Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-07-2008, 08:44 PM   #1
Bevis
Senior Member
Bevis's Avatar
Default Hanging OSB
Is it best to use screws or nails?? Got about 48 sheets to hang Monday.
Bevis is offline   Reply With Quote
Old 08-07-2008, 09:05 PM   #2
Bigger Hammer
Senior Member
Default Re: Hanging OSB
I personally like screws but it can be nailed too. Nailing is faster especially if you have a gun. If you ever need to remove a sheet to get inside the wall, you might as well plan on getting a new one to replace it. With screws they come off the wall much easier.
Edit: I might also add to that, that I did have buckets of 1 1/4" and 1 5/8" screws laying around left over from jobs. So that sort of drove my decision as well.
Bigger Hammer is offline   Reply With Quote
Old 08-07-2008, 09:33 PM   #3
IDASHO
Senior Member
Knowing how long it would take to screw, Id never bother with anything but an 8D gun nail
__________________
See my garage build here:
http://www.bonnefinstudios.com/kwb/paradise/garage/
IDASHO is offline   Reply With Quote
Old 08-07-2008, 09:39 PM   #4
Bevis
Senior Member
Bevis's Avatar
It may very well be nails then...since I've got a whole box of 8D (that were given to me)for my nailgun.
Old 08-07-2008, 10:20 PM   #5
locoman
Are you using for a finish wall inside?
__________________
B Conner
locoman is offline   Reply With Quote
Old 08-08-2008, 12:20 AM   #6
Bevis
Senior Member
Bevis's Avatar
No...at least not at this time. It's going on the outer walls, before the steel panels go on.
Old 08-08-2008, 03:00 AM   #7
BooUrns!
Senior Member
Use a 1/2" crown stapler. It's all I use for fastening structural panels. Although we typically attach the osb sheets when the wall is lying flat. I never understood why you guys put them on after the wall is standing.
BooUrns! is offline   Reply With Quote
Old 08-08-2008, 04:12 AM   #8
Bigger Hammer
Senior Member
Quote:
In that case I have to go with the gun nails or staples as well. Sorry, for some reason, I was thinking you were talking about interior walls.
Old 08-08-2008, 05:53 AM   #9
Bevis
Senior Member
Bevis's Avatar
In reality I guess I'll be using both nails and screws (nails to hang the OSB, then screws to hang the steel panels.)
Old 08-08-2008, 10:26 AM   #10
dcjredline
Senior Member
dcjredline's Avatar
I was also thinking interior. Outside use the nail gun, interior use screws.
dcjredline is offline   Reply With Quote
Old 08-08-2008, 05:53 PM   #11
Bevis
Senior Member
Bevis's Avatar
I guess I should have stated that it was exterior...my bad. Thanks for all the suggestions.
Old 08-08-2008, 06:30 PM   #12
IDASHO
Senior Member
Exterior!
For exterior I only use an 8D galvanized ring shank gun nail.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
