Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 08-20-2013, 11:09 PM   #1
Hoot
Senior Member
Default Help identify electric motor on compressor
I would really appreciate some help identifying the electric motor on a used air compressor that I picked up off Craig's List. The main reason I bought it was for the Quincy 325-16 pump that was on it. But I cannot find a data plate on the motor and the seller couldn't tell me anything about it either. He did have it hooked up to a single phase, 30 amp service, without any issues. So I'm thinking it's a 3 or 5 hp motor. Any guesses from the experienced folks out there based on the pictures? I also think the air compressor was pieced together. The tank has a 1983 Melben data plate, and they are owned by Campbell Hausfeld, I believe. So I'm not sure this would have originially come with a Quincy pump...
I'm also considering doing a teardown on the head and cylinder to check things out. Some of the external stuff looks a little sketchy (looks like a gas pipe flex hose connecting the pump to the tank???). The pump has been disassembled previously but I'm not sure how good the work was.
Thanks,
Houston
Hoot is offline   Reply With Quote
Old 08-20-2013, 11:13 PM   #2
zkling
Senior Member
Default Re: Help identify electric motor on compressor
Nice compressor
For the motor I want to say Lesson, maybe baldor. Did you try pulling the terminal cover on the far side and see if there is a wiring diagram or any markings in there? It looks like it has been painted at the same time the entire compressor was.
More pics, definitely wouldn't hurt.
zkling is offline   Reply With Quote
Old 08-20-2013, 11:19 PM   #3
kingston
Senior Member
kingston's Avatar
X2 "try pulling the terminal cover on the far side"
__________________
My Little Shop
kingston is offline   Reply With Quote
Old 08-21-2013, 05:41 AM   #4
Hoot
Senior Member
Quote:
Sounds like a good start - I'll do that tonight.
-Houston
Old 08-21-2013, 10:12 PM   #5
Hoot
Senior Member
This compressor is definitely pieced together. It has a Melden tag on the tank but a Speedaire sticker (painted over) that was located just under the motor. There is also some areas of "Speedaire Greene" on the drive belt cover.
I did some more disassembly on the motor in an attempt to find out more about it. There was nothing under the terminal cover. There is a button on the side that I assume is a thermal reset. The entire motor was painted a mustard yellow at one time.
There were some partial numbers under the capacitor covers.
Can anyone tell me how bad this is?? The outer part of the pulley is cracked but the assembly seems very secure...
Old 08-21-2013, 10:56 PM   #6
jayrush13
Senior Member
jayrush13's Avatar
First off its not a pulley it's a sheave and I wouldn't hesitate to run that on an air compressor. But probably not on a motor that would run for hours on end. Just keep an eye on it and make sure it's not coming loose
jayrush13 is offline   Reply With Quote
Old 08-21-2013, 11:18 PM   #7
A_Pmech
A_Pmech's Avatar
The sheave isn't cracked. It's the taper lock bushing that's cracked. They do that sometimes.
It will probably run a LONG time like that, so long as you keep the taper bushing bolts tight. You can always buy a new bushing, they're not expensive.
__________________
Your Finest Hammer
Building The Paulding Racer - My Blog
My Garage Machine Shop
Quote:
Originally Posted by Sir Stanley Hooker
One stroke to produce power and three strokes to wear it out.
A_Pmech is offline   Reply With Quote
Old 08-21-2013, 11:32 PM   #8
Trey T
Senior Member
Trey T's Avatar
I would inspect it a little bit via inspection plate before committing to tear down. Don't waste your time rebuilding a tool. Let it run and see.
Trey T is offline   Reply With Quote
Old 08-21-2013, 11:34 PM   #9
A_Pmech
A_Pmech's Avatar
Quote:
Blasphemy!
__________________
Your Finest Hammer
Old 08-22-2013, 06:25 AM   #10
Hoot
Senior Member
I'll admit to knowing nothing about this pulley setup. I assume the tapered lock bushing and the pulley are pulled together by the bolts, and that locks them onto the motor output shaft? And where would you typically find a replacement? I looked on Grainger's website for tapered lock bushings, but didn't see anything that looked similar to what I have.
Old 08-22-2013, 03:13 PM   #11
A_Pmech
A_Pmech's Avatar
Hoot,
My mistake. It's not a Gates Taper Lock, it's a Gates QD bushing. I get the two confused sometimes.
Mcmaster stocks them:
http://www.mcmaster.com/#quick-disco...shings/=o6fh3b
They are easy to destroy if you don't follow the dismounting instructions here:
http://www.gates.com/downloads/Vol%2...ion%5B1%5D.pdf
__________________
Your Finest Hammer
Old 08-22-2013, 05:07 PM   #12
Hoot
Senior Member
Much appreciated. Although it would probably be fine as is, it would bother me to no end if I didn't try to fix it. And I had no idea what I was even looking at when I pulled the guard off and found the crack. I always thought pulleys were just bolted on... Again, thanks for the info. Especially the instructions...
-Houston
Old 08-22-2013, 06:10 PM   #13
iajonesy
Senior Member
We call these woods taper locks. If you send me the numbers that are stamped into the bushing,I'll see if I have one. I could send it to you for the cost of shipping it.Just PM me with those numbers. They will have the shaft size,the bushing number,and possibly the key size. To remove the bushing,use the threaded holes to push the bushing out of the pulley.
Mike
iajonesy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
