Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-31-2008, 02:01 PM   #1
Piper
Senior Member
Piper's Avatar
Default cfm compared to psi chart?
I'm wondering if there exists a chart which compares CFM and PSI? I understand the differences with each of these units but here's where I'm coming from. I have a compressor that states "4.2 CFM at 120 PSI, or 6.4 CFM at 90 PSI" (these are just examples). So, the new compressor I'm considering buying states 19 CFM at 175 PSI. Well, most of my tools run at 90 PSI so I'm not too sure how the 175 helps me determine the "useful" CFM.
I've done a bit of searching but come up with very little. So, does anyone have any quazi scientific info on these 2 measurements? I've been told that if you're running a tool at roughly 1/2 the rated PSI quoted (so in my case 175/2 = 87.5) that the CFM would basically double or be at 38 CFM. This somehow seems kinda logical initially but I don't see that it's likely. FWIW, this is a 2 stage 80 gal compressor with a 5 hp motor, 220v.
Piper
Piper is offline   Reply With Quote
Old 08-31-2008, 03:19 PM   #2
russlaferrera
Senior Member
Default Re: cfm compared to psi chart?
I don't know of any charts. MY understanding is about design and size (cubic inches). A two stage designed compressor will develop higher pressure. The size of the piston provides the CFM.
The requirements or specs given tell you the output at a pressure rating. Most air tools operate @ 90 psi. Withe a 175 psi reserve you are allowed more reserve because at the tank bleeds down to the cut in pressure their is no interruption in working, as the working pressure is always over 90 psi.providing the compressor is large enough.
I hoped I answered your question?
russlaferrera is offline   Reply With Quote
Old 08-31-2008, 03:20 PM   #3
W-Cummins
Too much stuff
W-Cummins's Avatar
The only chart of CFM VS PSI that would be created would be for a specific model of compressor pump. I'm sure that the compressor manufactures have these charts of their pumps performance. I have not seen them used in the marketing of the compressors though. Most machines are listed at their free air displacement, 90 psi and max psi, for the pumps I have seen the specs on.
It doesn't work that way at all. The CFM at the different pressures is directly related to the individual pumps efficiency.
__________________
My Garage Journal shop pictures
1998 Dodge 3500 12 Valve TST 10, 3K GSK, ddp stage IV injectors, SB con-Fe
1987 Chevy 3500 24 valve Cummins, Nv4500, DD#2 injectors, Edge Comp
1955 Ford F100
1941 Chevy Panel
W-Cummins is offline   Reply With Quote
Old 08-31-2008, 03:34 PM   #4
timgr
Senior Member
There's a simple gas relationship that says P1 V1 = P2 V2. It just means that you can trade off pressure for volume, and vice-versa. With no other considerations, you're right that the volume doubles at half the pressure.
I think the numbers don't add up just because the compressor has a harder time producing a higher pressure in a given time. Note that 4.2 * 120 = 504, and 6.4 * 90 = 576, so the amount of extra work done by the compressor (conversion loss) goes up as the pressure goes up. Not sure why this is - maybe the compression cycle is less efficient as the pressure goes up. But anyway, yeah the volume will double if you let the pressure drop by 1/2.
__________________
'75 AMC Jeep CJ-6 304/T-15
'77 AMC Jeep J-10 258/T-15
'82 AMC Jeep J-20 360/T-18
'95 VW Golf Sport 2D 2.0L
timgr is offline   Reply With Quote
Old 08-31-2008, 04:43 PM   #5
W-Cummins
Too much stuff
W-Cummins's Avatar
Quote:
NO NO NO NO NO NO NO NO NO.......
UNITS!!! CFM = Cubic Feet per MINUTE
is the thing we are interested in here
The numbers don't' add up because it's not a calculated value, it would be a measured value. To make a chart like that the manufacture would RUN the pump and record the observed values and plot them.... The equation P1V1=P2V2 is used on a system that those values (pressure and volume) are the only ones changing. Start changing the stuff that happens in the compressor you move into a set up that would be VERY difficult to calculate.
William...
Old 08-31-2008, 05:17 PM   #6
timgr
Senior Member
William, if you have minutes on both sides of the equation, it should not matter. As a rough estimate, I believe it is correct. I understand what you are saying, but the question here is what the compressor can deliver, not what the pump can deliver.
Do you agree that the compressor can deliver 19 CFM at 175 psi? I presume that this is at 100% duty cycle - essentially a steady-state. Then a regulated output, set to 90 psi, is only limited by the P*V limit of the source. The regulator lets the 175 psi air expand into the delivery space until the set pressure is reached, ie 90 psi.
I'm not saying that it's an exact correspondence, but I think it's a good estimate. Even the the 504 and 576 are within about 15% of a P*V relationship.
__________________
Old 08-31-2008, 07:51 PM   #7
logical
Senior Member
William is right. CFM is basically the amount of production it can deliver at a given level.
logical is offline   Reply With Quote
Old 08-31-2008, 08:32 PM   #8
timgr
Senior Member
Quote:
Sorry, I think you miss the point. I'm not disputing the output of the compressor. If you take any volume of gas and reduce its pressure by one-half, you will double the volume (ignoring the change in temperature).
The regulator releases gas into the lines at the supply pressure until the receiving volume (the line) reaches a certain pressure. It's a simple feedback system. Does not matter if it is flowing or not - in fact, the regulator will only work when gas flows.
If the downstream pressure is halved, the volume will double. The rate of production does not change, only the pressure changes. If you count the molecules, the amount of gas (number of molecules) does not change.
__________________
Old 08-31-2008, 10:02 PM   #9
roofster
Senior Member
roofster's Avatar
I agree with William. On the few compressoers I have seen that list a CFM at 90 or 100PSI it is no where near double the CFM at 175 psi. P1V1=P2V2 is the ideal gas law. It works more like this. A 10 gallon tank at 100 psi will be 50 psi in a 20 gallon tank.
I saw somewhere, maybe Eaton compressors, that displaced CFM is bore times stroke times pump rpm. Seems to me it would be more Pi/4 x bore squared x stroke (areaxlength) x rpm. Which is fine until you have a mulit cylinder 2 stage with different bores and strokes. Then you Best start measuring. Then consider pump efficiency and loses to get an actual CFM. Finally consider it takes more work to get to 175 psi, but yet you still only have a 5 hp engine, so the pump up time increases but not per the ideal gas law.
roofster is offline   Reply With Quote
Old 09-01-2008, 07:23 AM   #10
Piper
Senior Member
Piper's Avatar
So this is more involved as I thought it was going to be. I guess I should talk to the manufacturer. I think generally that we all agree that at 90 psi the cfm will be just as high (and likely higher) than at 175 psi. I just kind of find it strange that they'd indicate 175 which is essentially a pressure that isn't used. Why not rate it at 90? I dunno. I'll phone the manufacturer on Tuesday and see what they say.
I just want to buy the compressor once and have enough air for my sandblaster, air tools etc that I don't ever say, "gee, I should have got the ..." Buy once, cry once.
Piper
Old 09-01-2008, 08:18 AM   #11
cw_racefan
Senior Member
The relationship between CFM and PSI has nothing to do with ideal gas equations or the pressure volume relationship. It is completely compressor dependent, thus as William said, the only table would be for a given compressor. Flow rate is different than volume. A more better/more efficient compressor can produce a higher flow rate at a given pressure than a less efficient compressor. To the original posters question, you need to look at the requirements of the tools you want to use, they will all have a CFM @ PSI rating. Compare those requirements to the specs of the compressor you're looking at, and make sure it will supply the flow rate for the highest CFM tool you want to use. BTW, as an example, one impact wrench may require 4 cfm @90psi, where another may require 8cfm @90psi, so your requirements are tool dependent as well.
Craig
cw_racefan is offline   Reply With Quote
Old 09-02-2008, 02:54 PM   #12
Piper
Senior Member
Piper's Avatar
so to finish off with what I found from the manufacturer. He told me that they always rate 2 stage compressors at 175 psi and that at 90 psi I could expect an additional 10% CFM. So, 18.7 CFM at 90 psi.
Thanks for all your thoughts!
Piper
Old 09-02-2008, 04:22 PM   #13
Lyaec350
Senior Member
If you have two tanks and just dump air from one to the other, the P1V1=P2V2 relationship holds true, but in a time dependent system (a compressor pump w/ flow) the PV relationship won't hold up.
Think about it this way, you're pumping up an empty, closed, tank from 0 to 100psi. At first the compressor will find it very easy (little work) to push a unit (cubic foot of air) into the tank. Since the pump can only do a fixed amount of work in a given time, as the pressure increases and the amount of work to push in each unit of air increases, the time to pump that unit of air in will increase as well, resulting in a decrease in the cubic feet per minute pumped in to the tank. Basically it is load dependent and it is not a linear relationship.
It is based on the "load" that the compressor sees at the other end of the system.
Lyaec350 is offline   Reply With Quote
Old 09-02-2008, 09:29 PM   #14
roofster
Senior Member
roofster's Avatar
Piper,
As you shop and compare you will notice that some single stage compresors will have higher cfm ratings at 90 psi than more expensive 2 stage units. I don't know for sure, but the claimed advantages of a 2 stage (175 psi) compressor are cooler air due to less work and therefore dryer air, maybe less noise and more storage. I read that there is more air in a 60 gallon tank at 175 psi than in an 80 gal at 90 psi. I'm looking for a unit to do sandblasting and have decided on a 2 stage one.
Old 09-05-2008, 07:11 PM   #15
timgr
Senior Member
Sorry to bring this up again guys, but none of the explanations previously given were very satisfying. So, I think it might be helpful to thrash it a little more.
First, let me say that my reasoning about this seems to have been completely wrong. I think my understanding of the physics is right, but my (and I think all the other posters) interpretation of the compressor specs is wrong.
I did a little research, and some arithmetic, and here's what I think is going on.
First, the CFM specs for the compressor always are in terms of free air at the intake. So, 19 CFM means an actual flow of air at 185 psi going into the tank is 19 CFM * 15 psi / (185 + 15 psi) = 1.4 CFM. I guess this way of specifying the flow is as good as any, since when all the work is taken from the air (ie at the exhaust of the tool), it's back at atmospheric pressure.
The specified pressure is the 'set point' of the compressor. When the manufacturer says that the CFM increases by 10% at 90psi, that means that the amount of free air that the compressor can pump increases to 19 + 1.9 = 21 CFM. (I think that 18.7 is 17 PSI + 10%? Maybe the OP meant 17, not 19). This makes sense, because when the set point is lowered, the pump is working against less back pressure, so the volume pumped goes up a little.
However, with the set point of the compressor at 90 psi instead of 175 psi, the reserve of volume in the tank is cut by about 1/2: the same volume will only hold half as much air at half the pressure. You would hardly ever want to do this, since the amount of work (P*V=W) that the compressor can do on a full tank of air is also halved. The only time this would make sense would be at near 100% duty cycle, and where you need more than 19 CFM and less than 21 CFM - ie not often.
So, when you set the regulator to 90 psi because the tool requires it, that only affects the rate at which air is released, and it's not really related to the pressure that the compressor is spec'd to. The higher pressure only means that you have more reserve in the tank, since (I presume) the tools are spec'd in atmospheric air at the outlet, just like the compressor is spec'd in atmospheric air at the inlet.
__________________
Old 09-05-2008, 11:41 PM   #16
W-Cummins
Too much stuff
W-Cummins's Avatar
Well if you must
Well one out of three isn't too bad.... Your physics was wrong in thinking that you can use a static equation, P1V1=P2V2 in a dynamic system. You can't make it a dynamic equation by just adding time to it.
Well your still at it, You CAN NOT add time to the static Ideal gas eq. So all you get above is CF NOT CFM!!!
Here is the correct eq you used
To find cubic feet of either compressed air or free air
cu.ft. comp. air X (psig + 14.7) = cu.ft. free air X 14.7
  • cu.ft. comp. air [ Cubic Feet of Compressed Air ]
  • cu.ft. free air [ Cubic Feet of Free Air ]
Ok here again the train departs from the track....
The manufactures I have seen don't say that the CFM increases by 10% They say that the free air spec is the HIGHEST CFM the pump can put out. Then if they list a 90 psi rating it's lower than the free air spec. and then the Max rated pressure has an even lower CFM. Exactally what you would expect to see as the pump works harder to compress the air to the higher pressure, it can't match the free air CFM rating IE. a 100% pumping effecency at say 175psi. So you see ratings like 20cfm free air, 18cfm @ 90 psi and 17. cfm @ 175 psi..... on a 2 stage 5 hp compressor....
Dam I will say at least your consistent ..... P*V NOT = work
William....
Old 09-06-2008, 10:00 AM   #17
logical
Senior Member
Toss those formulas and wrap yer mind around this:
You pump the tank up to 150 psi, then you start bleeding off air at 150 psi with the pump running. Now keep increasing the rate that you bleed off (use) the 150 psi air. At some point the pump can't keep up and your tank (air supply) drops below 150 psi. The bleed rate where this happens is your max CFM at 150 psi. So if this happens when you get up to bleeding off 60 cubic feet per minute...then your compressor is capable of 60 CFM @ 150 psi.
Do the test again at 75 psi and it will be a different CFM. The relatinship might be 2:1 but if it is, it is just a happy coincidence. The relationship curve is unique to every compressor...pump size, pump configuration, pump design, pump efficiency, motor HP, motor performance under load, etc. The only place p1v1 = p2v2 is when you are filling your bicycle tire with a portable harbor freight 5 gallon tank and the air stops flowing.
Old 09-06-2008, 10:45 AM   #18
timgr
Senior Member
Hey William - I hope you don't take this the wrong way. I appreciate your input on this... and I could be wrong, but here's my response.
Quote:
In this case, sure you can. It's just a rate. There's no fancy dynamic dependence. It has no functional dependence other than "t", a linear term. See below.
Here you've restated what I wrote, in a different form: CFM1 * P1 = CFM2 * P2. If "t" is a unit of time, CFM1 = V1/t. CFM2 = V2/t. P1 V1/t = P2 V2/t. P1 V1 = P2 V2. The 14.7 is an offset due to the atmospheric pressure, always present - free air pressure is already 14.7 psig. You've contradicted your claim in the first paragraph.
In my reply, I rounded 14.7 to 15 - something I'm inclined to do because of my training/work.
The OP wrote that the manufacturer's rep said that the CFM rating of the compressor goes up by about 10% when the setpoint pressure is reduced from 175 psig to 90 psig. Not my number - just trying to understand the rep's claim.
I'm not sure what you are disputing here. My reading says that the CFM rating is free air at the input, ie CFM of atmospheric air. You have a problem with that? My reading also says that the pressure rating is not the regulated pressure at the output, but the setpoint pressure of the compressor. Do you have a problem with that?
Sure it is. Work = force * displacement. Let's define some new variables.
F = force
A = area
L = length aka displacement
Now, P=F/A, V = L*A.
P*V = F*L*A/A = F*L = W, qed.
You can also do this by dimensional analysis.
Work is joules, in units of N-M (newton-meters).
Pressure is N/M^2. Volume is M^3.
N/M^2 * M^3 = N-M.
__________________
Old 09-06-2008, 10:52 AM   #19
timgr
Senior Member
The question then is, where do you measure the CFM? Air changes volume at different pressures and temperatures. As I understand it, volume is measured at the input. It does not really matter if you measure it at the input or the output as long as the P and T are the same. Mass (the actual amount of air) is always conserved.
__________________
Old 09-06-2008, 11:40 AM   #20
logical
Senior Member
.......... Mass (the actual amount of air) is always conserved.
No, mass is released and then if the compressor has the balls to keep up, it is replenished. Again, you need to think of the ability of the pump to keep up with a rate of use....flow. (a given CFM rate of 150 psi air is not the same volume as that at a different psi).
My 12v cigarette lighter pump will make 150 psi but not very fast.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
