Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 08-30-2013, 05:07 PM   #1
GIG25
Junior Member
Default Help Lithonia high bay wiring
I purchased 4 Lithonia High Bay lights for my shop. The lights will be in the middle of two 3way switches. After calling the manufactuer due the wiring instruceions on the box, did not match what the fixture had (black, white, red wires). the red wire is actually linked to a gray wire. Tech support stated to connect the Red (gray) wire to the black wire in order for the lights to have full power. My experience in this area is limited and I don't want to burn up the light. I need to stay with in my budget or I would hire someone to complete this project. I attached a pic of the ballast and diagram. Thanks for the help.
GIG25 is offline   Reply With Quote
Old 08-30-2013, 05:26 PM   #2
pattenp
Senior Member
pattenp's Avatar
Default Re: Help Lithonia high bay wiring
Hook the gray to the black, that's what the diagram says to have 100% light level. You can put a switch on the gray to switch between high and low level lighting. An open gray gives you low.
pattenp is offline   Reply With Quote
Old 08-30-2013, 09:02 PM   #3
GIG25
Junior Member
Thanks for the information. I'll get I done in the morning.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
