Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 08-27-2008, 01:55 AM   #1
PoorOwner
Senior Member
Default how to lubricate ball bearing slides?
I have the kind of slides that if you put more weight on it, it slides smoother, not the kobalt or craftsman kind that fly open with the slightest pull.
What kind of oil should I use and how to apply it ?
PoorOwner is online now   Reply With Quote
Old 08-27-2008, 02:39 AM   #2
Nealcrenshaw
Senior Member
Nealcrenshaw's Avatar
Default Re: how to lubricate ball bearing slides?
I highly recommend this product by PB Blaster.This stuff is Amazing!!!! next time i'm at the store i'm buying the whole case.
Does not evaporate.
http://shop.blasterchemical.com/disp...?p=50003&pid=1
__________________
"Do one thing, and do it well"
Nealcrenshaw is offline   Reply With Quote
Old 08-27-2008, 05:29 AM   #3
eschoendorff
Director of Bands
eschoendorff's Avatar
www.corrosionx.com
__________________
When you die, I want your tools.
Quote:
Originally Posted by Moose-LandTran View Post
Why bother? Natural selection will take care of them. If it doesn't, a 12-gauge can take care of the unnatural selection...
eschoendorff is offline   Reply With Quote
Old 08-27-2008, 06:05 AM   #4
Merkava_4
Superlube #21030. It's a light viscosity synthetic grease that's clear and won't be seen when you pull the drawers out. It's also the official supplied lube for Snap-on's ratchets.
To apply, you smooth on a thin coat around the outside and inside of the slide members and then you push some in between the steel balls with your finger if you can reach them. Move the drawer in and out to work the grease in.
Merkava_4 is offline   Reply With Quote
Old 08-27-2008, 11:11 AM   #5
PoorOwner
Senior Member
Merk, how thin is the superlube, is it like silicone grease such as SilGlide?
Old 08-27-2008, 11:31 AM   #6
Merkava_4
I'm not sure about SilGlide, but I have some Dow Corning #111 for using as an o-ring lube and it's nowhere near as thick as that.
Old 08-27-2008, 03:26 PM   #7
PoorOwner
Senior Member
where do you buy the super lube?
Old 08-27-2008, 03:57 PM   #8
Lightning
Senior Member
I use water resistant marine grease. It is the same grease I use for my boat trailer wheel bearings.
Lightning is offline   Reply With Quote
Old 08-27-2008, 05:08 PM   #9
PoorOwner
Senior Member
Quote:
Does not evaporate.
Where did you buy this? I need something like this for around the house and I hate WD40, doesn't lubricate well
Old 08-28-2008, 12:18 AM   #10
PoorOwner
Senior Member
I was only able to find some 3 in 1 oil today, will it work? I read someone on here uses it on their drawers, I couldn't find the post tho.
Old 08-28-2008, 12:23 AM   #11
Merkava_4
Quote:
The 3 in 1 oil might wash out the grease that's in there now. All those oils you've read about in other posts are for friction slides.
The Superlube #21030 is not easy to get. I got mine from an industrial supply store. The upside is that it will stay in your slides for a very, very long time.
Old 08-28-2008, 12:39 AM   #12
PoorOwner
Senior Member
so is the superlube like pasty or what?
who is to say ball bearings are supposed to use silicone based lubricant instead of oil? Because I think I have seen both used in tool chests from the factory.
Old 08-28-2008, 12:57 AM   #13
Merkava_4
The Superlube is not pasty; it's more of a cream consistency and it may not be silicone; the manufacturer refers to it as a "synthetic."
Accuride Co. makes the slides. If you buy the slides new, they'll have a clear grease inside them. Grease sustains loads better than oil does and provides for smoother, quieter operation.
Old 08-28-2008, 01:38 AM   #14
PoorOwner
Senior Member
so, 3 oz seems a bit small to me?? maybe get 2-3 tubes?
Old 08-28-2008, 02:25 AM   #15
Merkava_4
If you're buying it online, I'd say 3 tubes since the shipping will be the same for 1 tube anyway. If you're getting it in town, it depends on how far you live from the source.
I think 1 tube will lube all the slides since you're not suppose to slop it on there anyway. If you can take the drawers out, that will allow you to gain more access to the inside of the slides.
Old 08-28-2008, 08:04 AM   #16
VDubJoe
Senior Member
VDubJoe's Avatar
Heres a link to Mil-com. Its all we use on guns. Bonds with the metal and works great. Most good gun shops or tackle shops carry it. If it works well on a Military gatling gun i would think drawer slides would be no problem. I'm going to give it a try.
http://www.mil-comm.com/index.php?op...word=corrosion
Joe
VDubJoe is offline   Reply With Quote
Old 03-01-2011, 07:32 PM   #17
les_garten
Location: PSL, FL Next door to Megan FOX, and down the street from Vanilla ICE
I'd like to bump this old thread.
I have a Snap-on KRL Roller and Top Box. I've had it maybe 3-4 years. About a year the slides starting feeling "thick and gummy". Especially when the temp got below the 70's. So I called Snap-on and they told me to get some kind of stuff, the person I talked too didn't inspire confidence in me that they knew what they were talking about. I think the lube was some kind of sparay foaming stuff that I think was silicone based. Well, now it is back like it was and the lube just plain feels gummy again.
It's warming up a little, so things are starting to loosen up, but it's irritating that my Pretty Snap-On feels like the sliders are coated in Molasses.
So what's the best way to handle this? And what to use?
les_garten is offline   Reply With Quote
Old 03-01-2011, 07:37 PM   #18
AZ_Catskinner
Senior Member
AZ_Catskinner's Avatar
I'd hit them with a little CitriSolve (or similar), let them dry for a day or two and then hit them with some fresh lube. I'm personally an advocate of white lithium for the slides, as it's pretty much maintenance free.
AZ_Catskinner is offline   Reply With Quote
Old 03-01-2011, 07:42 PM   #19
Toolhorder
Senior Member
Toolhorder's Avatar
I'd just get a clear caliper pin grease and add a small amount to the slides. Easy
Toolhorder is offline   Reply With Quote
Old 03-01-2011, 07:59 PM   #20
les_garten
Quote:
Interesting looking stuff, thanx!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
