Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 12-18-2005, 07:13 PM   #1
ruby76
Senior Member
ruby76's Avatar
Location: Fairview Hts, Illinois - outside Saint Louis Missouri
Default Kerosene vs propane torpedo htr
Pro's and Cons for a propane torpedo heater vs a kersone model. I have a 16x22 shop so I wouldn't need it to run very long before It comes up to temp and then I'd shut it off.
ruby76 is offline   Reply With Quote
Old 12-18-2005, 07:24 PM   #2
fireman
Senior Member
Default
Kerosene models stink. Propane is oderless. Make sure you have a fresh air source (open window/door) to avoid CO poisoning.
fireman is offline   Reply With Quote
Old 12-18-2005, 07:26 PM   #3
ruby76
Senior Member
ruby76's Avatar
Default
Good point, I had read about leaving a fresh air source. I guess that could be closed though once it is shut off though right?
Old 12-18-2005, 07:27 PM   #4
Quadlinear
Junior Member
Send a message via MSN to Quadlinear Send a message via Yahoo to Quadlinear
Default
Second the above!!!! Kerosene is also more $ than diesel fuel and getting harder to find.
Quadlinear is offline   Reply With Quote
Old 12-18-2005, 09:36 PM   #5
MXtras
Senior Member
MXtras's Avatar
Default
I agree with the consensus so far - propane.
Scott
MXtras is offline   Reply With Quote
Old 12-19-2005, 07:36 AM   #6
ruby76
Senior Member
ruby76's Avatar
Default
Thanks guys. I'll start researching different propane models.
Old 12-19-2005, 08:29 AM   #7
rick
Default
I have used both kinds propane is the best by far!
rick is offline   Reply With Quote
Old 12-19-2005, 08:36 AM   #8
krooser
Senior Member
krooser's Avatar
Default
An oil burner is OK IF you get free jet fuel from your local Air National Guard reservist like I used to....otherwise get propane...
One way to quiet down the unit is to put the heater OUTSIDE. My buddy did this by cutting a piece of plywood the dimensions of his service door...he then cut a round opening into the plywood the size of the heater snout...then stick the heater nose into the hole and fire it up...made a huge difference in the noise level and when he was done in the shop he simply pulled out the plywood and shut the door.
krooser is offline   Reply With Quote
Old 12-19-2005, 08:49 AM   #9
ruby76
Senior Member
ruby76's Avatar
Default
would that negate the need for a fresh air intake? Or is the fresh air for exhaust?
Old 12-19-2005, 11:31 AM   #10
DaveL.
Senior Member
DaveL.'s Avatar
Default go with a vented heater
Personally I'd go the extra mile and mount a vented heater. I used a propane torpedo for many years at my old place. I could only take it for about 2 hours. I kept windows open so I wouldn't suffocate. The fumes would irritate my lungs and give me a bad headache. Mount a little Hotdawg HD30 http://www.gas-space-heater.com/modine-hot-dawg.html or any other vented heater. In the long run you'll be much happier. Just my opinion...
Dave
DaveL. is offline   Reply With Quote
Old 12-19-2005, 12:58 PM   #11
fireman
Senior Member
Default
Quote:
Dave,
A headache is the first sign of CO poisoning. followed by fatigue, shortness of breath (your irritated lungs), nausea and dizziness. Glad you're okay and got rid of that heater. Jim
Old 12-19-2005, 02:01 PM   #12
DaveL.
Senior Member
DaveL.'s Avatar
Default
Quote:
Originally Posted by fireman
Dave,
Yep.I heard that Jim,thanks.
Dave
Old 12-19-2005, 02:20 PM   #13
MXtras
Senior Member
MXtras's Avatar
Default
Another sign is drowsiness or confusion. My brother in law died from this 8 years ago. They say he just fell asleep and never woke up in his garage.
Get the hell out of the space as soon as you start feeling a little sleepy or groggy. Maintain a fresh air supply no matter how cold it is outside. This is serious business as all of you know, but until you loose someone close to you in a manner that you could go, too - it may never sink in.
Scott
Old 12-19-2005, 03:20 PM   #14
ruby76
Senior Member
ruby76's Avatar
Default
Thank you for your opinion on the vented heater. I'd love to, but the garage is detached and has no gas line run to it. I do have electric though. Any good electric heater options out there? Preferable forced air and not radiant etc. I'm leaning towards the torpedo heater also because it is portable. Im planning on buying a house to refurbish and the torpedo could double as a heater in the "work" house too.
I havn't bought anything yet though, so I'm still thinking about it.
Old 12-19-2005, 03:23 PM   #15
krooser
Senior Member
krooser's Avatar
Default
Quote:
Well it does provide fresh air to the heater and reduces the noise...it also helps avoid "bad air" since you aren't using inside air for combustion...An old neighbor of mine went one step further and actually installed a "register" in the garage sidewall...he connected the torpedo to a large heater duct and it blew right into the garage...he also put the heater under a little lean-to to keep it out of the weather...that and a thermostat and he had a pretty good set-up..
Old 12-19-2005, 06:15 PM   #16
fireman
Senior Member
Default
Quote:
The problem is that it still exhausts into the garage and in that exhaust is not only the hot air but water vapor and CARBON MONOXIDE. The only safe combustion type heater is one that vents the combustion products to the outside.
Old 12-20-2005, 09:41 AM   #17
RonBou
Yet another Garage Guy!
RonBou's Avatar
Default
My detached garage is 80 feet from the house. I had a 100 gallon propane tank installed with my vented heater (Modine Hot Dawg).
__________________
RonBou
RonBou is offline   Reply With Quote
Old 12-20-2005, 12:30 PM   #18
ChucksCrib
Senior Member
ChucksCrib's Avatar
Default
I'm using a KeroWorld Kerosene heater I picked up at a tag sale for 5 bucks.. It was one year old(great shape) I do leave on of my 8x9 overhead doors open about a foot when I run it. My garage is usually about 40 degrees unheated up here in CT. I turn the kerosene heater on until the garge (28x28x11)reaches about 55 degrees. Thats plenty warm for me.
I will not however shut the unit off in the garage. It stinks to high heaven when I shut it off so what I do is carry it outside and shut it off. Otherwise I don't notice any fumes when I'm in there.
ChucksCrib is offline   Reply With Quote
Old 12-20-2005, 01:10 PM   #19
ruby76
Senior Member
ruby76's Avatar
Default
Thanks for the replies everyone. I made the jump last night and ordered a small (35,000 BTU) Mr Heater propane torpedo. It arrives in a week. It was an Internet only, sale with no shipping costs. I went with the propane b/c of the comments in the posts above. The garage has good ventilation and I'll keep the window open when I use it. It is a small enough garage that I should be able to run it for a couple of minutes then shut it off, so that should help with fumes.
THanks again guys!
Jeremy
Old 12-20-2005, 01:11 PM   #20
ruby76
Senior Member
ruby76's Avatar
Default
Quote:
That was probably a very good idea. I may look into that at a later date. Then again, this isn't going to be my long term house/shop so I'll keep that in mind for the next one
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
kerosene fuel oil or diesel? the intimidator Heating and A/C 26 03-23-2008 03:32 AM
Propane Turbo Heater Problem stppinz Heating and A/C 8 02-17-2006 11:56 PM
Propane Tanks in Garage mrl05 Heating and A/C 10 01-14-2006 07:31 AM
scentless kerosene jcfitzgerald Heating and A/C 4 12-27-2005 12:27 PM
Kerosene Heaters for Large Building poci1957 Heating and A/C 20 10-14-2005 02:23 PM
