Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-10-2008, 12:58 AM   #1
Vinko
Senior Member
Default Differences among acetone, mineral spirits, lacquer, paint, shellac thinner
What are the principle differences among acetone, mineral spirits, lacquer, paint, and shellac thinner?
I know they've got different chemical compositions, but is there a rule of thumb on the different uses, things you can clean with each of them?
I've been using acetone to clean up urethane and it works like a charm.
I looked in the archives but didn't find anything specific or comparing them.
Hope this ain't too much of a pain-in-the-ass quesiton
Vinko is offline   Reply With Quote
Old 08-10-2008, 01:28 AM   #2
ddawg16
Senior Member
ddawg16's Avatar
Default Re: Differences among acetone, mineral spirits, lacquer, paint, shellac thinner
Acetone
Mineral Spirits
Lacquer Thinner, Paint Thinner, etc
Or when all else fails...type in acetone or any of the other key words into Google and get the anser.....
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 08-10-2008, 08:03 AM   #3
PAToyota
Senior Member
PAToyota's Avatar
Send a message via AIM to PAToyota
And you thin shellac with denatured alcohol.
PAToyota is offline   Reply With Quote
Old 08-10-2008, 11:06 AM   #4
kbs2244
Senior Member
Of the ones you listed Acetone will evaporate with the least amount of surface film left behind.
Denatured alcohol will leave no film behind, but wear gloves. It will suck the oil out of your skin.
For small, complex linkages,(lawnmower carbs and such) I use either spray carb cleaner or spray starting fluid.
The starting fluid is ether and evaporates without a trace.
Most coating will tell what to use to thin it.
The same stuff will work to clean it up.
kbs2244 is offline   Reply With Quote
Old 08-10-2008, 11:20 AM   #5
timgr
Senior Member
Mineral spirits, paint thinner, naptha, Stoddard solvent, white spirits are all basically the same thing - this is also the "solvent" used in solvent tanks in auto shops. It has a much lower vapor pressure than gasoline, acetone, lacquer thinner and alcohol, so it both evaporates more slowly and is less of a fire or explosion hazard than the the others.
Lacquer thinner is a proprietary mix of solvents such as acetone, dimethyl ketone, toluene, alcohol and other petroleum distillates. Has a much higher vapor pressure than "solvent" so it evaporates quickly.
Google is your friend!
__________________
'75 AMC Jeep CJ-6 304/T-15
'77 AMC Jeep J-10 258/T-15
'82 AMC Jeep J-20 360/T-18
'95 VW Golf Sport 2D 2.0L
timgr is offline   Reply With Quote
Old 08-10-2008, 03:23 PM   #6
stuckinohio
Quote:
The buzz?
__________________
Chris
stuckinohio is offline   Reply With Quote
Old 08-10-2008, 04:23 PM   #7
ddawg16
Senior Member
ddawg16's Avatar
Quote:
The buzz?
Ok....now we know you have been stuck in Ohio way too long.....
__________________
John
Home for.....
Old 08-10-2008, 04:27 PM   #8
kf4zht
Senior Member
Acetone is a decent cleaner and is used to thin quite a few different paints.
Denatured alcohol is great for wiping down parts before they are painted. Gets rid of grease and dust, then evaporates quickly.
Lacquer thinner or MEK will clean anything. Strong shit, but works even on the spray gun your buddy "cleaned" before he gave it back.
All the others I just use as needed to thin paints. I always keep a decent amount of LT, Acetone and Den. Alcohol on hand.
kf4zht is offline   Reply With Quote
Old 08-10-2008, 05:12 PM   #9
W-Cummins
Too much stuff
W-Cummins's Avatar
For the most part the bottom line is, like dissolves like. Solvents run the range from non-polar to highly polar as do the things your trying to remove or dissolve. On the highly polar side we have water and on the highly non-polar side, straight chain hydrocarbons ( hexane, etc.). Between fall most other things your calling solvents. So the more water (H-O-H) like the solvent ie. ethanol (R-OH) will dissolve things that are like it ie. the shellac. Your Acetone ({CH2}=0) less polar, MEK ({R}2-C=O) even more non-polar all the way to a straight chain hydrocarbon (R-H) no polarity. So one solvent is not ideal for all things you need a range of stuff in your cleaning/dissloving arsenal....
Sorry about the lame notation it's hard in ascii.
William....
__________________
My Garage Journal shop pictures
1998 Dodge 3500 12 Valve TST 10, 3K GSK, ddp stage IV injectors, SB con-Fe
1987 Chevy 3500 24 valve Cummins, Nv4500, DD#2 injectors, Edge Comp
1955 Ford F100
1941 Chevy Panel
W-Cummins is offline   Reply With Quote
Old 08-10-2008, 07:31 PM   #10
timgr
Senior Member
Good explanation William.
__________________
Old 08-17-2008, 02:20 AM   #11
Vinko
Senior Member
Yeah, thanks William!
Old 01-14-2013, 11:39 PM   #12
Bolster
Senior Member
Bolster's Avatar
Thread resurrectus.
Hey Vinko. Found these:
http://www.nytimes.com/1996/10/27/ny...-solvents.html
http://wiki.xtronics.com/index.php/Solvents
http://www.leeswoodprojects.com/wood.../thinners.html
__________________
Delmar O'Donnell Bolster. A bona fide Soggy Bottom Boy.
There is no certainty; there are only people who are certain. --Renouvier
Casually collect Proto with pebble field & other Proto Los Angeles items.
Bolster is offline   Reply With Quote
Old 01-15-2013, 03:48 AM   #13
Senior Member
theoldwizard1's Avatar
Quote:
Yes and no.
Yes, it cleans grease and dust and it evaporates quickly.
No, because some paints require a "metal prep" to "etch" new bare metal before painting. All of the expensive Imron paint (a HD Polyurethane Enamel) came off of my buddy's race car chassis because he did not use the prescribed DuPont metal prep !
theoldwizard1 is online now   Reply With Quote
Old 01-16-2013, 08:37 AM   #14
RonRock
Senior Member
RonRock's Avatar
Quote:
Ouch!
RonRock is offline   Reply With Quote
Old 01-16-2013, 08:41 AM   #15
rbonitz
Senior Member
Acetone will free superglue. (don't ask how I know this).
rbonitz is offline   Reply With Quote
Old 01-17-2013, 11:40 AM   #16
James E
Senior Member
James E's Avatar
William....
If I'm bi-polar, I can use any solvent.
James E is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
