Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 07-02-2013, 06:25 AM   #1
bruce69camaro
bruce69camaro's Avatar
Default 3 way toggle switch wiring.
I got a question for you electricians, I want to install a 3 way toggle switch in my race car (12v system), then in the bottom position, it will power up my running/ tail lights and then in the up position, it will power up my head lights as well as the other lights.
I have two switch's, a 3 way, 6 pole and a 3 way, 3 pole switch, which one would be better?
If it's easier to scan a schematic, I could PM you my email address.
Thank you
Bruce
bruce69camaro is offline   Reply With Quote
Old 07-02-2013, 07:04 AM   #2
astroracer
Senior Member
astroracer's Avatar
Default Re: 3 way toggle switch wiring.
Street driven "race" car? Turn signals involved? Stock wiring harness or custom? Do you have a wiring schematic for the car, stock or otherwise? Lots of questions, as you can see.
Plan to run relays with the switch to power up the lights. Makes for an easier time of it for the switch as it only has to carry a small load to energize the relays.
Mark
__________________
My Fotki Album...
http://members.fotki.com/astroracer/about/
'31 Model A Tudor Sedan (it's own basket)
'73 Firebird. Pro Streeted due to rust but slated for a Pro_Touring makeover.
'88 Astro Van - The BAD AST project...
'94 Firebird Formula
'95 GMC Sierra - It has a few mods...
'00 Monte Carlo SS- The GOOD car...
'01 Astro Van - The "family trukster"...
(gone) '02 Collector Edition Trans Am (traded for the '56)
'56 Chevy Handyman Wagon
'04 Astro Van - The daily driver/go getter
astroracer is offline   Reply With Quote
Old 07-02-2013, 08:07 AM   #3
bruce69camaro
Hi Mark,
Custom wiring harness/ fuse block, race car only, and I have no issues using a relay, my other items (fuel pump, water pump, electric fan) are run off of them.
I have a schematic done up on Word of how things are currently wired.
Here is what I was told so far, use a 3 way, 6 post switch, middle post to battery, bottom post on the same side to running lights, top post on opposite side to headlights, then a jumper to the bottom post on the same side.
Thank you.
Old 07-02-2013, 09:05 AM   #4
Steevo
Senior Member
Steevo's Avatar
"Here is what I was told so far, use a 3 way, 6 post switch, middle post to battery, bottom post on the same side to running lights, top post on opposite side to headlights, then a jumper to the bottom post on the same side."
That doesn't quite make sense to me, but maybe I am not catching what you are saying.
A DPDT switch like that has two separate switches inside, one left and one right.
In either "on" position it connects the two center poles to the two end poles, and in the other "on" position, the center poles to the two opposite end poles.
When you wire the "middle post to the battery", you want to wire it to both middle posts.
Then wire tail/running lights to one end post, and headlights to the other end post in same end of the switch.
Then, run a jumper from the tail light post to the end post on the same side.
Now, when you flip it one way, it is powering just the tail/running lights.
When you flip it to the opposite side, the power is applied to both the headlight connection, and the tail/running light connection.
I'll try to draw it and post it shortly.
__________________
My Workbench Build Thread
My Idaho Shop Build Thread
"I'd rather laugh with the sinners than cry with the saints, the sinners are much more fun" - Billy Joel
Steevo is offline   Reply With Quote
Old 07-02-2013, 09:13 AM   #5
larry_g
Senior Member
Sounds correct. One side controls the head lights and only one wire connected to the outer post. For the tail circuit jumper the top and bottom together and then off to the tail lights.
You will need a three position toggle switch that has a center off position.
Please ignore the wiring above and just look at the terminal id's
C&D to 12v
B&F (jumpered together) to the tail lights
A or E to the headlights
lg
no neat sig line
__________________
My Shop build thread
Great minds talk about ideas, average minds talk about events, small minds talk about people.
Wise people talk because they have something to say. Fools talk because they have to say something.
larry_g is offline   Reply With Quote
Old 07-02-2013, 09:47 AM   #6
bruce69camaro
So basically Steevo's drawing is correct except for missing the one wire on the 12V power supply, correct?
Using the drawing the Larry posted, I was told that to run a 12v wire to C, then E goes to my running/ tail lights, B would go to my head lights and I was to jump B & F together.
When I was told this, I questioned to myself why D wasn't used?
Let me ask this question, using Larry's method, if I wanted the running/ tail lights to come on when the switch is in the bottom position, would I run the wire off of "B" and when I put the switch in the up position for the head lights, should I use "E"?
Thanks guys....
Old 07-02-2013, 09:50 AM   #7
astroracer
Senior Member
astroracer's Avatar
Then, run a jumper from the headlight post to the end post on the same side.
Did you mean to say "tail light" post?
Mark
__________________
My Fotki Album...
Old 07-02-2013, 10:16 AM   #8
Steevo
Senior Member
Steevo's Avatar
Yes
Fixed it.
__________________
Old 07-02-2013, 10:16 AM   #9
larry_g
Senior Member
Thanks guys....
Steves is correct in that he shows 12v going to two terminals. Look again at what I said, use A OR E . Which ever works in your world of up and down. I am assuming your up and down is when the toggle is down then the upper terminals are connected to common and visa versa . I have problems with up/down, right/left, or other references to directions is situations like this as your frame of reference may be quite different than mine.
lg
no neat sig line
__________________
Old 07-02-2013, 10:47 AM   #10
bruce69camaro
You're right Larry, when I mentioned up, the toggle switch is up, but the bottom poles are being used and visa versa but I think we are all on the same page.
Thanks for all your help.
Old 07-02-2013, 02:51 PM   #11
jagwinn
Senior Member
jagwinn's Avatar
Great little schematic program...and it's free!
http://sourceforge.net/apps/mediawik...?title=TinyCAD
jagwinn is offline   Reply With Quote
Old 07-02-2013, 07:50 PM   #12
laser3kw
Senior Member
I wouldn't wire the load (lights) right to the switch myself. I would use the switch to operate relays. That way you have some isolation between the low current switch network and the high current light network.
But that's just me......
laser3kw is offline   Reply With Quote
Old 07-03-2013, 05:02 AM   #13
bruce69camaro
Laser,
Relays plan to be used.
Thank you.
Old 07-22-2013, 11:51 AM   #14
bruce69camaro
I just wanted to update everyone that helped me out with this. I got everything wired up and used a realy for the headlights and verifed that that worked. I hooked up the switch and well, it didn't work. What I had was, the parking lights worked with the switch in both on positions, but no headlights.
To get the switch to work, I had to run power to both of the middle posts and it now works just fine.
This was a 6 post, on-off-on and I thought that if you put power to one of the middle posts, it would power both sides, just like how it is shown in the above drawings.
Is my switch something different?
Old 07-22-2013, 12:11 PM   #15
laser3kw
Senior Member
usually both "sides" of a double pole, double throw switch are independent of each other, the centers are not "common". sounds like you did the right thing.
Old 07-22-2013, 01:07 PM   #16
bruce69camaro
Thanks.
I just had this gut feeling this was the problem, so what I did was, I switch the power wire to the other post on the other side and guess what, the head lights worked but the parking lights didn't. BINGO, made a jumper and now they all work.
Thanks again to all that helped.
Old 07-22-2013, 01:20 PM   #17
larry_g
Senior Member
Thanks.
You should of had that feeling as that is what Steeves diagram shows. Good on you for getting all going.
lg
no neat sig line
__________________
Old 07-22-2013, 02:03 PM   #18
bruce69camaro
You know, I completely skipped over Steevo's description and was looking at his drawing. I didn't take noticed that he "informed" me to wire both sides...
I looked at the drawing and to me, it appears you wire just the one post.
Guess if I would have read what he said, it would have saved me some time...
Anyhow, here's to Steevo and his discription, that I should have read...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
