#1 |
Senior Member
Ridgid just recently updated their wall mount shop vac. I was planning on buying the older model, but they were gone and this one was in its place at Home Depot.
http://www.ridgid.com/Tools/WD5500-Wall-Vac/index.html The WD5500 5gal/5hp shop vac was $99 and it was the only wall mounted shop vac they had so I figured I would give it a shot. The plastic back mounts to the wall with 4 screws. I used concrete screws to mount it to the block wall in my garage. The plastic backing is nice and thick, and holds up fine when mounted to a wall. They have it rated at 8.5amps and 5hp. I know it is less than that hp number realistically, but this vacuum does the job nonetheless. Even at the end of the full 21ft of hose there was more than enough suction for my wife to get dog hair out of her car parked in the driveway. If you mount this thing in the right place you will probably never even have to take it off of the wall since it has a 20ft cord and a 21ft hose. Ridgid supplied all the necessary attachments and I didn't have to buy any extra which was a plus. The box says there is a "full lifetime warranty against material defects and workmanship," hopefully I won't need it but it seems like a good deal. Bottom Line: This thing is a steal for $99 and I am very happy with it.
__________________
- Luke |
#2 |
Looks nice and compact. Solves the problem with my current vacuum (Craftman 8 gallon) about where to put the hose when you're done.
__________________
bmwcca 147895 | 99 m3 | 90 535i | 89 325is | 04 sienna le awd | 88 f250 4x4 my garage build |
#3 |
That looks like a dandy to me, wish I had one!
#4 |
Junior Member
Looks good hanging on the wall. I am glad to see that is has good suction because I picked one up on Monday.
I went in to get the wall mounted one in the local HD flyer (a Ridgid WD 4050 with a wire holder for $79), but none of the local stores had one so we spilt the difference and I was able to get this one for $89. I hope to get it set-up this weekend. |
#5 |
Junior Member
Where can I purchase the Rigid WD 5500? I do not find it on Home Depot website. Also, how large is the unit - length x width x height?
Thanks. |
#6 |
Senior Member
I've got one too & have been impressed with its power. It's perfect for a small shop & the hose is generously long even without the secondary accordian type hose. Great for cars too.
#7 |
Senior Member
ljtanner,
This thread is 4 years old. Rigid has probably made 6 different models of this and then discontinued it by now. |
#8 |
Senior Member
Does if have a nice big hose or a little one like the actual "shop vac" brand ones?
I traded in my shop vac for a CMan unit a while back and it was a night and day difference. CMan one can darn near suck the concrete off the slab and the Shop Vac had trouble picking up nails even. |
#9 |
Senior Member
Looks like its been discontinued, not surprising after 4 years. But google did find this one for sale
http://www.alexgs.com/product/ridgid-tool-co-22718.html |
#10 |
Senior Member
I've beat the hell out of that shop vac for four years now and it is still going strong. No issues whatsoever and I'd buy another one in a heartbeat if I needed to.
__________________
- Luke |
#11 |
Junior Member
I just picked up the Kobalt KWM508 and it looks like it might be the Lowes branded updated version of the WD5500. I just got it setup today but it has performed well so far, picking up some saw dust as well as pine needles from taking the christmas tree out. It's got the same 21 ft of hose and 20 ft power cord and the same peak horsepower rating and bin size as the WD5500. The form factor is very similar even down to the wall mount. Going through the manuals for both the Kobalt and the Rigid it looks like they both outsourced the manufacture of their products to the same company. Given that home depot no longer sells the WD5500, the KWM508 may be the next best bet. I would love for someone who has the WD5500 to do a comparison.
#12 |
Senior Member
I've wanted a big(12+amp) motor on a little(5-8 gallon)frame with the large diamter hose for a very long time. Just something small enough to easily move around and clean things up. Why is that so impossible.
__________________
Slow is smooth, smooth is fast. |
#13 |
Junior Member
FYI: I just picked up one of these on clearance at HD for $45 in Orlando. They had about 3-5 more of them.
So far, I have no complaints, |
#14 |
Senior Member
Just in my local HD (Glendale CA) and they had these clearanced at $19.00, sku 439-523.
__________________
. Contact us for DIY Wolverine Coatings floor epoxies. Do It Yourself Professional Results. Fred@AlphaGarage.com 877-333-GARAGE (4272) |
#15 |
Senior Member
Just picked up 2 at my local HD for $19 as well. I like the fact that it's easily removable from the wall bracket. One for the garage, one for the house. The hose and attachments are probably worth more than $19!
#16 |
Senior Member
I just picked up two myself in North Windham CT.. they had like a dozen of them there
#17 |
don't really need one since I have a roll-around shop vac, but for $20 and change, almost a no brainer.
#18 |
Senior Member
all the accessories are easily more than $19.
Bought 2 |
#19 |
Senior Member
Thanks for the tip, guys. I'm currently on the phone searching local HD stores right now. The store closest to me sold the last one an hour ago.
I just bought a new sandblast cabinet a week or so ago, and this will be perfect for it. *EDIT* - no luck, the nine closest stores to me are sold out. I was told they were part of a large purchase for a Father's Day special they had. When the specific time passed, they blew them out to make room for other items. Last edited by Wanna Ride; 08-01-2010 at 03:39 PM. |
#20 |
Senior Member
I snagged a couple today (Sunday the 1st of Aug-2010) for $19.00 each. Heck the replacement filter-the cheapist one-costs $15.00. Buy a few WD 5500's at $19.00 just to get the filter and then have a lot of extra accessories and spare motor for $4.00.
Thanks Guys-GJ and the OP |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Fab shop or Garage ? | AprilzWarrior | Garage Gallery | 23 | 12-20-2007 12:33 PM |
| Shop addition | astroracer | Garage Gallery | 44 | 05-01-2006 06:55 AM |
| GARAGE-LESS NEW GUY OR (shop owner wannabe) | slowride66 | General Garage Discussion | 10 | 12-20-2005 12:10 AM |
| Wiring for detached shop | plepper | General Garage Discussion | 7 | 09-24-2005 11:31 PM |
| Newbie, with a new shop | BOSS351C | General Garage Discussion | 12 | 07-29-2005 08:40 AM |
