Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 09-18-2013, 05:33 PM   #1
boyAND1
Junior Member
Default Can I use an external tankless water heater safely inside for floor heat
Hi,
I built my shop about 2 years ago and want to finally get my floor heat going which has just had my 3 loops hanging out of the floor with duct tape on the ends. I live in ND and each loop is just under 300'. Shop is about 960 sq ft.
Question is I understand that the condensing boiler or more efficient boiler will save money in the long run but prices I have seen basically justify an investment that would take 20-30 years to payoff. Due to my location I would have to use LP or have off peak electric installed. I firmly believe the heat from LP is better so going that route.
Now back to the question, I have found an external or outdoor tankless water heater that claims 95% efficient for about $800. Question is, would it be safe to install this in my 960 sq ft shop inside where the loops come out. If it matters, the shop is 26W x 36D x 10H. The loops come out about 2/3 back on the left wall (about 24' back). I don't do any welding or anything like that. I am just not sure why I could not use this inside assuming that I vent the main gasses outside through the pvc exhaust.
Oh yeah, I did do a heat loss online and was very conservatively in the 50-55K range, but I doubt it will take that much. I only plan on heating to about 55 degrees and have a large wood burner inside (forced air) to heat up the rest when I will be out there all weekend. But the heat might be so great I just say screw it.
Any thoughts? By the way I love this forum!!
__________________
boyAND1
Knowledge is power
boyAND1 is offline   Reply With Quote
Old 09-18-2013, 10:08 PM   #2
Jackfre
Senior Member
Default Re: Can I use an outdoor tankless water heater safely inside shop
NO! Google carbon monoxide and read for a while.
Jackfre is offline   Reply With Quote
Old 09-18-2013, 11:29 PM   #3
Fast LT1
Senior Member
^^^^ lol!!
Fast LT1 is offline   Reply With Quote
Old 09-19-2013, 07:36 AM   #4
boyAND1
Junior Member
I said i would vent it outside. Is there any real good reason i should not be able to do this? What is the biggest difference b/t indoor and outdoor boilers? --Other than it being outside.
__________________
boyAND1
Knowledge is power
Old 09-19-2013, 08:16 AM   #5
Jackfre
Senior Member
Different manuf of tankless have different ways of dealing with indoor/outdoor units. Find out the model/make of the unit, go to their website and read the install manual. It should detail the manuf requirements.
Old 09-19-2013, 08:54 AM   #6
anthony666
Senior Member
anthony666's Avatar
mount it outside, pass your heavily insulated feed and return lines through the wall .. done & dusted
anthony666 is offline   Reply With Quote
Old 09-19-2013, 09:23 AM   #7
sands35
Senior Member
Pay attention to the details of the combustion exhaust. Likely category 3 - which means stainless steel parts and sealed joints with specific spacing and wall vent designs.
If you are putting it into a wood or body shop with lots of suspended contaminants, you will need an external intake as well.
Jackfre is right, get the manual and read.
sands35 is offline   Reply With Quote
Old 09-19-2013, 09:24 AM   #8
rsa
Senior Member
rsa's Avatar
Quote:
Bingo—or buy an indoor unit.
This two part video shows the differences between outdoor and indoor types:
http://www.youtube.com/watch?v=mqPY_Nn4nyQ
http://www.youtube.com/watch?v=F9SxGPxN_HQ
__________________
Disclaimer: I'm not a building professional.
rsa is offline   Reply With Quote
Old 09-19-2013, 12:54 PM   #9
boyAND1
Junior Member
The manual does not even have an option to hook up a flue. It is all built into the front of the unit. so guess that will not work. I don't want to hook that up outside when it hits -30F here in the winter before the wind chill.
Thanks for the help.
__________________
boyAND1
Knowledge is power
Old 09-19-2013, 08:57 PM   #10
Jackfre
Senior Member
Good decision. Low cost is a part of a system equation, but should not be the sole criteria for the decision. Forge onward!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
