Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 11-10-2013, 09:33 PM   #1
Chuck McB
Senior Member
Chuck McB's Avatar
Default Pneumatic da sanders whats the best buy?
After taking the HD da back for the second replacement I'd like to hear from you guys what's the best deal.
Chuck McB is offline   Reply With Quote
Old 11-10-2013, 09:51 PM   #2
metaleltr
Senior Member
Default Re: Pneumatic da sanders whats the best buy?
Be prepared for sticker shock, but A Hutchins will be the last DA you ever have to buy. Especially if you are just a DIY guy. What are your intended uses. Hutchins makes sanders to be used all day everyday in body shops. I personally have a 4560. The 3500s are ok, but I do not like the muffler design. They are prone to breakage when dropped and when the muffler is broken they are loud as hell.
__________________
A bit of humor - every mechanic/tech is a Ford tech, to some degree...
Quote:
A bunch of Luddites on Garage Journal don't really reflect the general mood of most people
Quote:
Originally Posted by DieselSaves View Post
Winding a recoil spring is kind of like arguing with a woman. There ar several ways to go about it and none of them work very well.
metaleltr is offline   Reply With Quote
Old 11-10-2013, 09:58 PM   #3
The Gambler
Senior Member
i like my snap on but i bought it used off the truck for like 60 bucs
The Gambler is offline   Reply With Quote
Old 11-10-2013, 10:14 PM   #4
gtermini
Senior Member
gtermini's Avatar
Dynabrade. About $150. Your choice of pad.
Greyson
gtermini is offline   Reply With Quote
Old 11-10-2013, 10:37 PM   #5
HMCFab9
Senior Member
HMCFab9's Avatar
Hutchins is probably the best, but Chicago Pneumatic is pretty good too.
(not central pneumatic / aka harbor crap store junk)
I've got a National Detroit DA also & it works great.
HMCFab9 is offline   Reply With Quote
Old 11-10-2013, 10:44 PM   #6
930dreamer
930dreamer's Avatar
I have a Craftsman I bought about ten years ago, the handle/actuator is tweaked but is still running. X2 on the Hutchins.
__________________
I can take it apart.
http://stores.ebay.com/930dreamer?_rdc=1
930dreamer is offline   Reply With Quote
Old 11-10-2013, 11:32 PM   #7
stanward
Junior Member
I have an Ingersoll Rand that I really love.
stanward is offline   Reply With Quote
Old 11-10-2013, 11:44 PM   #8
Tinner
Senior Member
Tinner's Avatar
The Dynabrade is a good value. We have several at work and while they don't see the use that a body shop would give them, they get used and abused more than most DIYers would. They work well and need very little repair.
Tinner is offline   Reply With Quote
Old 11-11-2013, 08:51 AM   #9
ianguilly
Senior Member
ianguilly's Avatar
I really do like my HF sander it has last 2+ years of every day abuse. The bearings are just now starting to go.
__________________
Current boxes:
Work boxSnap On KTL7023PVE /KRA2055
Home boxes Snap on KR1000 "the tank", KR650&655, KRA429K and KRA-59J, kr537/547/557/kr274
36 toolboxes owned and counting.....
ianguilly is offline   Reply With Quote
Old 11-11-2013, 09:20 AM   #10
Chuck122
Senior Member
Chuck122's Avatar
I have used Astro pneumatic, Snap On, IR, Dynabrade and Mirka. For the same orbit size, the Mirka seemed to cut the fastest, the Snap On and Dynabrade felt nicer and easier to control. I never cared for the IR or astro mostly because they have a less comfortable shape. Overall the Mirka and Dynabrade were my favorite.
In any case, i'd suggest getting a hook-and-loop pad, as it works well in a dusty bodyshop.
__________________
Quote:
Originally Posted by diesel research View Post
if it was designed perfectly the first time, you would be a $7/hr yard inspector., some oversights still occur, allowing opportunities for dollars to be made..
Chuck122 is offline   Reply With Quote
Old 11-11-2013, 09:36 AM   #11
rlitman
Senior Member
The older Dynabrade was 10,000 RPM. The new ones are 12,000 RPM.
Maybe that was the difference you saw in cutting speed?
Mine are Dynabrade. But I have a bunch of Mirka pads. Both are top shelf.
rlitman is offline   Reply With Quote
Old 11-11-2013, 10:23 AM   #12
pepi
Senior Member
pepi's Avatar
Hands down: www.hutchinsmfg.com
I have the DA & Straight line sander, they are powerful, good speed control, and move a load of filler.
High speed is not the secret to moving filler it is torque, speed just wears out the sand paper quicker.
I ran my sander at the highest speed when I did not know any better, then discovered dropping it enough to sand increased the life of the paper, and sanded.
Not a cheap tool but a very good tool, best of brand..
__________________
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair.
Best viewed loud
https://www.youtube.com/watch?v=PmmyMGQojzI
pepi is offline   Reply With Quote
Old 11-11-2013, 10:35 AM   #13
rlitman
Senior Member
You've got to work on your technique.
A DA sander sands primarily on the orbit. The rotation is really there only to make the orbits more random so you don't end up with swirl marks. You need to vary your palm pressure to control the rotation speed. 100-200 RPM seems around right.
Whether orbiting faster helps it sand faster or just waste paper depends on a bunch of other factors. But in many cases, orbiting faster can indeed get you faster stock removal.
Old 11-11-2013, 10:39 AM   #14
Tinner
Senior Member
Tinner's Avatar
[QUOTE=pepi;3492494]
/QUOTE]
Absolutely true. I work in raw metal, using a da to blend in ground welds, hammer and other marks from hand forming. There's always a sweet spot in the speed range where you're working efficiently. Flat and curved surfaces are different as well. I rarely run the tool wide open.
Old 11-11-2013, 01:40 PM   #15
sandman67
Junior Member
There is a company called AirVantage tools www.airvantagetools.com that makes great sanders. They are ergonomic and perfectly balanced. It is my choice is your looking for quality and durability. It can be ordered for around $130.00 for standard non-vac with PSA or Velcro pad. You can order one from abrasive ideas 226-787-5405.
You can get a 3/16" orbit (for more agressive kick) or a 3/32" orbit kick which can give a tighter less agressive finish. I generally recommend that one for high grits ...
sandman67 is offline   Reply With Quote
Old 11-11-2013, 02:20 PM   #16
rlitman
Senior Member
[QUOTE=Tinner;3492526]
Quote:
It sure does depend a lot on what you're doing. Certainly, if the whole pad is not in contact with the work surface (flattening raised areas, working over curved surfaces, etc), you will not be able to get the full power out of the machine.
Old 11-11-2013, 02:35 PM   #17
djd99
Senior Member
djd99's Avatar
Ive been using a Hutchins for 15 years now. You can't go wrong with a Hutchins it'll be the last one you buy. Not cheap but well worth your money.
__________________
Don
djd99 is offline   Reply With Quote
Old 11-11-2013, 03:08 PM   #18
Packard V8
Senior Member
Just one more vote for Hutchins. Not often is the best tool also made in USA.
jack vines
Packard V8 is offline   Reply With Quote
Old 11-11-2013, 04:08 PM   #19
pepi
Senior Member
pepi's Avatar
[QUOTE=rlitman;3492991]
Quote:
Do not know what you are talking about, "Certainly, if the whole pad is not in contact" ?
The DA & Streight line sanders are used for blending, the sander will run at the power it is set at.
Makes no sense what you posted, sounds a if you have not had the pleasure of using a Hutchins.
__________________
Best viewed loud
Old 11-11-2013, 05:51 PM   #20
Crow Horse
Senior Member
Crow Horse's Avatar
I use a National Detroit DAQ 8-10 hours a day and they have been great. Maybe not quite as good as the Hutchins, but I felt it was the best bang for the buck. Cost around $150 or so.......
It operates at 45 to 60 psi and is very aggressive.....
__________________
All Good Medicine,
Crow
Crow Horse is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
