Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 11-16-2013, 07:30 PM   #1
shawn84&92
Default Non-faced insulation question
I have a pole barn with double bubble insulation between the metal and the perlins. I have built 2x4 walls even with the posts and plan to insulate and sheet the walls with osb.
Today, I got a great deal on unfaced r-11 insulation 7ft wide and 100 ft long for $30 per roll. My question is since I have double bubble is it okay to use the unfaced insulation or do I need to put a vapor barrier between the osb and the unfaced insulation? If I need a vapor barrier, what do I need to use. I plan to sandwich the insulation between the osb and the 2x4's.
Thanks,
Shawn
shawn84&92 is offline   Reply With Quote
Old 11-17-2013, 07:00 PM   #2
shawn84&92
Default Re: Non-faced insulation question
bump
Old 11-17-2013, 08:38 PM   #3
bullnerd
Senior Member
bullnerd's Avatar
I cant help you on this one .Over my head. I dont think you would want a moisture retarder on both sides of the insulation? I always thought it was supposed to "breath" to the outside. This will require a pros advice. Good luck.
bullnerd is offline   Reply With Quote
Old 11-18-2013, 11:41 AM   #4
Highbeam
Senior Member
You shouldn't have put in the bubble wrap. That is now the vapor barrier and it is on the wrong side assuming you live in a heating area and not way down south.
The problem is that warm moist air from inside the building will move on through the OSB and fiberglass until it hits that cold bubble wrap where it will condense like a cold can of coke. The trapped water will saturate your FG batts and rot your wood, grow mold like crazy.
First, remove the bubble crap. It's not doing you any good anyways. Then insulate, then cover with a poly VB on the inside and then put up the OSB.
Highbeam is offline   Reply With Quote
Old 11-23-2013, 02:00 PM   #5
shawn84&92
There will be about a 4 inch ir gap between the insulation and the double bubble, will that help the situation any?
Old 11-23-2013, 02:19 PM   #6
shawn84&92
"The problem is that warm moist air from inside the building will move on through the OSB and fiberglass until it hits that cold bubble wrap where it will condense like a cold can of coke. The trapped water will saturate your FG batts and rot your wood, grow mold like crazy."
I don't understand, wouldn't it do the same thing when it hits the cold metal on the building?
Thanks,
Shawn
Old 11-24-2013, 11:04 AM   #7
Highbeam
Senior Member
It won't hit the metal if you put the vapor barrier where it belongs which is on the warm side of the wall. The idea is to keep the warm, moist, room air from entering the wall cavity where it will eventually find a place cold enough to condense and then it is stuck there.
If you have a ventilated 4" air gap between the insulation and the metal skin then you are in better shape but still, not ideal. The foil wrap can only hurt you. Tyvek house wrap would have been a better idea.
Old 11-24-2013, 11:08 AM   #8
jannan
You will be alright as long as you are very careful installing the poly vapor barrier. Be sure to tape all seams and tears. JMO
jannan is offline   Reply With Quote
Old 11-24-2013, 06:04 PM   #9
shawn84&92
Quote:
What I will end up with is:
OSB
plastic vapor barrier
unfaced insulation
3 to 4 inch air gap
double bubble
outside metal
Will this be okay?
Sorry to keep asking,but this is out of my knowledge range and I don't want to mess up.
Thanks,
Shawn
Old 11-24-2013, 07:04 PM   #10
CNGsaves
Senior Member
CNGsaves's Avatar
Question Re: Non-faced insulation question
What environment you in . . . hot, cold, or moderate?? What country?? State and city??
Now would be good time to Update GJ Profile with your Location.
CNGsaves is offline   Reply With Quote
Old 11-24-2013, 11:10 PM   #11
shawn84&92
I am in Fort Smith, Arkansas.
Old 11-25-2013, 11:55 AM   #12
jannan
Quote:
OSB
unfaced insulation
3 to 4 inch air gap
double bubble
outside metal
Will this be okay?
Thanks,
Shawn
Yes, as long as you are careful when installing the VB. Moisture that cannot travel thru the VB, cannot condense on the other side of the VB. Your reasoning, that you stated earlier, is correct.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
