag around the wrench, and use a piece of pipe.
I have one it works , the chrome is not great on it but it doesn't damage the wrench
ndoran is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
