Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 06-15-2013, 06:33 PM   #1
scratchedup
Senior Member
scratchedup's Avatar
Default Part 2 how to clamp exhaust tubing
Please show pics or post how you hold exhaust pieces together for welding.
I do all the fabricating but do not weld. My welder is very good but it seems to me he lacks a shop/tools to hold stuff and do a proper job.
If I can provide him with pieces already clamped it would be a help.
Im kind of a newbe with exhaust systems....what is the protocal for clamping round stuff....(2.5")
scratchedup is offline   Reply With Quote
Old 06-15-2013, 06:37 PM   #2
steel 35
Senior Member
steel 35's Avatar
Default Re: Part 2 how to clamp exhaust tubingq
Usually held by hand and lightly tacked every 90 deg for me.
steel 35 is offline   Reply With Quote
Old 06-15-2013, 06:38 PM   #3
AZ Glen
Senior Member
AZ Glen's Avatar
hold....flip helmet down....step on pedal.
AZ Glen is offline   Reply With Quote
Old 06-16-2013, 08:04 AM   #4
scratchedup
Senior Member
This is the current project. Can one use masking tape to hold while tacking?
Old 06-16-2013, 10:01 AM   #5
AZ Glen
Senior Member
AZ Glen's Avatar
nice tight gap....tape wont hold it, just have someone hold it square and then tack it.
If it is being tig welded it will be even easier. A good welder could do that by himself.
Old 06-16-2013, 10:13 AM   #6
Mr.N
Senior Member
Default
Sounds like you need to make a fixture.
You could try to make one out of wood. Have the flange bolt to it and the other side surround the tube.
Mr.N is offline   Reply With Quote
Old 06-16-2013, 10:23 AM   #7
steel 35
Senior Member
steel 35's Avatar
Very nice fitI would just number the pieces; you are saving someone a lot of work & hopefully they account for that. I would enjoy welding that.
Old 06-16-2013, 10:29 AM   #8
scratchedup
Senior Member
Quote:
Thanks.....I'LL be right over but I'm have trouble on Google with the location of the emerald triangle😀
Old 06-16-2013, 10:33 AM   #9
scratchedup
Senior Member
It's the OEM 3 hole flange with the bore enlarged and custom machined recess for 14 degree short bend on to a Random Tec. custom modified cat. With an added o2 bung��
Old 06-16-2013, 11:31 AM   #10
lilredex
Senior Member
Maybe a modified version of these would do it....
screen shot tool
upload a picture
lilredex is offline   Reply With Quote
Old 06-16-2013, 11:41 AM   #11
srmofo
Senior Member
Ive used hose clamps before. Just weld right through the damn thing to tack it up. Cut the excess off and finish welding. Thats not usually needed though. Just get a second pair of hands to positioning it and then tack it.
srmofo is offline   Reply With Quote
Old 06-16-2013, 11:43 AM   #12
e30bradley
Senior Member
e30bradley's Avatar
last time I welded tubing I held it while tacking it. How well do MIG welds work for an exhaust?
__________________
2000 Suzuki TL1000R 30k miles
2000 Honda CRV awd, 5spd 223k miles
1987 Ford F-250 4x4 5spd 6.9 turbo diesel, D60, 206k
1985 Yamaha FJ1100
2004 Mazda RX8 119k 6speed
1996 Honda Civic hatch 70hp 5sp
e30bradley is offline   Reply With Quote
Old 06-16-2013, 11:45 AM   #13
scratchedup
Senior Member
Quote:
screen shot tool
upload a picture
Now wer talkin....
BTW it will be TIG.
Old 06-16-2013, 06:41 PM   #14
59'trump
Grab a hose clamp and drill as large of a hole in it as possible in three positions spaced around the circumference. Tighten the hose clamp across your joint and tack weld right in the holes being careful not to weld the hose clamp to your work. Should work fine for most applications.
-First time posting, long time reader
__________________________________________________ ________
2004 1500 Avalanche (gas guzzler)
2006 Victory Vegas
1982 Suzuki GS650
1959 Triumph T110
59'trump is offline   Reply With Quote
Old 06-16-2013, 08:00 PM   #15
lotsoftools
Senior Member
If you have enough room for a clamp you could also use these: http://www.summitracing.com/parts/SUM-693330/
Or even make your own.
lotsoftools is offline   Reply With Quote
Old 06-16-2013, 09:15 PM   #16
scratchedup
Senior Member
Great stuff
Old 06-16-2013, 10:47 PM   #17
steel 35
Senior Member
steel 35's Avatar
Quote:
Originally Posted by scratchedup View Post
Thanks.....I'LL be right over but I'm have trouble on Google with the location of the emerald triangle��
It sure isn't the Bermuda Triangle!
Old 06-16-2013, 10:57 PM   #18
trboxman
Senior Member
trboxman's Avatar
hmmm...short term memory loss...such a terrible thing...
__________________
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
- Herbert Spencer
trboxman is offline   Reply With Quote
Old 06-16-2013, 11:32 PM   #19
Mike Miller
Senior Member
Mike Miller's Avatar
I use a piece of angle iron on an adjustable "A" frame stand, put the two pieces in the V and support in position to tack, use hose clamps to hold steady if needed.
Mike Miller is offline   Reply With Quote
Old 06-17-2013, 12:55 AM   #20
lilscorpion
Senior Member
lilscorpion's Avatar
Default
Strong hand clamps with the optional swivel jaws. Easy and quick but not super cheap.
__________________
My Shop Organization Thread - my on going project thread
lilscorpion is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
