Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 09-25-2013, 06:37 PM   #1
johninct
Senior Member
Default Snap-On YA 700 rebuild ???
I am in the process of taking my Snap-On YA 700 apart and am thinking about assembly and have some questions.
On the Hyd. pump assembly chevron seals, how tight do I make that little nut that holds them in place? I am thinking that the tighter I tighten the nut, the more the seals expand. Do I tighten the chevron seal nut with the plunger inside it's sleeve?
How tight do I tighten the big tank nut? I don't want to go too tight. I am thinking my 3/4" Impact will be too much?
Do I use a thread sealer on the big tank nut threads, pump assembly threads, safety valve set screw threads, pressure and suction valve screw and the gallery plug?
What lube should I use on the O-rings and seals?
johninct is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
