Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 11-15-2013, 08:05 PM   #21
Burgerkong
Senior Member
Burgerkong's Avatar
Default Re: Can you identify this floor jack?
Quote:
Originally Posted by joel63 View Post
Hiball, how can you tell it's not a Lincoln, but an import instead?
I'm not questioning you, but it sure had me fooled.
Colour scheme maybe? IIRC the Snap On jacks have the model and warnings painted on. I know exactly what it was because I was looking at this exact jack for my friend. We were going to buy new lol. Then this popped up.
__________________
Brendan
Burgerkong is offline   Reply With Quote
Old 11-16-2013, 04:00 AM   #22
EDGAR
Senior Member
The rebranded Snap On's use an universal joint for the release. The Norco 71230 uses a gear type release. Easy to spot if you look at the handle yoke or holder, but of course, you need to know of that difference in advance. Also, the top flange on the Lincoln's, Hein Werner's, Snap O's is straight. The Norco flange is not a straight line but it has a slight turn along its length.
To make things more interesting, there is a company called PROJACKS that makes a jack that is very similar to the Hein Werner. The difference in the body is that the flange has less width. Also, the pump looks the same as the Hein Werners. However the Projacks pump has some internal differences. It uses the cheaper o-ring and o-ring retainer instead of an u-cup. On the good side, it has seals for the oil tank (both ends) and it also has a sealing washer for the cylinder. The Lincoln, Hein Werners do not have seals for the oil tank nor for the cylinder, requiring that these be tightened to higher torque values to prevent leaks.
http://www.projacks.com/
http://www.projacks.com/Uploaded/Att...00ee24f7f9.pdf
Shinn Fu also made a Blackhawk BH 6020 floor jack which was the same as the Hein Werner 93642 but it was made in China. It was red in color.
EDGAR is offline   Reply With Quote
Old 11-16-2013, 04:24 AM   #23
kc-steve
Senior Member
kc-steve's Avatar
Thanks EDGAR, I think I have one labeled as Western Auto, based on the other description of using a gear for the release. I got mine at a garage sale for $50 and works great.
Steve
__________________
Junkyard Tools rescued from the junkyard
Feedback
kc-steve is offline   Reply With Quote
Old 11-16-2013, 07:10 AM   #24
Hiball
Senior Member
Hiball's Avatar
When you have torn down as many of them as I have the differences are quite easy to spot, as already mentioned the release mechanism/frame was a dead giveaway based off the limited pictures. In Lincoln's hay day (prior to shinn fu) they where selling the design to many different brands with subtle changes, Blackhawk at the time was searching to fill voids in there catalog which is why you see weaver and Lincoln in blackhawk color schemes, Lincoln compared to walker was very good at marketing there product line.
__________________
Im Currently not taking any orders or shipping Kits/parts. It's always best to patronize local business's when possible, if not available there are numerous online suppliers. Below, you will find a phone number to HPS, Steve and His Wife are very knowledgable and very economically priced. .
Have a Hydraulic Jack Question? Check Here First..
Need a Seal Kit? Contact Hydraulic Parts Supply at 620-594-2247
BRC 6/9/22 - 3/5/12 My Best Friend and the Greatest Man i ever Knew RIP...
Hiball is offline   Reply With Quote
Old 11-16-2013, 10:42 AM   #25
joel63
Senior Member
joel63's Avatar
Thanks for your reply.
Can you tell me who makes the SO YA700?
Is that a good one to get?
Thanks again.
joel63 is online now   Reply With Quote
Old 11-16-2013, 11:40 AM   #26
Hiball
Senior Member
Hiball's Avatar
Thanks again.
Ya-700 Should be Oem'd walker/Lincoln/HW with the exception of the "c" series in which I believe is a import. A picture will be more helpful, you can send it in a PM if it's a auction/Cl ad your wanting to keep hush/ hush .
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
