Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-19-2008, 08:22 PM   #1
jcummins
Junior Member
Default rafter cost
I have an oppurtunity to buy 33, 32 clear span 2x6 rafters. They are made of rough cut pine, I think, and told by a friend they are stout.
How much are these worth? I don't have enough money to build a pole barn type structure at the moment, but I am thinking of getting these and just tarp them for awhile.
jcummins is offline   Reply With Quote
Old 08-19-2008, 10:20 PM   #2
FunfDreisig
Senior Member
Default Re: rafter cost
Quote:
Originally Posted by jcummins View Post
I have an oppurtunity to buy 33, 32 clear span 2x6 rafters. They are made of rough cut pine,...
2x6 pine generally costs about $.40/ft for lengths up to around 16'. Longer 2x6s cost more/ft. But...
A 32 ft long 2x6 is quite long and not very strong all by itself. I can't imagine a 2x6 that long used as a "clear span rafter" unless it was twinned, used as the base of a truss, etc.
Could you confirm what length this lumber is?
Funf Dreisig
FunfDreisig is offline   Reply With Quote
Old 08-20-2008, 01:10 AM   #3
mtwaterguy
Senior Member
Something else to think about. If a contractor will be building this pole barn, he'll need load capacity specs. Even if you were to be the GC on the job you might run into problems with these. It would be a shame to lose the roof because of rafters that were not built to the correct specs.
mtwaterguy is offline   Reply With Quote
Old 08-20-2008, 12:32 PM   #4
blkhonda1991
Senior Member
Quote:
are you thinking about trusses?
blkhonda1991 is offline   Reply With Quote
Old 08-20-2008, 05:22 PM   #5
jcummins
Junior Member
OK....I'm not a builder. I called these rafters...but I also think of them as trusses. Can someone clarify the difference.
BTW .... I can get these for about $50 a piece...and we are talking 32 foot span. How much would new ones cost?
Old 08-20-2008, 06:28 PM   #6
mtwaterguy
Senior Member
Quote:
Yeah, sorry. When I read pole barn I pictured mine and it has trusses.
Old 08-20-2008, 08:00 PM   #7
blkhonda1991
Senior Member
these are trusses
these are rafters
Old 08-20-2008, 08:43 PM   #8
Steve in Mi
Senior Member
Steve in Mi's Avatar
They can be built better and stronger than what can be purchased at the lumber yard but a building inspector may require that you have a PE (lic.'ed professional engineer) sign off (signed letter with his seal) on them before he okays using them.
I think a phone call to your local lumber yard would give you a good idea of cost per truss. It's likely your location will influence the price some.
__________________
Work safe, have fun, enjoy the sport.
Remember that a guy never has to come down out of the clouds if he keeps filling the valleys with peaks. Steve
Steve in Mi is offline   Reply With Quote
Old 08-23-2008, 03:13 PM   #9
rickas47
Junior Member
For my 24' wide garage I had 5 scissor trusses & 14 "attic room" trusses built. Cost with tax & delivery was right at $100. a piece. This was a few months after Katrina, so the materials cost was a bit higher than now.
Trusses are built in a factory. They are held together with stamped steel plates underhigh pressure. A rafter roof is built on sight with nails. The pictures show the difference pretty well.
rickas47 is offline   Reply With Quote
Old 08-23-2008, 04:09 PM   #10
kbs2244
Senior Member
A truss is an assembly of boards.
A rafter is a single board.
Are these single boards or an assembly?
kbs2244 is offline   Reply With Quote
Old 08-23-2008, 05:19 PM   #11
IDASHO
Senior Member
Quote:
Typically cost $4-$6 per running foot.
So a truss spanning 20" would cost $80-$120 each.
__________________
See my garage build here:
http://www.bonnefinstudios.com/kwb/paradise/garage/
IDASHO is offline   Reply With Quote
Old 08-23-2008, 06:40 PM   #12
Steve in Mi
Senior Member
Don't you think it better to suggest calling than to provide a range that allows for 50% slop?
Besides, your numbers don't agree at all with what I find in Menards flyer that comes in the paper. The highest price per foot in it is 30 footers at $54.87. They don't list a 20' truss but the 22' is $36.79.
Like I said, call the place you would be buying from.
Note the Menards prices are for clear span and 62lbs./sq.ft. @ 24" spacing.
__________________
Old 08-28-2008, 04:54 PM   #13
jcummins
Junior Member
I have not seen them, but I understand they are trusses. I think these would be a very good buy, but right now, I've got other expenses (ranch), and I'll have to let them pass.
Old 08-28-2008, 07:38 PM   #14
IDASHO
Senior Member
As I said, TYPICAL COST. This is not to be disputed, this is what most builders run with. This is also based upon last summers figures. Cost of materials + labor + markup + current market.
Your quotes per menards are probably old-stock or limited stock left over from a special order. There is no way their regular cost can be that low. It barely covers materials. Let alone labor + mark-up.
Unless they are actually taking a loss on every sale, which is possible due to the crappy market right now.
I just checked their online weekly flyer. No pricing listed.
And of course they should call around. They are going to have to call around to get them ordered anyhow.
__________________
Old 08-28-2008, 08:59 PM   #15
Steve in Mi
Senior Member
Last weeks sale prices may be better than a year old estimate.
__________________
Old 08-29-2008, 12:39 AM   #16
IDASHO
Senior Member
No, I say "last summer" as in the summer we just had. The one that is coming to a close. Being in the building supply biz, we are very keen on building seasons. Our summer season is coming to a close.
That said, this winter looks to be VERY slow. We ( along with the rest of the nation ) can only hope that the market rebounds a bit next summer.
__________________
Old 08-29-2008, 04:02 AM   #17
Kevin54
Senior Member
Kevin54's Avatar
At $50/pc you had better jump on them. A few years ago I bought 28 footers and they were $128/pc
Kevin54 is offline   Reply With Quote
Old 08-29-2008, 08:07 PM   #18
IDASHO
Senior Member
Quote:
Yep, Right about $4.50 a foot.
Which fits the bill for my estimate of $4-$6 per running foot.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
