Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-10-2008, 08:35 PM   #1
Dragster Racer
Senior Member
Default Mounting lights outside metal building
OK. Simple detail question. I have metal ribbed siding, and the center has a rib running up and down it. I would like to mount a light right at the center but it will be straddling the rib. How do you get this to look good and right?
Dragster Racer is offline   Reply With Quote
Old 09-10-2008, 09:27 PM   #2
Everyday
Default Re: Mounting lights outside metal building
I've been wondering the exact same thing. I have a pole barn with metal siding that I want to install outside lights. I haven't seen anything for this yet.
__________________
Matt Kelly
Razor Servers
Website, Colocation and Data Hosting
www.razorservers.com
Everyday is offline   Reply With Quote
Old 09-10-2008, 09:54 PM   #3
jcs_in_ky
Senior Member
There's one on a metal building on my property that is done like that. It was there when we bought the place. It looks like they just took a normal fixture and notched it out for the rib. Then they caulked around it. They didn't do that good of a job cutting it and relied more on the caulking (lots of it). If I had been done neatly it would look better and probably seal better. I need to pull it down one of these days and fix it, just haven't had a chance yet.
jcs_in_ky is offline   Reply With Quote
Old 09-10-2008, 10:31 PM   #4
Nealcrenshaw
Senior Member
Nealcrenshaw's Avatar
Need some pics!
__________________
"....Give me neither poverty nor riches"
Nealcrenshaw is offline   Reply With Quote
Old 09-11-2008, 12:40 AM   #5
Steve in Mi
Senior Member
Steve in Mi's Avatar
Quote:
You could use a 6" X 6" (or whatever size will accommodate the light base) piece of wood and saw a matching rib relief down the center to straddle the center rib.
Rap in aluminum or paint to suit.
__________________
Work safe, have fun, enjoy the sport.
Remember that a guy never has to come down out of the clouds if he keeps filling the valleys with peaks. Steve
Steve in Mi is offline   Reply With Quote
Old 09-11-2008, 05:46 AM   #6
Dragster Racer
Senior Member
Thanks guys. That helps!
Old 09-11-2008, 09:56 AM   #7
Nutty 5.0
Senior Member
Nutty 5.0's Avatar
I ended up going to HD, and they have these little vinyl/plastic sections that are about 9" LxW. They have different styles to mount either flat or angle cut for vinyl siding so they will sit flush. I found one that was flush and placed it between some of the ribbing. Or you can just make the notches yourself to fit the ribs. Really looks nice and finshed. Did this outside the mandoor for a light and the opposite side over the doors facing the alley with a flood light.
__________________
24'x32'x12' Conestoga built pole building with two 10'x10' doors. 6" concrete floor 4500 psi. Bend Pak MX10-AC 2 post lift and a Pro Park 8 Plus 4 post lift with lifting jack . U-Coat it floor and Garage Pak air lines. Built in March 2005. My garage build: http://www.garagejournal.com/forum/s...ad.php?t=41534
Nutty 5.0 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
