Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 10-24-2008, 09:11 AM   #1
dc426
Junior Member
Default covering the top of a work bench???
Yesterday I spent the afternoon honing my carpentry skills making a new storage/work bench. I intend on making one more like this one and want to add a black rubber mat to the tops of them.
Anyone know where I can find this? Just a smooth black rubber covering that will not absorb oil or moisture.
DC
dc426 is offline   Reply With Quote
Old 10-24-2008, 09:19 AM   #2
fotoflojoe
Senior Member
Default Re: covering the top of a work bench???
Home Cheapo - probably Lowes too - sells rubber mat by the yard. It's sold as hallway runner. smooth on one side, ribbed on the other. Not exactly sure how wide it is, but I think it would fit the bill.
fotoflojoe is offline   Reply With Quote
Old 10-24-2008, 09:28 AM   #3
1320stang
Senior Member
1320stang's Avatar
ditto, that's exactly what I used, got it at Lowes. It was 36" wide as my bench is 30" deep. I used it rib side up. You could probably glue it down with laminate glue if you wanted, my bench has 10 coats of polyurethane on it that I wanted to semi protect.
__________________
_________________________________________________
Larry Hampton
1963 Fairlane 2 door post
1965 Mustang Coupe
1973 F-100 longbed
2002 Pontiac Grand Prix
2003 Explorer SportTrac
2005 Honda Accord
2008 Mercury Mountaineer
2015 F-150 Screw 5.0 2wd
Quote:
Originally Posted by raccoon View Post
PS: I'm a girl..
1320stang is offline   Reply With Quote
Old 10-24-2008, 09:32 AM   #4
kartracer23
Senior Member
kartracer23's Avatar
I use it for drawer liner. It's $1.97 a running foot. Both Lowe's and HD carry it.
kartracer23 is offline   Reply With Quote
Old 10-24-2008, 11:55 AM   #5
1320stang
Senior Member
1320stang's Avatar
That's what I did with the cut offs.
__________________
Larry Hampton
1965 Mustang Coupe
1973 F-100 longbed
2005 Honda Accord
PS: I'm a girl..
Old 12-08-2009, 08:41 AM   #6
ironroad 9c1
ironroad 9c1's Avatar
Anyone got any reports on how counter top laminate holds up to carb and brake cleaner?
ironroad 9c1 is offline   Reply With Quote
Old 12-08-2009, 11:38 AM   #7
OccupantRJ
Senior Member
OccupantRJ's Avatar
Surplus rubberized conveyor belting. I used Corian solid surface on my last one.
OccupantRJ is offline   Reply With Quote
Old 12-08-2009, 11:42 AM   #8
FlameOut
Senior Member
Rubber roofing material? Probabaly cheaper buying the stuff at HD/Lowes though
FlameOut is offline   Reply With Quote
Old 12-08-2009, 11:48 AM   #9
kartracer23
Senior Member
Quote:
I've got the laminate in my workshop - and use Brake Kleen on everything. Hasn't bothered the laminate in 2 years. I'll even clean it with Brake Kleen. I've got the preformed stuff so there are no open edges - that would be my only concern. Heck - it was about the same price as mdf-and it's ready to go with a backsplash & all. I don't bang on it though - I've got a piece of sheet steel attached to some mdf if I've got to bang out bearings or something.
Old 12-08-2009, 01:42 PM   #10
CrashTestDummy
Senior Member
I have a friend who built plywood shelves and covered them with black laminate. He used the sheet stuff, so the edges were trimmed in it, too. Absolutely no problem in a semi-pro drag racer's garage/shop. We built and ran several cars out of that shop from Super Gas to Pro Stock, and would throw heads and transmissions up on those shelves to work on them.
The laminate survived brake kleen, gas, gear oil, etc. with absolutely no problems. I'm considering the same for the workbench I'm building.
Gene Beaird
Pearland, Texas
CrashTestDummy is offline   Reply With Quote
Old 12-08-2009, 02:05 PM   #11
Falcon67
Senior Member
Falcon67's Avatar
My transmission rebuild bench has a sheet metal top - went to a metal shop and had them bend one up. $25 for a 2x5 piece folded to cover the edges of the MDF.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 12-08-2009, 02:15 PM   #12
Zrexxer
Senior Member
Zrexxer's Avatar
Tractor Supply Company, SKU #5040819 - 48" x 96" heavy duty rubber mat in a roll, 1/4" thick.
Zrexxer is offline   Reply With Quote
Old 12-08-2009, 09:14 PM   #13
ironroad 9c1
Thanks everyone I was thinking of useing counter tops , but wanted to be sure it wasn't gonna melt with carb or brake clean..lol
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
