Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-11-2008, 11:08 PM   #1
FunfDreisig
Senior Member
Default Core Filling a 4ft high Concrete Block Stem Wall
I've seen a lot of concrete foundation walls on this site. Surely they have at least half of the cores filled with concrete. So...
Just how did you guys fill the cores of concrete blocks?
And how did you keep from making a mess of the wall?
Did you mix it up a bag at a time by hand or in a concrete mixer?
Did you use a soup spoon, ladle, coffee can, grain scoop, shovel, wheel barrow or a pump truck to pour the concrete in the cores?
Background:
I've laid roughly 2/3 of the 8x8x16" concrete blocks for my 4' high stem wall on the back and part of two sides of my new 25x42' garage. These walls sit on top of the 12"wx24"deep perimeter beams that are integral to the nominal 5.5" thick 4000 PSI slab. Every other core in the wall has a 48" high stick of #4 rebar wired to a 6" stub of #4 rebar that was placed at the time of the pour. The corner and ends the walls have additional rebar in each core (i.e. 3 in a row every 8"). All this leaves me with 55 cores with rebar to fill with concrete. And each of these cores will require close to 2 60lbs bags to fill. IOW I need to dump 100+ 60 lbs bags of concrete down 55 holes with small openings (e.g. 4x5") 4 ft in the air
Funf Dreisig
FunfDreisig is offline   Reply With Quote
Old 09-11-2008, 11:20 PM   #2
boiler7904
Senior Member
boiler7904's Avatar
Default Re: Core Filling a 4ft high Concrete Block Stem WallI've seen a lot of concrete found
Take the time to make a funnel out of plywood that matches your block size. Doesn't have to be anything fancy - you just need to give yourself a big target to aim at. Use a mixer and dump it into the wall with 5 gallon buckets. Use a loose piece of rebar to vibrate the mix as you pour it into the cores to eliminate air pockets.
You only really need to put grout in the cores that have rebar or are directly under the bearing point of a beam, column, lintel, etc. The empty cores of the other blocks actually give you some r value and help insulate the wall.
__________________
2004 Ford Escape XLT
2012 Ford Fusion Sport
1997 2 car garage in progress
Quote:
Originally Posted by bmwpower View Post
Oh, and it's BMWPower. I do have powerful BM's but wouldn't want everyone to know all my secrets.
boiler7904 is offline   Reply With Quote
Old 09-12-2008, 01:27 AM   #3
IDASHO
Senior Member
I would NEVER bother to hand mix, or run mud with a wheel barrel to grout block walls.
Pumper is the only way to go. Quick, precise, and clean.
I have 7 yards of grout mud in this wall. Cost me an extra $150 or so for the pumper, but it saved a TON of labor and time. Took all of 20 minutes to grout.
__________________
See my garage build here:
http://www.bonnefinstudios.com/kwb/paradise/garage/
IDASHO is offline   Reply With Quote
Old 09-12-2008, 02:09 AM   #4
Steve in Mi
Senior Member
Steve in Mi's Avatar
Filled my foundation block the old fashion way. Sand, gravel, portland cement and water into the mixer. Dump into wheel barrel, 3# coffee can into block while working with rebar to settle out. FUN
__________________
Work safe, have fun, enjoy the sport.
Remember that a guy never has to come down out of the clouds if he keeps filling the valleys with peaks. Steve
Steve in Mi is offline   Reply With Quote
Old 09-12-2008, 06:11 AM   #5
ron in sc
Senior Member
ron in sc's Avatar
A pumper truck was used for my job.
ron in sc is offline   Reply With Quote
Old 09-12-2008, 06:55 AM   #6
PurdueSD
Senior Member
PurdueSD's Avatar
rented a barrel mixer for $50 - made a trough funnel out of osb and away we went. Its really not that bad compared to the block work. Granted while laying the block I had the pleasure of mixing mortor by hand.
__________________
My Truck Shop Build thread... (SOLD)
http://www.garagejournal.com/forum/s...ead.php?t=9671
Help me brainstorm the new shop!
http://www.garagejournal.com/forum/s...d.php?t=338743
PurdueSD is offline   Reply With Quote
Old 09-12-2008, 08:17 AM   #7
sparky1562
Senior Member
sparky1562's Avatar
My 12 ft wall is solid filled up to 7 ft, and every 4th cell after that. The guy that did mine built the plywood funnel mentioned above and just had the concrete truck dump right into it.
A pumper would be the easier, but hard to justify on a small job.
__________________
Herb
BSEE Purdue 1986
sparky1562 is offline   Reply With Quote
Old 09-12-2008, 08:24 AM   #8
FunfDreisig
Senior Member
Thanks for these great replies guys One of the best things about this site is the diversity of the advice that provides good ideas and options
100 60 lbs bags is less than 2 cubic yards so I think this job is too small for a concrete delivery and pump truck. The pump truck I used for the slab cost me $570 extra (i paid the bill) over the turn key price of the 30 yd 4,000 psi slab.
Based on your advice and a little thinking, here's the plan...
I'll use a rented 2 bag mixer and ladle the grout into the cores with a 3 quart feed scoop. I'll drape a little 6 mil plastic sheeting over the wall in the area of the core being poured and build a crude trough style funnel that fits over two sides of the wall so I don't have to hold it steady. I'll use a spare chunk of rebar to settle the grout and avoid air pockets.
FWIW i hate these rented mixers. I seem to spend more time cleaning them than using them So I plan to keep the mixer running continuously. I'll mix a bag and dump it into one of those little plastic mixing troughs for transfer to the wall and mix the next bag while filling a core. Since the wall is 4 ft high I'll use the fork lift of the Kubota to lift the plastic mixing trough onto a 4 wheel dolly with enough pallets to raise it up to easy reach.
Did I miss anything?
Funf Dreisig
Old 05-06-2010, 07:02 PM   #9
hevnbnd
Senior Member
Anyone got a pic of these trough funnels they built?
hevnbnd is offline   Reply With Quote
Old 05-06-2010, 09:38 PM   #10
Red05GT
Senior Member
Send a message via Yahoo to Red05GT
We've had to grout bond beams on top of block walls before and built a plywood
funnel/trough with a beveled 2x4 inside on each side to support the apparatus allowing
the plywood to extend down on the outsides of the block a couple of inches. Cap each
end of the trough with plywood. The square bottom edge of the 2x rides on the top
edges of the block and the beveled edge does away with a ledge for the grout to catch
on.
Red05GT is offline   Reply With Quote
Old 05-06-2010, 11:23 PM   #11
Ironcrow
Senior Member
Ironcrow's Avatar
I'd drop a piece of rebar in every hole, and hire a pump truck. If I was worried about a minimum order of concrete, I'd find another piece of the project to place; an apron, staircase, fence posts, retaining wall, sidewalk, pad for the garden shed...something
Ironcrow is offline   Reply With Quote
Old 05-07-2010, 10:49 AM   #12
JamieK
Senior Member
Just a stupid question here, but what is the main purpose of a stem wall? I've seen buildings with and without them. Is it just to raise the lower level of the stud wall to above ground level?
Thanks
JamieK is offline   Reply With Quote
Old 05-07-2010, 11:42 AM   #13
WNYflyer
Senior Member
WNYflyer's Avatar
Quote:
Thanks
A few reasons.
- If building into the side of a hill or grade drops off fast then used to keep moisture sensitive building materials far enough above grade. Plus in this situation when backfilling higher on the outside than the inside the block wall ends being a retaining wall and block can be grouted and vertically reinforced.
- Used in a lot of buildings where you anticipate washing down the floor or lower walls. Also if you anticipate possible banging/damage to the lower wall from what ever you are doing in the building.
WNYflyer is offline   Reply With Quote
Old 06-29-2016, 03:15 PM   #14
WilltheEngineer
Senior Member
WilltheEngineer's Avatar
For a block column with #5 rebar, 8' high, would a core fill mix be needed or could wet (more water to increase slope..)?
WilltheEngineer is offline   Reply With Quote
Old 06-29-2016, 07:09 PM   #15
mzwizanski
Find a metered concrete truck, they mix it as it comes out the truck. You only pay for what you use. Here they have a 1 yard minimum and it was $200 (110 a yard plus 80 for delivery). By the time you buy the bags and take the time to mix them its a no brainer.
mzwizanski is offline   Reply With Quote
Old 06-30-2016, 12:59 PM   #16
flan
Junior Member
4 60 lb bags will fill 9 feet of 8" block. Lowes has 60lb bags for $1.98 here in ct I just bought 2 pallets
flan is offline   Reply With Quote
Old 06-30-2016, 06:37 PM   #17
DalyArcher
DalyArcher's Avatar
a pumper truck round here was a minimum 4 hour charge at $250.00 an hour, plus the 160.00 per yard for concrete. I poured a 17 yard thickened edge slab a few weeks ago. I called a few friends at church and we wheelbarrowed it.
DalyArcher is offline   Reply With Quote
Old 07-01-2016, 05:06 AM   #18
ms fowler
Senior Member
Location: Littlestown, PA _ 6 miles south of Gettysburg
Remember, there is a difference between grout-used to fill block walls, and concrete. When placing concrete, water is the enemy of long-term strength. But when grouting, water is your friend. You want the water in the grout to carry the cementatious material into the pores of the CMU block. That is what makes the bond. Also, the block needs to be dry. If the block is already wet, the pores are already filled with water, so you do not be the benefits you should. When placing concrete you want a slump in the 3" to 5" range, maybe 6". But in grout, you want a slump in the 10" range. Actually you are probably outside the limits for a slump test, but you really want it wet.
Grouting is generally limited to 4' "lifts, meaning you grout 4' high each time. Also move the rebar rods up and down to remove voids and get the grout to flow everywhere it should. You can grout higher than 4', but then you need to open a "window" at the bottom of the grout column to visibly see that the grout gets all the way down, and then have a scrap of wood to nail over the "window" to keep the grout inside the wall.
After grouting, you should see that the surface of the CMU wall is wet. It may take some time, but the wall should look darker in color as the moisture permeates the wall.
ms fowler is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
