Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 10-03-2008, 07:13 PM   #1
ron in sc
Senior Member
ron in sc's Avatar
Default Homemade transmission jack
None of the transmission jacks I looked at seemed like they would work very well so I just improvised.
Floor jack, 1/2" aluminum plate, 3/4" OSB, 1 bolt with nut and washers, and 2 straps.
ron in sc is offline   Reply With Quote
Old 10-03-2008, 07:54 PM   #2
Fast Orange
Senior Member
Fast Orange's Avatar
Default Re: Homemade transmission jack
Ron,I've done the same thing-it worked OK a couple of times,but the odds caught up with me the last time I tried it.
The narrow track of the floor jack,combined with the lack of swivel castors on both ends resulted in the jack and the tranny falling over sideways.I was lucky-no one got hurt and the damage to the tranny was minimal-but it was too close a call for me.The tranny was almost in place-just needed to shift it sideways a hair to line it up.As soon as we pushed a bit sideways on the wheel of the jack,the tranny slid on the plate and the whole mess wound up laying on the ground.
Since then,I bought a used tranny jack.The abilty to exactly position the tranny,including tilting and angling the whole head,has made this so much easier and safer,I'll never try it any other way.
Look at it this way-how much did it cost for that freshly built tranny?When it falls off the jack and cracks/breaks or distorts the bellhousing,how much will it cost to fix? On the off chance that you don't get away from it before it lands on you,how much is the E-room bill going to be? My close call convinced me that that jack,even though I only use it once in a while,was well worth the $250 that it cost me.Plus-make up another head for it and it's better than those $150 motorcycle jacks.
__________________
Chisel,Bend And Burn To Fit-
Fast Orange is offline   Reply With Quote
Old 10-03-2008, 08:31 PM   #3
Northstar9126
Senior Member
Beautiful floor. Epoxy?
Northstar9126 is offline   Reply With Quote
Old 10-03-2008, 08:40 PM   #4
Stephenw
Senior Member
Stephenw's Avatar
Balancing a transmission on a floor jack is a risky venture. A transmission adapter on a floor jack is just as bad, if not worse. The adapter makes the rig taller and even more unstable.
The floor jack is too narrow and can easily tip over.
I got this one from HF on sale for $99. It is acceptable quality.
http://www.harborfreight.com/cpi/cta...temnumber=3185
I also checked out their more expensive model. It is better still, but I didn't feel it was twice the price better.
http://www.harborfreight.com/cpi/cta...temnumber=4075
Stephenw is offline   Reply With Quote
Old 09-27-2010, 04:37 PM   #5
mechanikat
Junior Member
10" angle iron out riggers with casters added on the front. Also made a long pipe roller to place in front between the front wheel arms. Boy does this work good on a 3ton floor jack. Ever tried pulling a trannie out in the dirt out in the boonies?
mechanikat is offline   Reply With Quote
Old 09-28-2010, 07:12 AM   #6
cranky
cranky's Avatar
i agree its risky buisness not using correct equipment and would advise against it if possible, but sometimes paying money for a jack ur gonna hardly use. its hard to get the money out of ur wallet. ive changed a few trans with just manpower a normal trolley jack and some axle stands. a extra per of hands always helps
__________________
The Beetle in my sig does not belong to me
but i hope to build something similar!
cranky is offline   Reply With Quote
Old 09-28-2010, 07:25 AM   #7
mrholeshot
Senior Member
mrholeshot's Avatar
That nice lift and you are using a floor jack? While it serves duty as an extention cord holder most of the time. This is a lot safer.
__________________
Try to be the person your dog thinks you are.
mrholeshot is offline   Reply With Quote
Old 09-28-2010, 03:22 PM   #8
SCscoutguy
Senior Member
SCscoutguy's Avatar
I bought the largest transmission jack HF had about 5 years ago and it has been great. One of the best purchases I have ever made from there. I have taken out probably 15+ automatic transmission/transfer case combo's with no problems.
SCscoutguy is offline   Reply With Quote
Old 01-17-2011, 07:27 AM   #9
homesale
Senior Member
The 800 Lb. Capacity Transmission Jack is no longer $99. It's $129.99.
Has anyone tried the HF 450 Lb. Capacity Transmission Jack Central Hydraulics 39178?
$79.99
http://www.harborfreight.com/450-lb-...ack-39178.html
homesale is offline   Reply With Quote
Old 01-17-2011, 07:44 AM   #10
472scout
Senior Member
$79.99
I have one. The screw stripped out with only mild use.
472scout is offline   Reply With Quote
Old 01-17-2011, 08:03 AM   #11
34 Ply
I made one somthing like the one he made. Like one person said It's hard to justifie the exspenes of a tool to use once or twice. I was a carpenter untill I retired and still have most of my tools. They were all the best I could buy because I wanted the longjevity and safty because I used them every day. My trans setup I have used twice, with good results. With anything like that you have to use common sense, If it can't move sideways don't push it sideways. I see a lot of home made tools in this site that work well. Nessesity is the mother of invention.
34 Ply is offline   Reply With Quote
Old 01-20-2011, 03:52 AM   #12
homesale
Senior Member
I changed a clutch with my 2.25 ton jack and it was real difficult. It took hours and I thought the transmission was going to fall off the jack a few times.
Does the hydraulics leak on the Harbor Freight 800 Lb. Capacity Transmission Jack? I will swap a clutch and probably will not use it for a year or 2, then maybe I might use it.
http://www.harborfreight.com/800-lb-...jack-3185.html
Are there any good, affordable transmission jack adapters that can be mounted to an existing floor jack?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
