Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 11-28-2013, 03:02 PM   #1
stroked87monte
Junior Member
Default Help with an old Craftsman arc welder
Hey, I bought this welder from a yard sale. I know it powers on and will strike an arc, but I am not sure about the setting of the leads.
It is a model 113-1923. Any info would be helpful. Thanks in advance.
stroked87monte is offline   Reply With Quote
Old 11-28-2013, 03:32 PM   #2
zkling
Senior Member
Default Re: Help with an old Craftsman arc welder
WOW, old is right. It should just be a basic AC transformer. With two ranges and taps between.
The A heats should be the upper row, the B heats, the lower row. With the way you have it set there, it should be "set" at 110 amps.
Before putting it into regular service, I"d give it a through check over inside, clean it out and make sure all connections and wires are properly insulated.
zkling is offline   Reply With Quote
Old 11-28-2013, 04:19 PM   #3
G_P
Senior Member
G_P's Avatar
First off, Stop using it.
Those leads have bare exposed wire. Either use heatshrink to fix them or get new leads. If the wire on the outside is falling apart the wire on the inside is probably crumbling as well.
Open the machine up and remove all the dust and cobwebs and make sure all connections are clean and not corroded. If it has a cooling fan make sure it works and lube it up.
G_P is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
