Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 10-03-2013, 06:07 PM   #1
dealingdave
Junior Member
Default Grinding Concrete - Removing Rock Solid Polyurea
I just put the Rock Solid Polyurea coating (color tint added to the bag and then shake) this weekend. I applied the base coat as directed and than added the color chips. No additional clear coat was added, as the clear in the mix was plenty of shine for my tastes.
At first the installation seemed ok, but the next day I went out and saw two areasof a 10x10 area that did not flash over properly. One portion of it is flat and the other half is glossy. That does not include the roller marks and small overlaps that are not shiny. I could live with the small flaws, but half of the main section is screwed up.
I called tech support, they recommended that I sand the entire floor and put down the clear coat. Basically blamed me for the product not flashing over in the two sections. I am not ready for the clear after reading reviews on amazon. I don't want it not drying or feeling oily.
http://www.amazon.com/RockSolid-Floo...ews/B004K2WSPE
Right now, I just want to put this behind me and start with something different. Maybe a good quality epoxy with a urethane clear. The polyurea is not for a DIY or amateur.
Does anybody have any advice on getting this back to the base concrete. The slab was new and the garage has never been used. Size is right around 860 square feet.
I read some good things about the diamabrush. Would the concrete prep tool or removal tool be better to get the coating/chips removed?
http://www.diamabrush.com/concrete_prep.htm
http://www.diamabrush.com/mastic_removal_tool.htm
Local rental place has the Edco grinder and contractors have the walk behind shot tool. The local guys I called all have different ideas and equipment. None were familiar with removing the RockSolid polyurea. They have all dealt with removing epoxies, paint or just sealers.
dealingdave is offline   Reply With Quote
Old 10-03-2013, 06:53 PM   #2
my58
Senior Member
Default Re: Grinding Concrete - Removing Rock Solid Polyurea
You can use a pulman holt style floor buffer with a diamabrush scraper (home depot rents them) to remove the coating. about an 80.00 fix with plenty of sweat and dust.
or find a rental center that has an Edco with Dyma serts. (many size machines available) An Edco SEC-1 or 2 or an older general (single head machines) will handle the job nicely. Probably about 150.00 less dust and sweat.
my58 is offline   Reply With Quote
Old 10-03-2013, 07:22 PM   #3
retfr8flyr
Senior Member
retfr8flyr's Avatar
I would second the Diamana tool from HD. I would first use the surfacer tool to remove the Rock Solid and then use the grinder tool and grind the floor. You can rent the buffer and tools by the day and I would think it would take at least 2 days to do a good job.
Then get some good epoxy coating from Alpha Garage, Legacy Industrial, or Garagefloorings LLC. These vendors can recommend just what you need to have a great looking floor the will last for years. I am extremely happy with my Wolverine floor from Alpha Garage.
retfr8flyr is offline   Reply With Quote
Old 10-03-2013, 08:36 PM   #4
LegacyIndustrial
Alliance Member
LegacyIndustrial's Avatar
Dave:
As you and I previously discussed. Because you are only doing a few small sections, buy yourself a 4.5" or 7" variable speed grinder, a diamabrush hand tool (with shroud) and go to town.
When done you will always have the grinder for other duties as well as the Diamabrush head.
If you rent from THD, you need the mastic removal head. The concrete prep tool may have trouble digging through the coating, especially if thick.
Good luck.
LegacyIndustrial is offline   Reply With Quote
Old 10-03-2013, 09:17 PM   #5
dealingdave
Junior Member
That is some good info on using the mastic tool first. The rep at Home Depot showed me the Concrete Prep Plus tool that is sort of new for them. It is supposed to be able to remove coatings as well as grind. Does anybody have real world experience with this model from diamabrush?
http://www.diamabrushbymalish.com/co...prep-plus.html
The rental place that had the Edco models did not know if the inserts were carbide or diamond. Is there a certain grit on the Edco to look for if I go that route? 20 to 40?
Scotty, I am changing my mind since we last communicated. The more I look at this floor, the more disgusted I get. The only way to really make it right is to remove the entire coating and start from scratch. The hardest lessons learned are the ones that waste an entire weekend of time.
Old 10-03-2013, 10:09 PM   #6
LegacyIndustrial
Alliance Member
Sorry to hear it Dave.
You talked with rocksolid? What did they say went wrong?
Old 10-04-2013, 03:42 PM   #7
Cruzin90
Senior Member
You don't want to put epoxy or urethane on top of the polyurea. They are compatible, but the polyurea is more durable than either the epoxy or urethane. If the polyurea did not cure, then (probably) either it was not mixed well or there was too much water in the concrete.
Cruzin90 is offline   Reply With Quote
Old 10-04-2013, 03:45 PM   #8
jordan369
Senior Member
jordan369's Avatar
Do you have photos of your floor?
Mike
jordan369 is offline   Reply With Quote
Old 10-04-2013, 04:15 PM   #9
dealingdave
Junior Member
I talked with the company multiple time and got nowhere. I don't think Rock Solid (aka Citadel Coatings) actually cares. It is all my fault and is applicator error. She told me that I put it on too thick which caused it to go flat. I specifically remember that area, as it was the last one of the day and it was applied thin just like the rest of the sections that did not have a problem.
I will take blame for some of the roller marks that overlapped but I can't see it on the large area that is flat. Today a flooring contractor stopped over and confirmed to just remove it and start over. He scratched the flat area with his fingernail. There is no protection on the areas that are flat.
I am mounting up shop lights this weekend and will then start the removal. I will post some pictures once the process is started. Maybe my mistake can help one person from making the same one. Don't be cheap and buy yourself a quality coating.
Old 10-04-2013, 04:16 PM   #10
my58
Senior Member
This edco would be great
http://www.edcoinc.com/floor-grinders-sec.html
The first ones on this page. The Dyma-serts will work great for you. Most rental yards offer these with the edco.
http://www.edcoinc.com/accessories-floor-grinder.html#1
Old 10-04-2013, 04:19 PM   #11
my58
Senior Member
Also with the edco shown above you should be able to do it in 1 day easily. If you are concerned about the epoxy being really difficult to remove rent the PCDyma-serts also shown in link above.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
