Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 09-17-2013, 01:48 PM   #1
krdiesel03
Senior Member
krdiesel03's Avatar
Default New Max Axess Auto Ratchet Coming in October
Whether you're changing a tire or working on your engine, the new Craftsman C3 19.2V Max Axess Auto Ratchet delivers fast, powerful and portable ratcheting without a power cord or air hose - designed with the mechanic in mind. Available October 19th! #00939558
FEATURES:
Ratchet head delivers up to 360 in. lbs. torque when used with included battery for efficient bolt tightening and removal.
Compatible with Craftsman Max Axess® Sockets and other Standard Drive Sockets (when used with adaptor).
Forward/Reverse toggle changes the direction of rotation for tightening and loosening.
Lock switch prevents unintentional starts.
LED work light provides extra light for better visibility.
Variable-speed Steel Paddle Switch delivers higher speed with increased pressure and lower speed with decreased pressure.
Includes Lithium-Ion battery for long-lasting, fade-free power.
Overmold Grip with Micro-texture adds to user comfort.
Compact design facilitates use in tight spaces.
krdiesel03 is offline   Reply With Quote
Old 09-17-2013, 02:10 PM   #2
warmpancakes
Senior Member
warmpancakes's Avatar
Default Re: New Max Axess Auto Ratchet Coming in October
30 Ft lbs, not gonna remove alot of bolts with it
__________________
" if it can be done wrong, I've usually done it at least three times"
"If you want to walk the heavenly streets of gold.......you gotta know the password, "Roll, tide, roll!"
Bear Bryant
Note: This post may contain misspellings, grammatical errors, disorganized sentence structure, or may entirely lack a coherent theme. These elements are natural to the process of writing, and will only add to the overall beauty of the post.
warmpancakes is offline   Reply With Quote
Old 09-17-2013, 02:12 PM   #3
trout
Senior Member
trout's Avatar
Quote:
I caught that too, looks like they're hoping their average customer can't tell the difference between feet and inches. They're probably right though.
trout is offline   Reply With Quote
Old 09-17-2013, 02:20 PM   #4
firebox40dash5
Senior Member
19.2 volts? I'll keep it in mind if I ever need to run a nut down 4' of all-thread in the middle of a room.
firebox40dash5 is offline   Reply With Quote
Old 09-17-2013, 02:33 PM   #5
woody 73
Senior Member
Now boys behave because santa is going to buy you and 100,000 other dads that for X-mas
woody 73 is offline   Reply With Quote
Old 09-17-2013, 02:49 PM   #6
bimmerZ5
Senior Member
this is not meant to be a hammerhead. even the IR IQv20 R3130 puts out only 54ft-lbs of torque. as long as the ratchet head locks, so you can manually break a fastener loose, and then use the powered portion to drive the fastener off, this should have its use. the fact that they are using the "max access" stuff, might mean the design is very low profile.. if so, the ability for this tool to get into tight spaces can be pretty valuable.
would really like to see what it looks like? I can certainly search, but if anyone has a link handy... that would be helpful...
bimmerZ5 is offline   Reply With Quote
Old 09-17-2013, 03:19 PM   #7
krdiesel03
Senior Member
krdiesel03's Avatar
here is a photo
Old 09-17-2013, 03:29 PM   #8
retDAC
Senior Member
My first generation C-man 19.2 drill is rated at 410 inch-lbs.
__________________
Where your treasure is, there will your heart be also.
Best of Luck in Your Honorable Endeavors!
Dave McDaniel
retDAC is offline   Reply With Quote
Old 09-17-2013, 03:40 PM   #9
03protege
Senior Member
I guess that would be good if you deal with a lot of threaded rod but otherwise I would just take the Milwaukee m12 ratchet.
03protege is offline   Reply With Quote
Old 09-17-2013, 03:46 PM   #10
krdiesel03
Senior Member
krdiesel03's Avatar
Quote:
Yes you would, But this is for people that already have an investment in the C3 line,
Old 09-17-2013, 06:55 PM   #11
Hootbro
Senior Member
Hootbro's Avatar
Quote:
Whether someone is "invested" in the C3 line or not, the question has to be asked if this is a practical tool and not some Christmas season gimmicky tool that Sears is so known for?
Obviously you are a collector of C3 and would buy a automated C3 toilet paper dispenser if Sears made one. The issue I have and many others is if this is really a practical tool given then the big ass 19.2V battery hanging of the ass end of it?
This really would have been a better tool launched on the Nextec 12v system.
Hootbro is offline   Reply With Quote
Old 09-17-2013, 07:22 PM   #12
rickhigginshtbr
Senior Member
rickhigginshtbr's Avatar
looks good from above the battery.... I'd probably get it if it had the same specs or similar for the nextec line.
__________________
Wanted:
Bonney Streamline Wrenches # 1158/1163/1168/1170
Craftsman Pro Screwdrivers # 47166 / 47197 / 47199
'59ish Craftsman Pedestal Power Tools - Alien Head Planer (stand only) / 24" Scroll Saw Double Pedestal
eBay Store
rickhigginshtbr is offline   Reply With Quote
Old 09-17-2013, 07:27 PM   #13
krdiesel03
Senior Member
krdiesel03's Avatar
I do agree that this would be better with the nextec, I do think it would be a pain to use under my truck. The newer LIon battery is 1/2 the weight of the nicad but the size would just get in the way.
Old 09-17-2013, 07:32 PM   #14
The Ratchet Man
Senior Member
The Ratchet Man's Avatar
Quote:
My thoughts exactly. Some power tool designs are doomed simply because the manufacturer chose the wrong battery platform.
The Nextec system could've produced the power for the stated torque specifications. If you stick a big, clunky battery on the end you've defeated the purpose of the head design.
On the other hand, if they did add it to the Nextec line, I would probably buy it.
The Ratchet Man is offline   Reply With Quote
Old 09-17-2013, 07:51 PM   #15
krdiesel03
Senior Member
krdiesel03's Avatar
They may have one coming for nextec, Most of the nextex was cleared out last month, and new tools are expected in October, I just do not have a inside on the nextec line just the c3.
Old 09-20-2013, 10:39 PM   #16
Ign
Senior Member
I agree w most of above:
-this is probably the wrong platform w the huge battery
-better suited for Nextec 12V
-why is everyone so concerned with ultimate torque? You break the fastener free manually then spin it off with power. Much more torque than that in a non-impacting tool and you just twist the operator if you don't twist the fastener first.
-I'd buy an auto TP dispenser if Milwaukee made it for M12
Ign is offline   Reply With Quote
Old 09-20-2013, 10:42 PM   #17
Ign
Senior Member
Quote:
To go next to all the "Dog Bone" wrenches and RoboGrip pliers??
Old 09-20-2013, 10:44 PM   #18
czgunner
Senior Member
You've got to be kidding me
__________________
U.S. Army Combat Vet
czgunner is offline   Reply With Quote
Old 09-20-2013, 10:57 PM   #19
LORDDiESEL
Senior Member
LORDDiESEL's Avatar
I'll take the AC delco at 57 ft/lbs over the milwaukee or C-man. It's also cheaper with two batteries for a buck 40.
http://www.acdelco-tools.com/index.p...product_id=106
LORDDiESEL is offline   Reply With Quote
Old 09-20-2013, 10:59 PM   #20
LORDDiESEL
Senior Member
LORDDiESEL's Avatar
Quote:
I caught that too. That thing couldn't twist a nipple, let alone change a tire.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
